[Bio] / Sprout / SproutGFF.pl Repository:
Log of /Sprout/SproutGFF.pl
Links to mgrast_dev_12152011: (view) (download) (as text) (annotate)
Tue Feb 5 05:47:32 2008 UTC (11 years, 10 months ago) by parrello
Removed obsolete use clauses.
Changes since 1.1: +5 -5 lines
Mon Aug 20 23:28:33 2007 UTC (12 years, 3 months ago) by parrello
Diff to selected 1.3
Replaces nmpdr2gff.
