[Bio] / Sprout / Sprout.pm Repository:
Log of /Sprout/Sprout.pm
Revision 1.118 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Sep 20 14:32:34 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.117: +15 -21 lines
Diff to previous 1.117
Changed subsystem-data access method to use more efficient queries.
Revision 1.117 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 16 18:57:59 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.116: +26 -52 lines
Diff to previous 1.116
Added trace messages.
Revision 1.116 - (view) (download) (as text) (annotate) - [select for diffs]
Changes since 1.115: +5 -10 lines
Diff to previous 1.115
Changes for v24 database.
Revision 1.115 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Sep 7 03:13:32 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.114: +3 -1 lines
Diff to previous 1.114
Fixed to not return nonexistent subsystems when listing the subsystems of a peg.
Revision 1.114 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 3 20:59:57 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.113: +49 -90 lines
Diff to previous 1.113
Fixed some bugs. Added hint support.
Revision 1.113 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 12 06:01:49 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: rast_rel_2008_08_07
Changes since 1.112: +14 -1 lines
Diff to previous 1.112
Updated to be more aggressive in the GenomeOf function.
Revision 1.112 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 28 17:39:38 2008 UTC (11 years, 5 months ago) by parrello
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.111: +1 -1 lines
Diff to previous 1.111
Fixed a bug in the genome menu.
Revision 1.111 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 7 23:11:51 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.110: +71 -5 lines
Diff to previous 1.110
Changed so that keywords are stemmed before being used for text searching.
Revision 1.110 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Apr 29 20:54:51 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.109: +20 -13 lines
Diff to previous 1.109
Changed genome control code generation slightly to be a little simpler.
Revision 1.109 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Mar 23 16:32:05 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.108: +183 -53 lines
Diff to previous 1.108
Reworked code for generating a genome menu.
Revision 1.108 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Feb 14 19:13:33 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.107: +104 -39 lines
Diff to previous 1.107
Cleaned up the group-handling stuff.
Revision 1.107 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Feb 7 00:06:16 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.106: +2 -2 lines
Diff to previous 1.106
Changed RealCoreGenomes so that it will work with the config file capabilities currently in NmpdrSetup.
Revision 1.106 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 6 23:21:02 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.105: +28 -0 lines
Diff to previous 1.105
Added a method to return the true core NMPDR genomes.
Revision 1.105 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 30 22:14:02 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.104: +5 -2 lines
Diff to previous 1.104
Added ability to specify an alternate host for Sprout.
Revision 1.104 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jan 23 00:56:31 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.103: +2 -2 lines
Diff to previous 1.103
Revision 1.103 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 7 18:30:14 2007 UTC (11 years, 11 months ago) by parrello
Changes since 1.102: +17 -28 lines
Diff to previous 1.102
Fixed group file management to remove the old, awful concept of the sort-of group.
Revision 1.102 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Dec 6 14:56:23 2007 UTC (11 years, 11 months ago) by parrello
Changes since 1.101: +263 -178 lines
Diff to previous 1.101
Changed POD format for better compatability with Wiki. Improved handling of the group file used during the load.
Revision 1.101 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 20 23:29:24 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.100: +1 -1 lines
Diff to previous 1.100
Fixed a bad comment.
Revision 1.100 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jul 16 19:59:50 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.99: +164 -247 lines
Diff to previous 1.99
Revision 1.99 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Apr 27 22:21:46 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.98: +85 -96 lines
Diff to previous 1.98
Converted to use the new attribute system for most properties.
Revision 1.98 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Apr 10 06:13:33 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.97: +73 -3 lines
Diff to previous 1.97
Converted from DBObject to ERDBObject. Added a SimMatrix command that corresponds to BBHMatrix.
Sun Feb 4 13:09:10 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.96: +1 -0 lines
Diff to previous 1.96
Fixed a bug in "AddProperty".
Wed Dec 6 03:37:26 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.95: +53 -0 lines
Diff to previous 1.95
Added support for batch BBH queries.
Wed Nov 29 20:31:32 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.94: +2 -2 lines
Diff to previous 1.94
Changed to use new format for delete methods.
