--- SearchHelper.pm 2006/10/02 06:35:31 1.5 +++ SearchHelper.pm 2008/04/29 20:52:05 1.40 @@ -10,15 +10,16 @@ use File::Path; use File::stat; use LWP::UserAgent; - use Time::HiRes 'gettimeofday'; + use FIGRules; use Sprout; use SFXlate; use FIGRules; use HTML; use BasicLocation; - use FeatureQuery; use URI::Escape; use PageBuilder; + use AliasAnalysis; + use FreezeThaw qw(freeze thaw); =head1 Search Helper Base Class @@ -65,7 +66,8 @@ =item orgs -Reference to a hash mapping genome IDs to organism names. +Reference to a hash mapping genome IDs to organism data. (Used to +improve performance.) =item name @@ -83,11 +85,6 @@ List of the parameters that are used to select multiple genomes. -=item filtered - -TRUE if this is a feature-filtered search, else FALSE. B that this -field is updated by the B object. - =back =head2 Adding a new Search Tool @@ -103,7 +100,8 @@ =item 2 Create a new subclass of this object and implement each of the virtual methods. The -name of the subclass must be CI. +name of the subclass must be CI, where I is the +type of search. =item 3 @@ -113,8 +111,9 @@ =item 4 -In the C script, add a C statement for your search tool -and then put the class name in the C<@advancedClasses> list. +If your search produces a result for which a helper does not exist, you +must create a new subclass of B. Its name must be +CI, where I is the type of result. =back @@ -150,42 +149,25 @@ Several helper methods are provided for particular purposes. -=over 4 - -=item 1 - L generates a control for selecting one or more genomes. Use L to retrieve all the genomes passed in for a specified parameter name. Note that as an assist to people working with GET-style links, if no genomes are specified and the incoming request style is GET, all genomes will be returned. -=item 2 - -L formats several rows of controls for filtering features. -When you start building the code for the L method, you can use a -B object to automatically filter each genome's features using -the values from the filter controls. - -=item 3 - L allows you to queue JavaScript statements for execution after the form is fully generated. If you are using very complicated form controls, the L method allows you to perform JavaScript initialization. The L control uses this facility to display a list of the pre-selected genomes. -=back - Finally, when generating the code for your controls, be sure to use any incoming query parameters as default values so that the search request is persistent. =head3 Finding Search Results -The L method is used to create the search results. For a search that -wants to return features (which is most of them), the basic code structure -would work as follows. It is assumed that the L method -has been used to create feature filtering parameters. +The L method is used to create the search results. The basic code +structure would work as follows. sub Find { my ($self) = @_; @@ -198,39 +180,50 @@ ... validate the parameters ... if (... invalid parameters...) { $self->SetMessage(...appropriate message...); - } elsif (FeatureQuery::Valid($self)) { + } else { + # Determine the result type. + my $rhelp = SearchHelper::GetHelper($self, RH => $resultType); + # Specify the columns. + $self->DefaultColumns($rhelp); + # You may want to add extra columns. $name is the column name and + # $loc is its location. The other parameters take their names from the + # corresponding column methods. + $rhelp->AddExtraColumn($name => $loc, style => $style, download => $flag, + title => $title); + # Some searches require optional columns that are configured by the + # user or by the search query itself. There are some special methods + # for this in the result helpers, but there's also the direct approach + # shown below. + $rhelp->AddOptionalColumn($name => $loc); # Initialize the session file. - $self->OpenSession(); + $self->OpenSession($rhelp); # Initialize the result counter. $retVal = 0; - ... get a list of genomes ... - for my $genomeID (... each genome ...) { - my $fq = FeatureQuery->new($self, $genomeID); - while (my $feature = $fq->Fetch()) { - ... examine the feature ... - if (... we want to keep it ...) { - $self->PutFeature($fq); - $retVal++; - } - } + ... set up to loop through the results ... + while (...more results...) { + ...compute extra columns and call PutExtraColumns... + $rhelp->PutData($sortKey, $objectID, $record); + $retVal++; } + # Close the session file. + $self->CloseSession(); } - # Close the session file. - $self->CloseSession(); # Return the result count. return $retVal; } A Find method is of course much more complicated than generating a form, and there -are variations on the above them. For example, you could eschew feature filtering -entirely in favor of your own custom filtering, you could include extra columns -in the output, or you could search for something that's not a feature at all. The -above code is just a loose framework. +are variations on the above theme. + +In addition to the finding and filtering, it is necessary to send status messages +to the output so that the user does not get bored waiting for results. The L +method performs this function. The single parameter should be text to be +output to the browser. In general, you'll invoke it as follows. -If you wish to add your own extra columns to the output, use the B -method of the feature query object. + $self->PrintLine("...my message text...
