[Bio] / Sprout / SearchHelper.pm Repository:
Log of /Sprout/SearchHelper.pm
Links to rast_rel_2009_05_18: (view) (download) (as text) (annotate)
Thu Apr 2 01:45:05 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.47: +40 -0 lines
Diff to previous 1.47
Added ID parsing logic for the Batch Search.
Mon Mar 16 00:23:37 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.46: +7 -7 lines
Diff to previous 1.46
Converted to new hint system.
Sat Mar 7 18:07:36 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.45: +2 -2 lines
Diff to previous 1.45
Cleaned up some error messages. Fixed some bugs in search.
Mon Mar 2 22:31:33 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.44: +7 -54 lines
Diff to previous 1.44
Added support for form IDs.
Thu Feb 5 07:17:03 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.43: +1 -2 lines
Diff to previous 1.43
Changed the expiration interval for the remembered parameters.
CVS Tags: rast_rel_2009_02_05
Changes since 1.42: +179 -50 lines
Diff to previous 1.42
Fri Oct 17 16:41:47 2008 UTC (10 years, 11 months ago) by parrello
Changes since 1.41: +11 -3 lines
Diff to previous 1.41
Added support for comment labels in FASTA downloads.
Wed Sep 3 20:54:47 2008 UTC (11 years ago) by parrello
Changes since 1.40: +23 -224 lines
Diff to previous 1.40
Fixed URLs.
Tue Apr 29 20:52:05 2008 UTC (11 years, 4 months ago) by parrello
Changes since 1.39: +3 -4 lines
Diff to previous 1.39
Changed hint function to use the new wiki syntax for links.
Tue Feb 5 05:43:46 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.38: +3 -3 lines
Diff to previous 1.38
Fixed Wiki help pointer.
Changes since 1.37: +56 -52 lines
Diff to previous 1.37
Mon Aug 20 23:22:42 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.36: +22 -19 lines
Diff to previous 1.36
Changed hints to pop up a wiki page when clicked. Removed OtherOnly button from the genome control. Removed some obsolete tracing-related code.
Wed Jul 25 16:21:21 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.35: +7 -3 lines
Diff to previous 1.35
Fixed an error that caused search results to appear in the wrong order.
Mon Jul 16 20:53:11 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.34: +2 -3 lines
Diff to previous 1.34
Fixed some bugs in the advanced gene search.
Changes since 1.33: +238 -1012 lines
Diff to previous 1.33
Tue Jun 19 21:28:21 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.32: +89 -10 lines
Diff to previous 1.32
Fixed some bugs. Added support for the pattern scan search.
Thu May 17 23:43:30 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.31: +142 -38 lines
Diff to previous 1.31
Added support for a flanking width in the FASTA formatter. Changed genome menu to separate supporting genomes by domain and use colors.
Fri May 11 06:28:21 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.30: +92 -11 lines
Diff to previous 1.30
Added support for non-feature searches.
Thu Apr 19 00:05:51 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.29: +70 -19 lines
Diff to previous 1.29
Added a utility method for handling tuning parameters more easily and provided improved control for positioning of extra columns.
Sat Apr 14 21:41:25 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.28: +56 -17 lines
Diff to previous 1.28
Fixed a bug in the MakeTable method that caused the subsystem trees to look ridiculous in Internet Explorer. Added support for FASTA downloads.
Tue Apr 10 06:05:40 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.27: +90 -9 lines
Diff to previous 1.27
Added support for search result downloads and for status messages during long searches.
Wed Feb 21 13:18:27 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.26: +63 -8 lines
Diff to previous 1.26
Added the ability to split the filter rows.
Sun Feb 4 13:07:24 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.25: +13 -2 lines
Diff to previous 1.25
Backed out the ENTER fix for Internet Explorer. Added code to make unclassified subsystems sort to the end of the subsystem tree.
Wed Dec 20 20:06:17 2006 UTC (12 years, 9 months ago) by parrello
Changes since 1.24: +1 -5 lines
Diff to previous 1.24
Changed so that a search is performed if no results exist and the user pressed ENTER instead of clicking the search button.
Fri Dec 15 03:27:20 2006 UTC (12 years, 9 months ago) by parrello
Changes since 1.23: +2 -2 lines
Diff to previous 1.23
Added "x" and "n" to the legal DNA letters.
Wed Dec 6 03:35:42 2006 UTC (12 years, 9 months ago) by parrello
Changes since 1.22: +53 -2 lines
Diff to previous 1.22
Converted the mini-forms on the search results to fake buttons.
Sat Dec 2 09:45:30 2006 UTC (12 years, 9 months ago) by parrello
Changes since 1.21: +4 -1 lines
Diff to previous 1.21
Fixed a bug with keyword validation. Changed the ShowURL checkbox default to checked.
Thu Nov 30 23:04:37 2006 UTC (12 years, 9 months ago) by parrello
Diff to previous 1.20
Changed the label on the organism name column.
Tue Nov 21 17:23:41 2006 UTC (12 years, 10 months ago) by parrello
Diff to previous 1.19
Fixed a bug in ComputeFASTA.
Mon Nov 20 05:54:09 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.18: +45 -14 lines
Diff to previous 1.18
Upgraded so that the search parameters are preserved by the page navigator.
Sat Nov 18 20:36:49 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.17: +91 -44 lines
Diff to previous 1.17
Added support for blastx. Changed search box on genome menu to use a button. Added ability to change main button caption.
Wed Nov 15 22:34:50 2006 UTC (12 years, 10 months ago) by parrello
Diff to previous 1.16
Wed Nov 15 12:02:46 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.15: +563 -0 lines
Added support for tree controls and keyword field validation.
Fri Nov 10 22:01:36 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.14: +12 -12 lines
Changed the handling of the advanced class list so that it is no longer necessary to maintain a list of search helpers.
Changed the genome menu so that we can remove the Search button.
Wed Nov 8 23:18:24 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.13: +24 -15 lines
Added capability to override the default feature columns. Moved the extra columns to the front of the result list.
Fri Nov 3 00:40:16 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.12: +72 -33 lines
Added support for the new special attribute keywords and for display of subsystems in the result list.
Mon Oct 16 22:58:37 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.11: +1 -35 lines
Removed obsolete feature-type code.
Mon Oct 16 07:44:13 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.10: +49 -32 lines
Factored the FeatureQuery module into a base class that handles feature manipulation and a subclass that handles feature manipulation and query support.
Fri Oct 13 21:45:11 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.9: +80 -25 lines
Sat Oct 7 13:18:11 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.8: +44 -3 lines
Fixed some comments. Fixed the advanced-clasess and feature-types methods.
Wed Oct 4 16:03:35 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.7: +11 -2 lines
Added the capability to de-select genomes selected in another gene menu.
Tue Oct 3 11:05:45 2006 UTC (12 years, 11 months ago) by parrello
Upgraded to allow specification of multiple property values per property.
Mon Oct 2 07:31:46 2006 UTC (12 years, 11 months ago) by parrello
Fixed GBrowse URL method.
Mon Oct 2 06:35:31 2006 UTC (12 years, 11 months ago) by parrello
Mon Oct 2 03:15:37 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.3: +73 -47 lines
Moved the show aliases option to the FeatureQuery object.
Changes since 1.2: +420 -50 lines
Changes since 1.1: +215 -26 lines