Fri Nov 3 00:42:25 2006 UTC (13 years ago) by parrello
Changes since 1.93: +9 -2 lines
Diff to previous 1.93
Fixed BBH code to filter out non-Sprout genomes.
Sun Oct 22 05:15:56 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.92: +50 -57 lines
Diff to previous 1.92
Changed to use the primary functional assignment of a feature whenever possible.
Mon Oct 16 07:41:50 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.91: +3 -2 lines
Diff to previous 1.91
Fixed the protein translation so that it is no longer case-sensitive.
Sat Oct 14 18:12:48 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.90: +44 -0 lines
Diff to previous 1.90
Changed the subsystem classification implementation so that we can reconstruct the correct hierarchy.
Fri Sep 29 15:10:05 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.89: +106 -57 lines
Diff to previous 1.89
Wed Sep 27 16:55:38 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.88: +1 -1 lines
Diff to previous 1.88
Wed Sep 27 12:34:46 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.87: +40 -4 lines
Diff to previous 1.87
Added a relationship between features and subsystems.
Tue Sep 26 13:46:03 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.86: +0 -91 lines
Diff to previous 1.86
Sun Sep 24 17:14:16 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.85: +95 -4 lines
Diff to previous 1.85
Moved NMPDR group into the Genome record. This insures that all of the information required to generate a popup menu of genomes is available without access to secondary tables.
Tue Sep 19 00:14:04 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.84: +73 -6 lines
Diff to previous 1.84
Integrated group file processing. Added the ability to generate a fast genome menu, and to specify a preselected genome.
Thu Sep 14 14:11:09 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.83: +9 -22 lines
Diff to previous 1.83
Converted to use the BBH server.
Wed Sep 6 19:30:22 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.82: +61 -0 lines
Diff to previous 1.82
Added support for the group data file.
Sat Sep 2 07:00:54 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.81: +42 -0 lines
Diff to previous 1.81
Moved in the method for fixing group hashes from GenomeStats.
Thu Aug 24 17:32:09 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.80: +1 -1 lines
Diff to previous 1.80
Changed the substitution logic in the annotation methods to prevent an execution warning.
Thu Aug 10 07:34:37 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.79: +61 -1 lines
Diff to previous 1.79
Added new methods to support genome statistics functions.
Mon Jul 31 20:07:06 2006 UTC (13 years, 3 months ago) by olson
Changes since 1.78: +3 -2 lines
Diff to previous 1.78
Add support for a Sprout database on a different machine.
Wed Jul 26 14:47:03 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.77: +4 -1 lines
Diff to previous 1.77
Added the ability to specify a DBD directory in FIG_Config.
Sun Jul 23 16:44:10 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.76: +3 -0 lines
Diff to previous 1.76
Added tracing.
Sun Jun 25 18:03:29 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.75: +1 -1 lines
Diff to previous 1.75
Sun Jun 25 18:02:35 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.74: +64 -0 lines
Diff to previous 1.74
Created a method to perform the boundaries_of function.
Sun Jun 25 07:34:46 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.73: +39 -0 lines
Diff to previous 1.73
Sun Jun 25 02:44:43 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.72: +4 -3 lines
Diff to previous 1.72
Sun Jun 25 02:37:04 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.71: +1 -1 lines
Diff to previous 1.71
Fixed a bug in CouplingEvidence.
Sun Jun 25 00:07:22 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.70: +66 -37 lines
Diff to previous 1.70
Added a method to request similarities from the network.
Fri Jun 23 19:08:58 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.69: +1 -0 lines
Diff to previous 1.69
Added tracing.
Fri Jun 23 01:34:42 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.68: +5 -4 lines
Diff to previous 1.68
Fixed GeneMenu method to include the strain in the genome list.
Sun Jun 18 08:51:59 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.67: +1 -1 lines
Diff to previous 1.67
Fixed a POD error.
