[Bio] / Sprout / SetPermissions.pl Repository:
Log of /Sprout/SetPermissions.pl
Tue Feb 5 05:47:32 2008 UTC (12 years, 5 months ago) by parrello
Changes since 1.7: +3 -2 lines
Removed obsolete use clauses.
Wed Nov 15 22:35:06 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.6: +4 -2 lines
Fixed to work in non-nmpdr environments.
Mon Oct 16 07:40:59 2006 UTC (13 years, 8 months ago) by parrello
Added a display of the current time.
Thu Oct 5 21:56:10 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.4: +8 -57 lines
Removed tracing.
Tue Oct 3 02:48:59 2006 UTC (13 years, 9 months ago) by parrello
Fixed default trace level.
Wed Jun 21 19:41:01 2006 UTC (14 years ago) by parrello
Fixed the sticky bit setting.
Wed Jun 14 00:54:27 2006 UTC (14 years ago) by parrello
Changes since 1.1: +6 -4 lines
Changed to work specifically for the NMPDR environment.
Thu Jun 8 13:40:47 2006 UTC (14 years, 1 month ago) by parrello
Diff to selected 1.2
Added to provide a way to fix the permissions in the NMPDR directories.
