[Bio] / Sprout / ShowCounts.pl Repository:
Log of /Sprout/ShowCounts.pl
Mon Jan 19 21:57:23 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.18: +217 -78 lines
Diff to previous 1.18 , to selected 1.13
Improved site maintenance utilities.
Thu Oct 9 17:22:26 2008 UTC (11 years, 1 month ago) by parrello
Changes since 1.17: +1 -0 lines
Diff to previous 1.17 , to selected 1.13
Added a trace message.
Tue Sep 16 18:59:01 2008 UTC (11 years, 2 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Changes since 1.16: +32 -183 lines
Diff to previous 1.16 , to selected 1.13
Fixed to work with the wiki.
Sun Mar 23 16:18:16 2008 UTC (11 years, 8 months ago) by parrello
Diff to previous 1.15 , to selected 1.13
Changed to use the new genome menu code for generating genome controls.
Tue Feb 5 05:47:32 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.14: +0 -2 lines
Diff to previous 1.14 , to selected 1.13
Removed obsolete use clauses.
Changes since 1.13: +46 -28 lines
Revision 1.13 - (view) (download) (as text) (annotate) - [selected]
Fri May 11 06:31:54 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.12: +4 -1 lines
Added a count of docked PDBs.
Tue Apr 10 06:08:06 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.11: +65 -7 lines
Diff to previous 1.11 , to selected 1.13
Separated the organism and subsystem forms into different pieces.
Wed Feb 21 13:19:54 2007 UTC (12 years, 9 months ago) by parrello
Diff to previous 1.10 , to selected 1.13
Fixed the output file name for the genome control.
Tue Oct 3 02:48:59 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.9: +1 -0 lines
Diff to previous 1.9 , to selected 1.13
Fixed default trace level.
Tue Jun 27 17:06:41 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.8: +2 -2 lines
Diff to previous 1.8 , to selected 1.13
Modified to make the version counts a little prettier.
Tue Jun 27 16:54:35 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.7: +13 -7 lines
Diff to previous 1.7 , to selected 1.13
Added more things to count in the second line.
Tue Jun 27 16:45:07 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.6: +10 -15 lines
Diff to previous 1.6 , to selected 1.13
Changed to display the difference in the annotation count instead the number of updated or new annotations.
Fri Jun 23 22:54:55 2006 UTC (13 years, 5 months ago) by parrello
Diff to previous 1.5 , to selected 1.13
Changed annotation counter to read "updated" instead of "new".
Fri Jun 23 19:08:58 2006 UTC (13 years, 5 months ago) by parrello
Diff to previous 1.4 , to selected 1.13
Added tracing.
Thu Jun 8 13:41:57 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.3: +17 -10 lines
Diff to previous 1.3 , to selected 1.13
Added code to validate the parameters.
Wed Jun 7 01:56:49 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.2: +28 -3 lines
Diff to previous 1.2 , to selected 1.13
Added code to generate the subsystem form.
Tue Jun 6 05:45:49 2006 UTC (13 years, 5 months ago) by parrello
Diff to previous 1.1 , to selected 1.13
Changed to use the new "nmpdr_pages" config variable.
Tue Jun 6 05:06:34 2006 UTC (13 years, 5 months ago) by parrello
Diff to selected 1.13
New script to generate include files for the NMPDR cover pages.