"); - $fq->AddExtraColumns(score => $sc); +The break tag is optional. When the Find method gets control, a paragraph will +have been started so that everything is XHTML-compliant. The L method must return C if the search parameters are invalid. If this is the case, then a message describing the problem should be passed to the framework @@ -241,18 +234,20 @@ # This counter is used to insure every form on the page has a unique name. my $formCount = 0; +# This counter is used to generate unique DIV IDs. +my $divCount = 0; =head2 Public Methods =head3 new -C<< my $shelp = SearchHelper->new($query); >> + my $shelp = SearchHelper->new($cgi); Construct a new SearchHelper object. =over 4 -=item query +=item cgi The CGI query object for the current script. @@ -262,30 +257,44 @@ sub new { # Get the parameters. - my ($class, $query) = @_; + my ($class, $cgi) = @_; # Check for a session ID. - my $session_id = $query->param("SessionID"); + my $session_id = $cgi->param("SessionID"); my $type = "old"; if (! $session_id) { + Trace("No session ID found.") if T(3); # Here we're starting a new session. We create the session ID and # store it in the query object. - $session_id = NewSessionID(); + $session_id = FIGRules::NewSessionID(); + Trace("New session ID is $session_id.") if T(3); $type = "new"; - $query->param(-name => 'SessionID', -value => $session_id); + $cgi->param(-name => 'SessionID', -value => $session_id); + } else { + Trace("Session ID is $session_id.") if T(3); } + Trace("Computing subclass.") if T(3); # Compute the subclass name. - $class =~ /SH(.+)$/; - my $subClass = $1; + my $subClass; + if ($class =~ /SH(.+)$/) { + # Here we have a real search class. + $subClass = $1; + } else { + # Here we have a bare class. The bare class cannot search, but it can + # process search results. + $subClass = 'SearchHelper'; + } + Trace("Subclass name is $subClass.") if T(3); # Insure everybody knows we're in Sprout mode. - $query->param(-name => 'SPROUT', -value => 1); + $cgi->param(-name => 'SPROUT', -value => 1); # Generate the form name. my $formName = "$class$formCount"; $formCount++; + Trace("Creating helper.") if T(3); # Create the shelp object. It contains the query object (with the session ID) # as well as an indicator as to whether or not the session is new, plus the # class name and a placeholder for the Sprout object. my $retVal = { - query => $query, + query => $cgi, type => $type, class => $subClass, sprout => undef, @@ -294,7 +303,6 @@ scriptQueue => [], genomeList => undef, genomeParms => [], - filtered => 0, }; # Bless and return it. bless $retVal, $class; @@ -303,7 +311,7 @@ =head3 Q -C<< my $query = $shelp->Q(); >> + my $query = $shelp->Q(); Return the CGI query object. @@ -316,9 +324,11 @@ return $self->{query}; } + + =head3 DB -C<< my $sprout = $shelp->DB(); >> + my $sprout = $shelp->DB(); Return the Sprout database object. @@ -339,7 +349,7 @@ =head3 IsNew -C<< my $flag = $shelp->IsNew(); >> + my $flag = $shelp->IsNew(); Return TRUE if this is a new session, FALSE if this is an old session. An old session already has search results ready to process. @@ -355,7 +365,7 @@ =head3 ID -C<< my $sessionID = $shelp->ID(); >> + my $sessionID = $shelp->ID(); Return the current session ID. @@ -370,7 +380,7 @@ =head3 FormName -C<< my $name = $shelp->FormName(); >> + my $name = $shelp->FormName(); Return the name of the form this helper object will generate. @@ -385,7 +395,7 @@ =head3 QueueFormScript -C<< $shelp->QueueFormScript($statement); >> + $shelp->QueueFormScript($statement); Add the specified statement to the queue of JavaScript statements that are to be executed when the form has been fully defined. This is necessary because until @@ -420,7 +430,7 @@ =head3 FormStart -C<< my $html = $shelp->FormStart($title); >> + my $html = $shelp->FormStart($title); Return the initial section of a form designed to perform another search of the same type. The form header is included along with hidden fields to persist the @@ -447,23 +457,18 @@ my ($self, $title) = @_; # Get the CGI object. my $cgi = $self->Q(); - # Start the form. + # Start the form. Note we use the override option on the Class value, in + # case the Advanced button was used. my $retVal = "
\n" . $cgi->start_form(-method => 'POST', -action => $cgi->url(-relative => 1), -name => $self->FormName()) . $cgi->hidden(-name => 'Class', - -value => $self->{class}) . + -value => $self->{class}, + -override => 1) . $cgi->hidden(-name => 'SPROUT', -value => 1) . - $cgi->h3($title); - # If tracing is on, add it to the form. - if ($cgi->param('Trace')) { - $retVal .= $cgi->hidden(-name => 'Trace', - -value => $cgi->param('Trace')) . - $cgi->hidden(-name => 'TF', - -value => ($cgi->param('TF') ? 1 : 0)); - } + $cgi->h3("$title" . Hint($self->{class}, "Click here for more information.")); # Put in an anchor tag in case there's a table of contents. my $anchorName = $self->FormName(); $retVal .= "\n"; @@ -473,7 +478,7 @@ =head3 FormEnd -C<< my $htmlText = $shelp->FormEnd(); >> + my $htmlText = $shelp->FormEnd(); Return the HTML text for closing a search form. This closes both the C
and C
tags. @@ -505,7 +510,7 @@ =head3 SetMessage -C<< $shelp->SetMessage($msg); >> + $shelp->SetMessage($msg); Store the specified text as the result message. The result message is displayed if an invalid parameter value is specified. @@ -529,7 +534,7 @@ =head3 Message -C<< my $text = $shelp->Message(); >> + my $text = $shelp->Message(); Return the result message. The result message is displayed if an invalid parameter value is specified. @@ -545,23 +550,42 @@ =head3 OpenSession -C<< $shelp->OpenSession(); >> + $shelp->OpenSession($rhelp); + +Set up the session cache file and write out the column headers. +This method should not be called until all the columns have +been configured, including the extra columns. + +=over 4 -Set up to open the session cache file for writing. Note we don't actually -open the file until after we know the column headers. +=item rhelp + +Result helper for formatting the output. This has the column +headers stored in it. + +=back =cut sub OpenSession { # Get the parameters. - my ($self) = @_; - # Denote we have not yet written out the column headers. - $self->{cols} = undef; + my ($self, $rhelp) = @_; + # Insure the result helper is valid. + if (! defined($rhelp)) { + Confess("No result type specified for $self->{class}."); + } elsif(! $rhelp->isa('ResultHelper')) { + Confess("Invalid result type specified for $self->{class}."); + } else { + # Get the column headers and write them out. + my $colHdrs = $rhelp->GetColumnHeaders(); + Trace(scalar(@{$colHdrs}) . " column headers written to output.") if T(3); + $self->WriteColumnHeaders(@{$colHdrs}); + } } =head3 GetCacheFileName -C<< my $fileName = $shelp->GetCacheFileName(); >> + my $fileName = $shelp->GetCacheFileName(); Return the name to be used for this session's cache file. @@ -576,7 +600,7 @@ =head3 GetTempFileName -C<< my $fileName = $shelp->GetTempFileName($type); >> + my $fileName = $shelp->GetTempFileName($type); Return the name to be used for a temporary file of the specified type. The name is computed from the session name with the type as a suffix. @@ -600,89 +624,14 @@ my ($self, $type) = @_; # Compute the file name. Note it gets stuffed in the FIG temporary # directory. - my $retVal = "$FIG_Config::temp/tmp_" . $self->ID() . ".$type"; + my $retVal = FIGRules::GetTempFileName(sessionID => $self->ID(), extension => $type); # Return the result. return $retVal; } -=head3 PutFeature - -C<< $shelp->PutFeature($fquery); >> - -Store a feature in the result cache. This is the workhorse method for most -searches, since the primary data item in the database is features. - -For each feature, there are certain columns that are standard: the feature name, the -GBrowse and protein page links, the functional assignment, and so forth. If additional -columns are required by a particular search subclass, they should be stored in -the feature query object using the B method. For example, the following -code adds columns for essentiality and virulence. - - $fq->AddExtraColumns(essential => $essentialFlag, virulence => $vfactor); - $shelp->PutFeature($fq); - -For correct results, all values should be specified for all extra columns in all calls to -B. (In particular, the column header names are computed on the first -call.) If a column is to be blank for the current feature, its value can be given -as C. - - if (! $essentialFlag) { - $essentialFlag = undef; - } - $fq->AddExtraColumns(essential => $essentialFlag, virulence => $vfactor); - $shelp->PutFeature($fq); - -=over 4 - -=item fquery - -FeatureQuery object containing the current feature data. - -=back - -=cut - -sub PutFeature { - # Get the parameters. - my ($self, $fq) = @_; - # Get the CGI query object. - my $cgi = $self->Q(); - # Get the feature data. - my $record = $fq->Feature(); - my $extraCols = $fq->ExtraCols(); - # Check for a first-call situation. - if (! defined $self->{cols}) { - # Here we need to set up the column information. Start with the defaults. - $self->{cols} = $self->DefaultFeatureColumns(); - # Add the externals if they were requested. - if ($cgi->param('ShowAliases')) { - push @{$self->{cols}}, 'alias'; - } - # Append the extras, sorted by column name. - for my $col (sort keys %{$extraCols}) { - push @{$self->{cols}}, "X=$col"; - } - # Write out the column headers. This also prepares the cache file to receive - # output. - $self->WriteColumnHeaders(map { $self->FeatureColumnTitle($_) } @{$self->{cols}}); - } - # Get the feature ID. - my ($fid) = $record->Value('Feature(id)'); - # Loop through the column headers, producing the desired data. - my @output = (); - for my $colName (@{$self->{cols}}) { - push @output, $self->FeatureColumnValue($colName, $record, $extraCols); - } - # Compute the sort key. The sort key floats NMPDR organism features to the - # top of the return list. - my $key = $self->SortKey($record); - # Write the feature data. - $self->WriteColumnData($key, @output); -} - =head3 WriteColumnHeaders -C<< $shelp->WriteColumnHeaders(@colNames); >> + $shelp->WriteColumnHeaders(@colNames); Write out the column headers for the current search session. The column headers are sent to the cache file, and then the cache is re-opened as a sort pipe and @@ -692,7 +641,8 @@ =item colNames -A list of column names in the desired presentation order. +A list of column names in the desired presentation order. For extra columns, +the column name is the hash supplied as the column definition. =back @@ -704,8 +654,10 @@ # Get the cache file name and open it for output. my $fileName = $self->GetCacheFileName(); my $handle1 = Open(undef, ">$fileName"); + # Freeze the column headers. + my @colHdrs = map { freeze($_) } @colNames; # Write the column headers and close the file. - Tracer::PutLine($handle1, \@colNames); + Tracer::PutLine($handle1, \@colHdrs); close $handle1; # Now open the sort pipe and save the file handle. Note how we append the # sorted data to the column header row already in place. The output will @@ -714,9 +666,41 @@ $self->{fileHandle} = Open(undef, "| sort | cut --fields=2- >>$fileName"); } +=head3 ReadColumnHeaders + + my @colHdrs = $shelp->ReadColumnHeaders($fh); + +Read the column headers from the specified file handle. The column headers are +frozen strings intermixed with frozen hash references. The strings represent +column names defined in the result helper. The hash references represent the +definitions of the extra columns. + +=over 4 + +=item fh + +File handle from which the column headers are to be read. + +=item RETURN + +Returns a list of the column headers pulled from the specified file's first line. + +=back + +=cut + +sub ReadColumnHeaders { + # Get the parameters. + my ($self, $fh) = @_; + # Read and thaw the columns. + my @retVal = map { thaw($_) } Tracer::GetLine($fh); + # Return them to the caller. + return @retVal; +} + =head3 WriteColumnData -C<< $shelp->WriteColumnData($key, @colValues); >> + $shelp->WriteColumnData($key, @colValues); Write a row of column values to the current search session. It is assumed that the session file is already open for output. @@ -740,11 +724,12 @@ my ($self, $key, @colValues) = @_; # Write them to the cache file. Tracer::PutLine($self->{fileHandle}, [$key, @colValues]); + Trace("Column data is " . join("; ", $key, @colValues) . ".") if T(4); } =head3 CloseSession -C<< $shelp->CloseSession(); >> + $shelp->CloseSession(); Close the session file. @@ -756,36 +741,17 @@ # Check for an open session file. if (defined $self->{fileHandle}) { # We found one, so close it. + Trace("Closing session file.") if T(2); close $self->{fileHandle}; + # Tell the user. + my $cgi = $self->Q(); + $self->PrintLine("Output formatting complete.
