Log of /Sprout/SproutLoad.pm
Parent Directory
Revision
1.97 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Sep 30 15:23:55 2008 UTC (11 years, 2 months ago) by
parrello
Branch:
MAIN
CVS Tags:
HEAD,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_dev_12152011,
mgrast_rel_2008_1110,
mgrast_rel_2008_1110_v2,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
mgrast_release_3_1_2,
mgrast_version_3_2,
myrast_33,
rast_rel_2008_10_09,
rast_rel_2008_10_29,
rast_rel_2008_11_24,
rast_rel_2008_12_18,
rast_rel_2009_02_05,
rast_rel_2009_03_26,
rast_rel_2009_05_18,
rast_rel_2009_07_09,
rast_rel_2009_0925,
rast_rel_2010_0118,
rast_rel_2010_0526,
rast_rel_2010_0827,
rast_rel_2010_0928,
rast_rel_2010_1206,
rast_rel_2011_0119,
rast_rel_2011_0928,
rast_rel_2014_0729,
rast_rel_2014_0912
Changes since
1.96: +3 -3 lines
Diff to
previous 1.96
to
selected 1.75
New loader technology.
Revision
1.75 -
view)
download)
as text)
annotate)
[selected]
Sun Oct 22 05:17:10 2006 UTC (13 years, 1 month ago) by
parrello
Branch:
MAIN
Changes since
1.74: +45 -12 lines
Diff to
previous 1.74
Changed to use the first alias as the primary functional assignment of non-peg features.
Revision
1.72 -
view)
download)
as text)
annotate)
[select for diffs]
Sat Oct 14 18:12:14 2006 UTC (13 years, 2 months ago) by
parrello
Branch:
MAIN
Changes since
1.71: +49 -11 lines
Diff to
previous 1.71
to
selected 1.75
Changed the subsystem classification implementation so that we can reconstruct the correct hierarchy.
Added new implementations for virulence and essentialiy properties.
Revision
1.68 -
view)
download)
as text)
annotate)
[select for diffs]
Sun Sep 24 17:14:16 2006 UTC (13 years, 2 months ago) by
parrello
Branch:
MAIN
Changes since
1.67: +15 -17 lines
Diff to
previous 1.67
to
selected 1.75
Moved NMPDR group into the Genome record. This insures that all of the information required to generate a popup menu of genomes is available without access to secondary tables.
Revision
1.20 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Nov 2 21:54:40 2005 UTC (14 years, 1 month ago) by
parrello
Branch:
MAIN
Changes since
1.19: +47 -55 lines
Diff to
previous 1.19
to
selected 1.75
Moved the loading of reactions to the Reactions group.
Fixed Reaction and Compound loaders to load all reactions and subsystems rather than only those used in subsystems.
Fixed the Catalyzes loader to use the correct role ID.
Revision
1.18 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Oct 12 03:17:58 2005 UTC (14 years, 2 months ago) by
parrello
Branch:
MAIN
Changes since
1.17: +254 -48 lines
Diff to
previous 1.17
to
selected 1.75
Added load methods for the new subsystem-related tables.
Fixed annotations so the keys are unique without having to change the timestamps.
Added load methods for the reaction/compound tables.
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
