[Bio] / Sprout / SearchHelper.pm Repository:
Log of /Sprout/SearchHelper.pm
Wed Sep 3 20:54:47 2008 UTC (11 years, 1 month ago) by parrello
Changes since 1.40: +23 -224 lines
Diff to previous 1.40 , to selected 1.31
Fixed URLs.
Tue Apr 29 20:52:05 2008 UTC (11 years, 5 months ago) by parrello
Changes since 1.39: +3 -4 lines
Diff to previous 1.39 , to selected 1.31
Changed hint function to use the new wiki syntax for links.
Tue Feb 5 05:43:46 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.38: +3 -3 lines
Diff to previous 1.38 , to selected 1.31
Fixed Wiki help pointer.
Changes since 1.37: +56 -52 lines
Diff to previous 1.37 , to selected 1.31
Mon Aug 20 23:22:42 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.36: +22 -19 lines
Diff to previous 1.36 , to selected 1.31
Changed hints to pop up a wiki page when clicked. Removed OtherOnly button from the genome control. Removed some obsolete tracing-related code.
Wed Jul 25 16:21:21 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.35: +7 -3 lines
Diff to previous 1.35 , to selected 1.31
Fixed an error that caused search results to appear in the wrong order.
Mon Jul 16 20:53:11 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.34: +2 -3 lines
Diff to previous 1.34 , to selected 1.31
Fixed some bugs in the advanced gene search.
Changes since 1.33: +238 -1012 lines
Diff to previous 1.33 , to selected 1.31
Tue Jun 19 21:28:21 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.32: +89 -10 lines
Diff to previous 1.32 , to selected 1.31
Fixed some bugs. Added support for the pattern scan search.
Thu May 17 23:43:30 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.31: +142 -38 lines
Diff to previous 1.31
Added support for a flanking width in the FASTA formatter. Changed genome menu to separate supporting genomes by domain and use colors.
Revision 1.31 - (view) (download) (as text) (annotate) - [selected]
Fri May 11 06:28:21 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.30: +92 -11 lines
Diff to previous 1.30
Added support for non-feature searches.
Thu Apr 19 00:05:51 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.29: +70 -19 lines
Diff to previous 1.29 , to selected 1.31
Added a utility method for handling tuning parameters more easily and provided improved control for positioning of extra columns.
Sat Apr 14 21:41:25 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.28: +56 -17 lines
Diff to previous 1.28 , to selected 1.31
Fixed a bug in the MakeTable method that caused the subsystem trees to look ridiculous in Internet Explorer. Added support for FASTA downloads.
Tue Apr 10 06:05:40 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.27: +90 -9 lines
Diff to previous 1.27 , to selected 1.31
Added support for search result downloads and for status messages during long searches.
Wed Feb 21 13:18:27 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.26: +63 -8 lines
Diff to previous 1.26 , to selected 1.31
Added the ability to split the filter rows.
Sun Feb 4 13:07:24 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.25: +13 -2 lines
Diff to previous 1.25 , to selected 1.31
Backed out the ENTER fix for Internet Explorer. Added code to make unclassified subsystems sort to the end of the subsystem tree.
Wed Dec 20 20:06:17 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.24: +1 -5 lines
Diff to previous 1.24 , to selected 1.31
Changed so that a search is performed if no results exist and the user pressed ENTER instead of clicking the search button.
Fri Dec 15 03:27:20 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.23: +2 -2 lines
Diff to previous 1.23 , to selected 1.31
Added "x" and "n" to the legal DNA letters.
Wed Dec 6 03:35:42 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.22: +53 -2 lines
Diff to previous 1.22 , to selected 1.31
Converted the mini-forms on the search results to fake buttons.
Sat Dec 2 09:45:30 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.21: +4 -1 lines
Diff to previous 1.21 , to selected 1.31
Fixed a bug with keyword validation. Changed the ShowURL checkbox default to checked.
Thu Nov 30 23:04:37 2006 UTC (12 years, 10 months ago) by parrello
Diff to previous 1.20 , to selected 1.31
Changed the label on the organism name column.