"); } } -=head3 NewSessionID - -C<< my $id = SearchHelpers::NewSessionID(); >> - -Generate a new session ID for the current user. - -=cut - -sub NewSessionID { - # Declare the return variable. - my $retVal; - # Get a digest encoder. - my $md5 = Digest::MD5->new(); - # Add the PID, the IP, and the time stamp. Note that the time stamp is - # actually two numbers, and we get them both because we're in list - # context. - $md5->add($$, $ENV{REMOTE_ADDR}, $ENV{REMOTE_PORT}, gettimeofday()); - # Hash up all this identifying data. - $retVal = $md5->hexdigest(); - # Return the result. - return $retVal; -} - =head3 OrganismData -C<< my ($orgName, $group) = $shelp->Organism($genomeID); >> + my ($orgName, $group) = $shelp->Organism($genomeID); Return the name and status of the organism corresponding to the specified genome ID. For performance reasons, this information is cached in a special hash table, so we @@ -799,9 +765,9 @@ =item RETURN -Returns a list of two items. The first item in the list is the organism name, +Returns a list of three items. The first item in the list is the organism name, and the second is the name of the NMPDR group, or an empty string if the -organism is not in an NMPDR group. +organism is not in an NMPDR group. The third item is the organism's domain. =back @@ -811,40 +777,33 @@ # Get the parameters. my ($self, $genomeID) = @_; # Declare the return variables. - my ($orgName, $group); + my ($orgName, $group, $domain); # Check the cache. my $cache = $self->{orgs}; if (exists $cache->{$genomeID}) { - ($orgName, $group) = @{$cache->{$genomeID}}; + ($orgName, $group, $domain) = @{$cache->{$genomeID}}; + Trace("Cached organism $genomeID has group \"$group\".") if T(4); } else { # Here we have to use the database. my $sprout = $self->DB(); - my ($genus, $species, $strain, $group) = $sprout->GetEntityValues('Genome', $genomeID, - ['Genome(genus)', 'Genome(species)', - 'Genome(unique-characterization)', - 'Genome(primary-group)']); - # Null out the supporting group. - $group = "" if ($group eq $FIG_Config::otherGroup); - # If the organism does not exist, format an unknown name. - if (! defined($genus)) { - $orgName = "Unknown Genome $genomeID"; - } else { - # It does exist, so format the organism name. - $orgName = "$genus $species"; - if ($strain) { - $orgName .= " $strain"; - } - } - # Save this organism in the cache. - $cache->{$genomeID} = [$orgName, $group]; + my ($genus, $species, $strain, $newGroup, $taxonomy) = $sprout->GetEntityValues('Genome', $genomeID, + ['Genome(genus)', 'Genome(species)', + 'Genome(unique-characterization)', + 'Genome(primary-group)', + 'Genome(taxonomy)']); + # Format and cache the name and display group. + Trace("Caching organism $genomeID with group \"$newGroup\".") if T(4); + ($orgName, $group, $domain) = $self->SaveOrganismData($newGroup, $genomeID, $genus, $species, + $strain, $taxonomy); + Trace("Returning group $group.") if T(4); } # Return the result. - return ($orgName, $group); + return ($orgName, $group, $domain); } =head3 Organism -C<< my $orgName = $shelp->Organism($genomeID); >> + my $orgName = $shelp->Organism($genomeID); Return the name of the relevant organism. The name is computed from the genus, species, and unique characterization. A cache is used to improve performance. @@ -867,102 +826,24 @@ # Get the parameters. my ($self, $genomeID) = @_; # Get the organism data. - my ($retVal, $group) = $self->OrganismData($genomeID); - # Return the result. - return $retVal; -} - -=head3 FeatureGroup - -C<< my $groupName = $shelp->FeatureGroup($fid); >> - -Return the group name for the specified feature. - -=over 4 - -=item fid - -ID of the relevant feature. - -=item RETURN - -Returns the name of the NMPDR group to which the feature belongs, or an empty -string if it is not part of an NMPDR group. - -=back - -=cut - -sub FeatureGroup { - # Get the parameters. - my ($self, $fid) = @_; - # Parse the feature ID to get the genome ID. - my ($genomeID) = FIGRules::ParseFeatureID($fid); - # Get the organism data. - my (undef, $retVal) = $self->OrganismData($genomeID); - # Return the result. - return $retVal; -} - -=head3 FeatureName - -C<< my $fidName = $shelp->FeatureName($fid); >> - -Return the display name of the specified feature. - -=over 4 - -=item fid - -ID of the feature whose name is desired. - -=item RETURN - -A displayable feature name, consisting of the organism name plus some feature -type and location information. - -=back - -=cut - -sub FeatureName { - # Get the parameters. - my ($self, $fid) = @_; - # Declare the return variable - my $retVal; - # Parse the feature ID. - my ($genomeID, $type, $num) = FIGRules::ParseFeatureID($fid); - if (! defined $genomeID) { - # Here the feature ID has an invalid format. - $retVal = "External: $fid"; - } else { - # Here we can get its genome data. - $retVal = $self->Organism($genomeID); - # Append the FIG ID. - $retVal .= " [$fid]"; - } + my ($retVal) = $self->OrganismData($genomeID); # Return the result. return $retVal; } =head3 ComputeFASTA -C<< my $fasta = $shelp->ComputeFASTA($incomingType, $desiredType, $sequence); >> + my $fasta = $shelp->ComputeFASTA($desiredType, $sequence, $flankingWidth); -Parse a sequence input and convert it into a FASTA string of the desired type. Note -that it is possible to convert a DNA sequence into a protein sequence, but the reverse -is not possible. +Parse a sequence input and convert it into a FASTA string of the desired type with +the desired flanking width. =over 4 -=item incomingType - -C if this is a DNA sequence, C if this is a protein sequence. - =item desiredType -C to return a DNA sequence, C to return a protein sequence. If the -I<$incomingType> is C and this value is C, an error will be thrown. +C to return a DNA sequence, C to return a protein sequence, C +to return a DNA search pattern, C to return a protein search pattern. =item sequence @@ -972,6 +853,13 @@ if the input does not begin with a greater-than sign (FASTA label line), a default label line will be provided. +=item flankingWidth + +If the DNA FASTA of a feature is desired, the