[Bio] / Sprout / SimLoad.pl Repository:
Log of /Sprout/SimLoad.pl
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Mon Jan 19 21:46:21 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
ERDB 2.0 support
Thu Dec 6 14:58:03 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.10: +3 -3 lines
Mon Feb 13 15:42:48 2006 UTC (14 years ago) by parrello
Changes since 1.9: +7 -2 lines
Fixed to work even if the config variables are undefined.
Thu Feb 2 21:30:05 2006 UTC (14 years ago) by parrello
Changes since 1.8: +52 -36 lines
Wed Feb 1 03:28:11 2006 UTC (14 years ago) by parrello
Changes since 1.7: +16 -12 lines
Changed the case of the TBL file names to match what's on disk.
Wed Feb 1 03:18:41 2006 UTC (14 years ago) by parrello
Changes since 1.6: +38 -26 lines
Fixed to allow loading of multiple groups and to use the new directory structure.
Tue Jan 31 07:33:46 2006 UTC (14 years ago) by parrello
Changes since 1.5: +7 -1 lines
Sun Jan 15 21:32:17 2006 UTC (14 years, 1 month ago) by parrello
Changes since 1.4: +5 -3 lines
Wed Jan 11 19:39:20 2006 UTC (14 years, 1 month ago) by parrello
Changes since 1.3: +17 -12 lines
Fixed some bugs.
Fri Jan 6 20:35:01 2006 UTC (14 years, 1 month ago) by parrello
Changes since 1.2: +111 -90 lines
Added support for finding similarities close to a gene.
Wed Jul 27 20:05:58 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.1: +4 -4 lines
Changed to use the new BasicLocation object instead of the old Location object.
Thu Jun 9 19:06:55 2005 UTC (14 years, 8 months ago) by parrello