Tue Nov 21 17:23:41 2006 UTC (12 years, 11 months ago) by parrello
Diff to previous 1.19 , to selected 1.31
Fixed a bug in ComputeFASTA.
Mon Nov 20 05:54:09 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.18: +45 -14 lines
Diff to previous 1.18 , to selected 1.31
Upgraded so that the search parameters are preserved by the page navigator.
Sat Nov 18 20:36:49 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.17: +91 -44 lines
Diff to previous 1.17 , to selected 1.31
Added support for blastx. Changed search box on genome menu to use a button. Added ability to change main button caption.
Wed Nov 15 22:34:50 2006 UTC (12 years, 11 months ago) by parrello
Diff to previous 1.16 , to selected 1.31
Wed Nov 15 12:02:46 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.15: +563 -0 lines
Diff to previous 1.15 , to selected 1.31
Added support for tree controls and keyword field validation.
Fri Nov 10 22:01:36 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.14: +12 -12 lines
Diff to previous 1.14 , to selected 1.31
Changed the handling of the advanced class list so that it is no longer necessary to maintain a list of search helpers.
Changed the genome menu so that we can remove the Search button.
Wed Nov 8 23:18:24 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.13: +24 -15 lines
Diff to previous 1.13 , to selected 1.31
Added capability to override the default feature columns. Moved the extra columns to the front of the result list.
Fri Nov 3 00:40:16 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.12: +72 -33 lines
Diff to previous 1.12 , to selected 1.31
Added support for the new special attribute keywords and for display of subsystems in the result list.
Mon Oct 16 22:58:37 2006 UTC (13 years ago) by parrello
Changes since 1.11: +1 -35 lines
Diff to previous 1.11 , to selected 1.31
Removed obsolete feature-type code.
Mon Oct 16 07:44:13 2006 UTC (13 years ago) by parrello
Changes since 1.10: +49 -32 lines
Diff to previous 1.10 , to selected 1.31
Factored the FeatureQuery module into a base class that handles feature manipulation and a subclass that handles feature manipulation and query support.
Fri Oct 13 21:45:11 2006 UTC (13 years ago) by parrello
Changes since 1.9: +80 -25 lines
Diff to previous 1.9 , to selected 1.31
Sat Oct 7 13:18:11 2006 UTC (13 years ago) by parrello
Changes since 1.8: +44 -3 lines
Diff to previous 1.8 , to selected 1.31
Fixed some comments. Fixed the advanced-clasess and feature-types methods.
Wed Oct 4 16:03:35 2006 UTC (13 years ago) by parrello
Changes since 1.7: +11 -2 lines
Diff to previous 1.7 , to selected 1.31
Added the capability to de-select genomes selected in another gene menu.
Tue Oct 3 11:05:45 2006 UTC (13 years ago) by parrello
Diff to previous 1.6 , to selected 1.31
Upgraded to allow specification of multiple property values per property.
Mon Oct 2 07:31:46 2006 UTC (13 years ago) by parrello
Diff to previous 1.5 , to selected 1.31
Fixed GBrowse URL method.
Mon Oct 2 06:35:31 2006 UTC (13 years ago) by parrello
Diff to previous 1.4 , to selected 1.31
Mon Oct 2 03:15:37 2006 UTC (13 years ago) by parrello
Changes since 1.3: +73 -47 lines
Diff to previous 1.3 , to selected 1.31
Moved the show aliases option to the FeatureQuery object.
Fri Sep 29 15:10:05 2006 UTC (13 years ago) by parrello
Changes since 1.2: +420 -50 lines
Diff to previous 1.2 , to selected 1.31
Wed Sep 27 16:55:38 2006 UTC (13 years ago) by parrello
Changes since 1.1: +215 -26 lines
Diff to previous 1.1 , to selected 1.31
Tue Sep 26 13:46:03 2006 UTC (13 years ago) by parrello
Diff to selected 1.31
