[Bio] / Sprout / SimBlocks.pm Repository:
Log of /Sprout/SimBlocks.pm
Links to mgrast_rel_2008_0924: (view) (download) (as text) (annotate)
Thu Dec 6 14:58:03 2007 UTC (12 years, 2 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Changes since 1.10: +26 -26 lines
Tue Apr 10 06:12:29 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.9: +8 -8 lines
Tue Jun 6 05:05:54 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.8: +3 -3 lines
Converted to use new ERDB interface.
Thu Feb 16 04:10:07 2006 UTC (14 years ago) by parrello
Fixed to expect the DBD files in the $FIG_Config::fig directory.
Mon Feb 13 15:42:48 2006 UTC (14 years ago) by parrello
Changes since 1.6: +20 -1 lines
Fixed to work even if the config variables are undefined.
Tue Feb 7 16:06:55 2006 UTC (14 years ago) by parrello
Replaced field "end" with "endpoint" to fix reserved word problem.
Fri Jan 13 07:00:28 2006 UTC (14 years, 1 month ago) by parrello
Changes since 1.4: +8 -4 lines
Fixed some bugs.
Wed Jan 11 19:39:20 2006 UTC (14 years, 1 month ago) by parrello
Changes since 1.3: +103 -1 lines
Fixed some bugs.
Fri Jan 6 20:35:01 2006 UTC (14 years, 1 month ago) by parrello
Changes since 1.2: +202 -12 lines
Added support for finding similarities close to a gene.
Thu Jun 9 19:06:55 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.1: +812 -60 lines
Wed May 4 03:24:43 2005 UTC (14 years, 9 months ago) by parrello
