[Bio] / Sprout / SearchSkeleton.pm Repository:
Log of /Sprout/SearchSkeleton.pm
Mon Mar 16 00:23:37 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Converted to new hint system.
Thu Feb 5 07:17:55 2009 UTC (11 years ago) by parrello
CVS Tags: rast_rel_2009_03_26
Re-enabled the drug docking search.
Mon Jan 19 21:56:19 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.1: +118 -77 lines
Wed Sep 3 21:00:28 2008 UTC (11 years, 5 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Old search code, repackaged for the NMPDR.