number of base pairs to either side of the +feature that should be included. Currently we can't do this for Proteins because the +protein translation of a feature doesn't always match the DNA and is taken directly +from the database. + =item RETURN Returns a string in FASTA format representing the content of the desired sequence with @@ -984,78 +872,279 @@ sub ComputeFASTA { # Get the parameters. - my ($self, $incomingType, $desiredType, $sequence) = @_; + my ($self, $desiredType, $sequence, $flankingWidth) = @_; # Declare the return variable. If an error occurs, it will remain undefined. my $retVal; + # This variable will be cleared if an error is detected. + my $okFlag = 1; # Create variables to hold the FASTA label and data. my ($fastaLabel, $fastaData); - # Check for a feature specification. + Trace("FASTA desired type is $desiredType.") if T(4); + # Check for a feature specification. The smoking gun for that is a vertical bar. if ($sequence =~ /^\s*(\w+\|\S+)\s*$/) { # Here we have a feature ID in $1. We'll need the Sprout object to process # it. my $fid = $1; + Trace("Feature ID for fasta is $fid.") if T(3); my $sprout = $self->DB(); # Get the FIG ID. Note that we only use the first feature found. We are not # supposed to have redundant aliases, though we may have an ID that doesn't # exist. my ($figID) = $sprout->FeaturesByAlias($fid); if (! $figID) { - $self->SetMessage("No feature found with the ID \"$fid\"."); + $self->SetMessage("No gene found with the ID \"$fid\"."); + $okFlag = 0; } else { - # Set the FASTA label. - my $fastaLabel = $fid; + # Set the FASTA label. The ID is the first favored alias. + my $favored = $self->Q()->param('FavoredAlias') || 'fig'; + my $favorLen = length $favored; + ($fastaLabel) = grep { substr($_, 0, $favorLen) eq $favored } $sprout->FeatureAliases($fid); + if (! $fastaLabel) { + # In an emergency, fall back to the original ID. + $fastaLabel = $fid; + } # Now proceed according to the sequence type. - if ($desiredType =~ /prot/i) { + if ($desiredType =~ /prot/) { # We want protein, so get the translation. $fastaData = $sprout->FeatureTranslation($figID); - } else { - # We want DNA, so get the DNA sequence. This is a two-step process. + Trace(length $fastaData . " characters returned for translation of $fastaLabel.") if T(3); + } elsif ($desiredType =~ /dna/) { + # We want DNA, so get the DNA sequence. This is a two-step process. First, we get the + # locations. my @locList = $sprout->FeatureLocation($figID); - $fastaData = $sprout->DNASeq(\@locList); + if ($flankingWidth > 0) { + # Here we need to add flanking data. Convert the locations to a list + # of location objects. + my @locObjects = map { BasicLocation->new($_) } @locList; + # Initialize the return variable. We will put the DNA in here segment by segment. + $fastaData = ""; + # Now we widen each location by the flanking width and stash the results. This + # requires getting the contig length for each contig so we don't fall off the end. + for my $locObject (@locObjects) { + Trace("Current location is " . $locObject->String . ".") if T(4); + # Remember the current start and length. + my ($start, $len) = ($locObject->Left, $locObject->Length); + # Get the contig length. + my $contigLen = $sprout->ContigLength($locObject->Contig); + # Widen the location and get its DNA. + $locObject->Widen($flankingWidth, $contigLen); + my $fastaSegment = $sprout->DNASeq([$locObject->String()]); + # Now we need to do some case changing. The main DNA is upper case and + # the flanking DNA is lower case. + my $leftFlank = $start - $locObject->Left; + my $rightFlank = $leftFlank + $len; + Trace("Wide location is " . $locObject->String . ". Flanks are $leftFlank and $rightFlank. Contig len is $contigLen.") if T(4); + my $fancyFastaSegment = lc(substr($fastaSegment, 0, $leftFlank)) . + uc(substr($fastaSegment, $leftFlank, $rightFlank - $leftFlank)) . + lc(substr($fastaSegment, $rightFlank)); + $fastaData .= $fancyFastaSegment; + } + } else { + # Here we have just the raw sequence. + $fastaData = $sprout->DNASeq(\@locList); + } + Trace((length $fastaData) . " characters returned for DNA of $fastaLabel.") if T(3); } } - } elsif ($incomingType =~ /prot/ && $desiredType =~ /dna/) { - # Here we're being asked to do an impossible conversion. - $self->SetMessage("Cannot convert a protein sequence to DNA."); } else { + Trace("Analyzing FASTA sequence.") if T(4); # Here we are expecting a FASTA. We need to see if there's a label. - if ($sequence =~ /^>\s*(\S.*)\s*\n(.+)$/) { + if ($sequence =~ /^>[\n\s]*(\S[^\n]*)\n(.+)$/s) { + Trace("Label \"$1\" found in match to sequence:\n$sequence") if T(4); # Here we have a label, so we split it from the data. $fastaLabel = $1; $fastaData = $2; } else { + Trace("No label found in match to sequence:\n$sequence") if T(4); # Here we have no label, so we create one and use the entire sequence # as data. - $fastaLabel = "User-specified $incomingType sequence"; + $fastaLabel = "$desiredType sequence specified by user"; $fastaData = $sequence; } - # The next step is to clean the junk out of the sequence. - $fastaData =~ s/\n//g; - $fastaData =~ s/\s+//g; - # Finally, if the user wants to convert to protein, we do it here. Note that - # we've already prevented a conversion from protein to DNA. - if ($incomingType ne $desiredType) { - $fastaData = Sprout::Protein($fastaData); - } - } - # At this point, either "$fastaLabel" and "$fastaData" have values or an error is - # in progress. - if (defined $fastaLabel) { - # We need to format the sequence into 60-byte chunks. We use the infamous - # grep-split trick. The split, because of the presence of the parentheses, - # includes the matched delimiters in the output list. The grep strips out - # the empty list items that appear between the so-called delimiters, since - # the delimiters are what we want. - my @chunks = grep { $_ } split /(.{1,60})/, $fastaData; - my $retVal = join("\n", ">$fastaLabel", @chunks, ""); + # If we are not doing a pattern search, we need to clean the junk out of the sequence. + if ($desiredType !