--- Sprout.pm 2005/09/11 17:29:52 1.25 +++ Sprout.pm 2005/09/14 14:04:13 1.39 @@ -622,8 +622,10 @@ } # Remember this specifier for the adjacent-segment test the next time through. ($prevContig, $prevBeg, $prevDir, $prevLen) = ($contigID, $beg, $dir, $len); + # Compute the initial base pair. + my $start = ($dir eq "+" ? $beg : $beg + $len - 1); # Add the specifier to the list. - push @retVal, "${contigID}_$beg$dir$len"; + push @retVal, "${contigID}_$start$dir$len"; } # Return the list in the format indicated by the context. return (wantarray ? @retVal : join(',', @retVal)); @@ -765,13 +767,15 @@ # the start point is the ending. Note that in the latter case we must reverse the DNA string # before putting it in the return value. my ($start, $stop); + Trace("Parse of \"$location\" is $beg$dir$len.") if T(SDNA => 4); if ($dir eq "+") { $start = $beg; $stop = $beg + $len - 1; } else { - $start = $beg + $len + 1; + $start = $beg - $len + 1; $stop = $beg; } + Trace("Looking for sequences containing $start through $stop.") if T(SDNA => 4); my $query = $self->Get(['IsMadeUpOf','Sequence'], "IsMadeUpOf(from-link) = ? AND IsMadeUpOf(start-position) + IsMadeUpOf(len) > ? AND " . " IsMadeUpOf(start-position) <= ? ORDER BY IsMadeUpOf(start-position)", @@ -783,18 +787,19 @@ $sequence->Values(['IsMadeUpOf(start-position)', 'Sequence(sequence)', 'IsMadeUpOf(len)']); my $stopPosition = $startPosition + $sequenceLength; + Trace("Sequence is from $startPosition to $stopPosition.") if T(SDNA => 4); # Figure out the start point and length of the relevant section. my $pos1 = ($start < $startPosition ? 0 : $start - $startPosition); - my $len = ($stopPosition <= $stop ? $stopPosition : $stop) - $startPosition - $pos1; + my $len1 = ($stopPosition < $stop ? $stopPosition : $stop) + 1 - $startPosition - $pos1; + Trace("Position is $pos1 for length $len1.") if T(SDNA => 4); # Add the relevant data to the location data. - $locationDNA .= substr($sequenceData, $pos1, $len); + $locationDNA .= substr($sequenceData, $pos1, $len1); } # Add this location's data to the return string. Note that we may need to reverse it. if ($dir eq '+') { $retVal .= $locationDNA; } else { - $locationDNA = join('', reverse split //, $locationDNA); - $retVal .= $locationDNA; + $retVal .= FIG::reverse_comp($locationDNA); } } # Return the result. @@ -2048,6 +2053,7 @@ # Get the parameters. my ($self, $entityName, $entityID) = @_; # Check for the entity instance. + Trace("Checking existence of $entityName with ID=$entityID.") if T(4); my $testInstance = $self->GetEntity($entityName, $entityID); # Return an existence indicator. my $retVal = ($testInstance ? 1 : 0);