Sun Jun 18 07:39:54 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.66: +1 -1 lines
Diff to previous 1.66
Sun Jun 18 07:33:53 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.65: +1 -1 lines
Diff to previous 1.65
Sun Jun 18 07:20:33 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.64: +1 -1 lines
Diff to previous 1.64
Sun Jun 18 07:09:55 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.63: +1 -1 lines
Diff to previous 1.63
Sun Jun 18 07:03:00 2006 UTC (13 years, 5 months ago) by parrello
Diff to previous 1.62
Sun Jun 18 05:38:12 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.61: +122 -0 lines
Diff to previous 1.61
Added new methods used by the GenomeStats script.
Wed Jun 14 20:15:48 2006 UTC (13 years, 5 months ago) by parrello
Diff to previous 1.60
Wed Jun 14 19:47:19 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.59: +4 -4 lines
Diff to previous 1.59
Fixed a bug in the computation of coupled features.
Wed Jun 7 01:53:03 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.58: +89 -0 lines
Diff to previous 1.58
Added methods to get a count of Contigs for a genome and to create an HTML menu of genomes.
Tue Jun 6 05:07:15 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.57: +65 -346 lines
Diff to previous 1.57
Added new methods to support the ShowCounts script. Converted to inherit ERDB methods.
Sat May 13 03:10:15 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.56: +5 -2 lines
Diff to previous 1.56
Added the ability to specify the database socket when creating a Sprout object.
Changes since 1.55: +9 -6 lines
Diff to previous 1.55
Mon Apr 3 18:33:58 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.54: +7 -2 lines
Diff to previous 1.54
Updated the documentation.
Thu Feb 16 04:10:07 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.53: +1 -1 lines
Diff to previous 1.53
Fixed to expect the DBD files in the $FIG_Config::fig directory.
Sat Jan 28 08:59:17 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.52: +36 -0 lines
Diff to previous 1.52
Added a method for deleting genomes.
Mon Dec 12 21:48:57 2005 UTC (13 years, 11 months ago) by parrello
Changes since 1.51: +9 -1 lines
Diff to previous 1.51
Added code taken from the FIG "function_of" that cleans excess data out of functional assignments.
Thu Dec 8 18:02:52 2005 UTC (13 years, 11 months ago) by parrello
Changes since 1.50: +2 -1 lines
Diff to previous 1.50
Fixed a bug in the IsComplete method.
Fri Oct 21 03:29:35 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.49: +1 -1 lines
Diff to previous 1.49
Another fix to the icky function_of mess.
Thu Oct 20 18:03:43 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.48: +1 -0 lines
Diff to previous 1.48
Added more tracing.
Thu Oct 20 12:33:00 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.47: +33 -24 lines
Diff to previous 1.47
Another attempt to get functional assignment into line.
Thu Oct 20 12:02:43 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.46: +6 -5 lines
Diff to previous 1.46
Changed "AllFunctionsOf" to get user data from the MadeAnnotation relationship.
Thu Oct 20 11:52:36 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.45: +3 -7 lines
Diff to previous 1.45
Changed AllFunctionsOf to map users to roles instead of roles to users. This allows more than one user to make the same assignment without losing it.
Thu Oct 20 10:20:27 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.44: +69 -1 lines
Diff to previous 1.44
Added a new function to produce the output expected by "functions_of" in a list context.
Fixed documentation errors.
Thu Oct 20 09:32:18 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.43: +1 -1 lines
Diff to previous 1.43
Fixed an error in the comments.
Tue Oct 18 18:36:26 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.42: +2 -2 lines
Diff to previous 1.42
Fixed error in the parsing of functional assignments.
Tue Oct 18 06:58:09 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.41: +8 -3 lines
Diff to previous 1.41
Okay, this time I've REALLY fixed the duplicate-role problem in SubsystemsOf
Tue Oct 18 02:24:23 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.40: +9 -4 lines
Diff to previous 1.40
Fixed a bug in the FeatureLocation method's segment recombination code for the "-" strand.
Wed Oct 12 03:12:24 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.39: +69 -12 lines
Diff to previous 1.39
Fixed a bug in location parsing.
Added support for the UnvSubsys feature clustering.
Added support for the "raw flag" on feature_annotations.
Changed the timestamp conversion for compatability
Fixed BBH methods to allow multiple target hits.