~ /pattern/i) { + $fastaData =~ s/\n//g; + $fastaData =~ s/\s+//g; + } + # Finally, verify that it's DNA if we're doing DNA stuff. + if ($desiredType eq 'dna' && $fastaData =~ /[^agctxn-]/i) { + $self->SetMessage("Invalid characters detected. Is the input really a DNA sequence?"); + $okFlag = 0; + } + } + Trace("FASTA data sequence: $fastaData") if T(4); + # Only proceed if no error was detected. + if ($okFlag) { + if ($desiredType =~ /pattern/i) { + # For a scan, there is no label and no breakup. + $retVal = $fastaData; + } else { + # We need to format the sequence into 60-byte chunks. We use the infamous + # grep-split trick. The split, because of the presence of the parentheses, + # includes the matched delimiters in the output list. The grep strips out + # the empty list items that appear between the so-called delimiters, since + # the delimiters are what we want. + my @chunks = grep { $_ } split /(.{1,60})/, $fastaData; + $retVal = join("\n", ">$fastaLabel", @chunks, ""); + } } # Return the result. return $retVal; } +=head3 SubsystemTree + + my $tree = SearchHelper::SubsystemTree($sprout, %options); + +This method creates a subsystem selection tree suitable for passing to +L. Each leaf node in the tree will have a link to the +subsystem display page. In addition, each node can have a radio button. The +radio button alue is either CI, where I is +a classification string, or CI, where I is a subsystem ID. +Thus, it can either be used to filter by a group of related subsystems or a +single subsystem. + +=over 4 + +=item sprout + +Sprout database object used to get the list of subsystems. + +=item options + +Hash containing options for building the tree. + +=item RETURN + +Returns a reference to a tree list suitable for passing to L. + +=back + +The supported options are as follows. + +=over 4 + +=item radio + +TRUE if the tree should be configured for radio buttons. The default is FALSE. + +=item links + +TRUE if the tree should be configured for links. The default is TRUE. + +=back + +=cut + +sub SubsystemTree { + # Get the parameters. + my ($sprout, %options) = @_; + # Process the options. + my $optionThing = Tracer::GetOptions({ radio => 0, links => 1 }, \%options); + # Read in the subsystems. + my @subs = $sprout->GetAll(['Subsystem'], "ORDER BY Subsystem(classification), Subsystem(id)", [], + ['Subsystem(classification)', 'Subsystem(id)']); + # Put any unclassified subsystems at the end. They will always be at the beginning, so if one + # is at the end, ALL subsystems are unclassified and we don't bother. + if ($#subs >= 0 && $subs[$#subs]->[0] ne '') { + while ($subs[0]->[0] eq '') { + my $classLess = shift @subs; + push @subs, $classLess; + } + } + # Declare the return variable. + my @retVal = (); + # Each element in @subs represents a leaf node, so as we loop through it we will be + # producing one leaf node at a time. The leaf node is represented as a 2-tuple. The + # first element is a semi-colon-delimited list of the classifications for the + # subsystem. There will be a stack of currently-active classifications, which we will + # compare to the incoming classifications from the end backward. A new classification + # requires starting a new branch. A different classification requires closing an old + # branch and starting a new one. Each classification in the stack will also contain + # that classification's current branch. We'll add a fake classification at the + # beginning that we can use to represent the tree as a whole. + my $rootName = ''; + # Create the classification stack. Note the stack is a pair of parallel lists, + # one containing names and the other containing content. + my @stackNames = ($rootName); + my @stackContents = (\@retVal); + # Add a null entry at the end of the subsystem list to force an unrolling. + push @subs, ['', undef]; + # Loop through the subsystems. + for my $sub (@subs) { + # Pull out the classification list and the subsystem ID. + my ($classString, $id) = @{$sub}; + Trace("Processing class \"$classString\" and subsystem $id.") if T(4); + # Convert the classification string to a list with the root classification in + # the front. + my @classList = ($rootName, split($FIG_Config::splitter, $classString)); + # Find the leftmost point at which the class list differs from the stack. + my $matchPoint = 0; + while ($matchPoint <= $#stackNames && $matchPoint <= $#classList && + $stackNames[$matchPoint] eq $classList[$matchPoint]) { + $matchPoint++; + } + Trace("Match point is $matchPoint. Stack length is " . scalar(@stackNames) . + ". Class List length is " . scalar(@classList) . ".") if T(4); + # Unroll the stack to the matchpoint. + while ($#stackNames >= $matchPoint) { + my $popped = pop @stackNames; + pop @stackContents; + Trace("\"$popped\" popped from stack.") if T(4); + } + # Start branches for any new classifications. + while ($#stackNames < $#classList) { + # The branch for a new classification contains its radio button + # data and then a list of children. So, at this point, if radio buttons + # are desired, we put them into the content. + my $newLevel = scalar(@stackNames); + my @newClassContent = (); + if ($optionThing->{radio}) { + my $newClassString = join($FIG_Config::splitter, @classList[1..$newLevel]); + push @newClassContent, { value => "classification=$newClassString%" }; + } + # The new classification node is appended to its parent's content + # and then pushed onto the stack. First, we need the node name. + my $nodeName = $classList[$newLevel]; + # Add the classification to its parent. This makes it part of the + # tree we'll be returning to the user. + push @{$stackContents[$#stackNames]}, $nodeName, \@newClassContent; + # Push the classification onto the stack. + push @stackContents, \@newClassContent; + push @stackNames, $nodeName; + Trace("\"$nodeName\" pushed onto stack.") if T(4); + } + # Now the stack contains all our parent branches. We add the subsystem to + # the branch at the top of the stack, but only if it's NOT the dummy node. + if (defined $id) { + # Compute the node name from the ID. + my $nodeName = $id; + $nodeName =~ s/_/ /g; + # Create the node's leaf hash. This depends on the value of the radio + # and link options. + my $nodeContent = {}; + if ($optionThing->{links}) { + # Compute the link value. + my $linkable = uri_escape($id); + $nodeContent->{link} = "../FIG/seedviewer.cgi?page=Subsystems;subsystem=$linkable"; + } + if ($optionThing->{radio}) { + # Compute the radio value. + $nodeContent->{value} = "id=$id"; + } + # Push the node into its parent branch. + Trace("\"$nodeName\" added to node list.") if T(4); + push @{$stackContents[$#stackNames]}, $nodeName, $nodeContent; + } + } + # Return the result. + return \@retVal; +} + + =head3 NmpdrGenomeMenu -C<< my $htmlText = $shelp->NmpdrGenomeMenu($menuName, $multiple, \@selected, $rows); >> + my $htmlText = $shelp->NmpdrGenomeMenu($menuName, $multiple, \@selected, $rows); This method creates a hierarchical HTML menu for NMPDR genomes organized by category. The category indicates the low-level NMPDR group. Organizing the genomes in this way makes it @@ -1082,6 +1171,13 @@ Number of rows to display. If omitted, the default is 1 for a single-select list and 10 for a multi-select list. +=item crossMenu (optional) + +If specified, is presumed to be the name of another genome menu whose contents +are to be mutually exclusive with the contents of this menu. As a result, instead +of the standard onChange event, the onChange event will deselect any entries in +the other menu. + =item RETURN Returns the HTML text to generate a C"; - my @lines = ($select); + my @lines = (""; # Check for multiple selection. if ($multiple) { - # Since multi-select is on, we set up some buttons to set and clear selections. - push @lines, "
"; - push @lines, ""; - push @lines, ""; - push @lines, ""; - push @lines, ""; - # Now add the search box. This allows the user to type text and have all genomes containing + # Multi-select is on, so we need to add some selection helpers. First is + # the search box. This allows the user to type text and have all genomes containing # the text selected automatically. my $searchThingName = "${menuName}_SearchThing"; - push @lines, "
Select genomes containing  " . - ""; + push @lines, "
" . + " " . + "" . Hint("Genome Control", + "Enter a genome number, then click the button to the left " . + "in order to select the genome with that number. " . + "Enter a genus, species, or strain and click the " . + "button to select all genomes with that genus, species, " . + "or strain name."); + # Next are the buttons to set and clear selections. + push @lines, "
"; + push @lines, ""; + push @lines, ""; + push @lines, ""; + # push @lines, ""; # Add the status display, too. push @lines, "
"; # Queue to update the status display when the form loads. We need to modify the show statement @@ -1221,7 +1362,7 @@ =head3 PropertyMenu -C<< my $htmlText = $shelp->PropertyMenu($menuName, $selected, $force); >> + my $htmlText = $shelp->PropertyMenu($menuName, $selected, $force); Generate a property name dropdown menu. @@ -1271,7 +1412,7 @@ =head3 MakeTable -C<< my $htmlText = $shelp->MakeTable(\@rows); >> + my $htmlText = $shelp->MakeTable(\@rows); Create a table from a group of table rows. The table rows must be fully pre-formatted: in other words, each must have the TR and TD tags included. @@ -1287,8 +1428,8 @@ =item rows Reference to a list of table rows. Each table row must be in HTML form with all -the TR and TD tags set up. The first TD or TH tag in each row will be modified to -set the width. Everything else will be left as is. +the TR and TD tags set up. The first TD or TH tag in the first non-colspanned row +will be modified to set the width. Everything else will be left as is. =item RETURN @@ -1303,11 +1444,26 @@ my ($self, $rows) = @_; # Get the CGI object. my $cgi = $self->Q(); - # Fix the widths on the first column. Note that we eschew the use of the "g" + # The first column of the first row must have its width fixed. + # This flag will be set to FALSE when that happens. + my $needWidth = 1; # modifier becase we only want to change the first tag. Also, if a width # is already specified on the first column bad things will happen. for my $row (@{$rows}) { - $row =~ s/(]+)>/i) { + # Here we have a first cell and its tag parameters are in $2. + my $elements = $2; + if ($elements !~ /colspan/i) { + Trace("No colspan tag found in element \'$elements\'.") if T(3); + # Here there's no colspan, so we plug in the width. We + # eschew the "g" modifier on the substitution because we + # only want to update the first cell. + $row =~ s/(<(td|th))/$1 width="150"/i; + # Denote we don't need this any more. + $needWidth = 0; + } + } } # Create the table. my $retVal = $cgi->table({border => 2, cellspacing => 2, @@ -1319,135 +1475,59 @@ =head3 SubmitRow -C<< my $htmlText = $shelp->SubmitRow(); >> + my $htmlText = $shelp->SubmitRow($caption); Returns the HTML text for the row containing the page size control and the submit button. All searches should have this row somewhere near the top of the form. -=cut - -sub SubmitRow { - # Get the parameters. - my ($self) = @_; - my $cgi = $self->Q(); - # Get the current page size. - my $pageSize = $cgi->param('PageSize'); - # Get the incoming external-link flag. - my $aliases = ($cgi->param('ShowAliases') ? 