Wed Sep 14 14:04:13 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.38: +1 -1 lines
Diff to previous 1.38
Wed Sep 14 14:02:44 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.37: +6 -6 lines
Diff to previous 1.37
Wed Sep 14 13:55:54 2005 UTC (14 years, 2 months ago) by parrello
Diff to previous 1.36
Wed Sep 14 13:52:34 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.35: +2 -2 lines
Diff to previous 1.35
Wed Sep 14 13:47:26 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.34: +3 -3 lines
Diff to previous 1.34
Wed Sep 14 13:43:31 2005 UTC (14 years, 2 months ago) by parrello
Diff to previous 1.33
Wed Sep 14 13:26:27 2005 UTC (14 years, 2 months ago) by parrello
Diff to previous 1.32
Wed Sep 14 13:24:14 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.31: +2 -0 lines
Diff to previous 1.31
Wed Sep 14 13:14:12 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.30: +1 -1 lines
Diff to previous 1.30
Wed Sep 14 13:13:25 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.29: +1 -0 lines
Diff to previous 1.29
Wed Sep 14 13:06:53 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.28: +5 -2 lines
Diff to previous 1.28
Wed Sep 14 13:01:40 2005 UTC (14 years, 2 months ago) by parrello
Diff to previous 1.27
Wed Sep 14 12:56:13 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.26: +1 -2 lines
Diff to previous 1.26
Attempted to fix the DNA sequence methods.
Tue Sep 13 18:33:20 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.25: +1 -0 lines
Diff to previous 1.25
Added some tracing.
Sun Sep 11 17:29:52 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.24: +8 -1 lines
Diff to previous 1.24
Sun Sep 11 17:08:59 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.23: +3 -3 lines
Diff to previous 1.23
Changed FASTA methods to normalize to lower case instead of upper case.
Fri Sep 9 21:15:47 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.22: +4 -1 lines
Diff to previous 1.22
Fixed a bug in the GetCoupling code that handles the ordering of evidence pairs.
Fri Sep 9 21:10:46 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.21: +1 -0 lines
Diff to previous 1.21
Fri Sep 9 20:40:41 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.20: +2 -0 lines
Diff to previous 1.20
Added trace messages for Coupling.
Wed Aug 24 19:31:20 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.19: +11 -6 lines
Diff to previous 1.19
Fixed FeatureLocations to return a comma-delimited string rather than a space-delimited string.
Changes since 1.18: +97 -12 lines
Diff to previous 1.18
Tue Jun 28 21:34:15 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.17: +96 -16 lines
Diff to previous 1.17
Added methods to find and identify the Sprout load files.
Mon Jun 27 20:00:55 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.16: +3 -3 lines
Diff to previous 1.16
after Sprout runs
Fri Jun 24 21:45:45 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.15: +33 -1 lines
Added a new method that returns a list of Subsystem names without extracting Role information.
Wed Jun 22 21:30:45 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.14: +1168 -862 lines
Fixed the tabs.
Added some new methods required by SFXlate.
Thu Jun 9 19:06:55 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.13: +11 -7 lines
Thu May 5 03:14:03 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.12: +3 -16 lines
Wed May 4 03:24:43 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.11: +10 -19 lines
Tue Mar 8 09:17:40 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.10: +41 -25 lines
no message
Fri Feb 25 18:41:45 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.9: +113 -109 lines
no message
Mon Feb 7 00:32:07 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.8: +35 -15 lines
no message
Thu Jan 27 00:30:20 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.7: +46 -0 lines
no message
Wed Jan 26 22:26:09 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.6: +8 -1 lines
no message
Wed Jan 26 17:41:53 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.5: +0 -1 lines
no message
Tue Jan 25 03:02:07 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.4: +18 -7 lines
no message
Tue Jan 25 01:36:09 2005 UTC (14 years, 9 months ago) by parrello
no message
Tue Jan 25 01:00:20 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.2: +161 -76 lines
no message
Sun Jan 23 22:31:29 2005 UTC (14 years, 9 months ago) by parrello
no message
Sun Jan 23 16:12:29 2005 UTC (14 years, 10 months ago) by parrello
no message