1 : 0); - # Create the row. - my $retVal = $cgi->Tr($cgi->td("Results/Page"), - $cgi->td($cgi->popup_menu(-name => 'PageSize', - -values => [10, 25, 45, 100, 1000], - -default => $pageSize) . " " . - $cgi->checkbox(-name => 'ShowURL', - -value => 1, - -label => 'Show URL')), - $cgi->td($cgi->submit(-class => 'goButton', - -name => 'Search', - -value => 'Go'))); - # Return the result. - return $retVal; -} - -=head3 FeatureFilterRows - -C<< my $htmlText = $shelp->FeatureFilterRows(); >> - -This method creates table rows that can be used to filter features. There are -two rows returned, and the values can be used to select features by genome -using the B object. - -=cut - -sub FeatureFilterRows { - # Get the parameters. - my ($self) = @_; - # Return the result. - return FeatureQuery::FilterRows($self); -} - -=head3 GBrowseFeatureURL - -C<< my $url = SearchHelper::GBrowseFeatureURL($sprout, $feat); >> - -Compute the URL required to pull up a Gbrowse page for the the specified feature. -In order to do this, we need to pull out the ID of the feature's Genome, its -contig ID, and some rough starting and stopping offsets. - =over 4 -=item sprout - -Sprout object for accessing the database. - -=item feat +=item caption (optional) -ID of the feature whose Gbrowse URL is desired. +Caption to be put on the search button. The default is C. =item RETURN -Returns a GET-style URL for the Gbrowse CGI, with parameters specifying the genome -ID, contig ID, starting offset, and stopping offset. +Returns a table row containing the controls for submitting the search +and tuning the results. =back =cut -sub GBrowseFeatureURL { +sub SubmitRow { # Get the parameters. - my ($sprout, $feat) = @_; - # Declare the return variable. - my $retVal; - # Compute the genome ID. - my ($genomeID) = FIGRules::ParseFeatureID($feat); - # Only proceed if the feature ID produces a valid genome. - if ($genomeID) { - # Get the feature location string. - my $loc = $sprout->FeatureLocation($feat); - # Compute the contig, start, and stop points. - my($start, $stop, $contig) = BasicLocation::Parse($loc); - Trace("Start and stop are ($start,$stop) on contig $contig.") if T(3); - # Now we need to do some goofiness to insure that the location is not too - # big and that we get some surrounding stuff. - my $mid = int(($start + $stop) / 2); - my $chunk_len = 20000; - my $max_feature = 40000; - my $feat_len = abs($stop - $start); - if ($feat_len > $chunk_len) { - if ($feat_len > $max_feature) { - $chunk_len = $max_feature; - } else { - $chunk_len = $feat_len + 100; - } - } - my($show_start, $show_stop); - if ($chunk_len == $max_feature) { - $show_start = $start - 300; - } else { - $show_start = $mid - int($chunk_len / 2); - } - if ($show_start < 1) { - $show_start = 1; - } - $show_stop = $show_start + $chunk_len - 1; - my $clen = $sprout->ContigLength($contig); - if ($show_stop > $clen) { - $show_stop = $clen; - } - my $seg_id = $contig; - $seg_id =~ s/:/--/g; - Trace("Show limits are ($show_start,$show_stop) in genome $genomeID with ref $seg_id.") if T(3); - # Assemble all the pieces. - $retVal = "gbrowse.cgi/GB_$genomeID?ref=$seg_id&start=$show_start&stop=$show_stop"; - } + my ($self, $caption) = @_; + my $cgi = $self->Q(); + # Compute the button caption. + my $realCaption = (defined $caption ? $caption : 'Go'); + # Get the current page size. + my $pageSize = $cgi->param('PageSize'); + # Get the current feature ID type. + my $aliasType = $self->GetPreferredAliasType(); + # Create the rows. + my $retVal = $cgi->Tr($cgi->td("Identifier Type "), + $cgi->td({ colspan => 2 }, + $cgi->popup_menu(-name => 'AliasType', + -values => ['FIG', AliasAnalysis::AliasTypes() ], + -default => $aliasType) . + Hint("Identifier Type", "Specify how you want gene names to be displayed."))) . + "\n" . + $cgi->Tr($cgi->td("Results/Page"), + $cgi->td($cgi->popup_menu(-name => 'PageSize', + -values => [10, 25, 50, 100, 1000], + -default => $pageSize)), + $cgi->td($cgi->submit(-class => 'goButton', + -name => 'Search', + -value => $realCaption))); # Return the result. return $retVal; } =head3 GetGenomes -C<< my @genomeList = $shelp->GetGenomes($parmName); >> + my @genomeList = $shelp->GetGenomes($parmName); Return the list of genomes specified by the specified CGI query parameter. If the request method is POST, then the list of genome IDs is returned @@ -1491,13 +1571,13 @@ =head3 GetHelpText -C<< my $htmlText = $shelp->GetHelpText(); >> + my $htmlText = $shelp->GetHelpText(); Get the help text for this search. The help text is stored in files on the template server. The help text for a specific search is taken from a file named CIC<.inc> in the template directory C<$FIG_Config::template_url>. There are also three standard help files: C describes the -feature filtering performed by the B object, C +feature filtering performed by the B object, C describes how to use a multiple-selection genome control, and C describes the standard controls for a search, such as page size, URL display, and external alias display. @@ -1532,7 +1612,7 @@ =head3 ComputeSearchURL -C<< my $url = $shelp->ComputeSearchURL(); >> + my $url = $shelp->ComputeSearchURL(%overrides); Compute the GET-style URL for the current search. In order for this to work, there must be a copy of the search form on the current page. This will always be the @@ -1542,11 +1622,25 @@ main complication is that if the user specified all genomes, we'll want to remove the parameter entirely from a get-style URL. +=over 4 + +=item overrides + +Hash containing override values for the parameters, where the parameter name is +the key and the parameter value is the override value. If the override value is +C, the parameter will be deleted from the result. + +=item RETURN + +Returns a GET-style URL for invoking the search with the specified overrides. + +=back + =cut sub ComputeSearchURL { # Get the parameters. - my ($self) = @_; + my ($self, %overrides) = @_; # Get the database and CGI query object. my $cgi = $self->Q(); my $sprout = $self->DB(); @@ -1573,21 +1667,7 @@ # a singleton list, but that's okay. my @values = split (/\0/, $parms{$parmKey}); # Check for special cases. - if ($parmKey eq 'featureTypes') { - # Here we need to see if the user wants all the feature types. If he - # does, we erase all the values so that the parameter is not output. - my %valueCheck = map { $_ => 1 } @values; - my @list = FeatureQuery::AllFeatureTypes(); - my $okFlag = 1; - for (my $i = 0; $okFlag && $i <= $#list; $i++) { - if (! $valueCheck{$list[$i]}) { - $okFlag = 0; - } - } - if ($okFlag) { - @values = (); - } - } elsif (grep { $_ eq $parmKey } qw(SessionID ResultCount Page PageSize Trace TF ShowURL)) { + if (grep { $_ eq $parmKey } qw(SessionID ResultCount Page PageSize Trace TF)) { # These are bookkeeping parameters we don't need to start a search. @values = (); } elsif ($parmKey =~ /_SearchThing$/) { @@ -1601,340 +1681,823 @@ if ($allFlag) { @values = (); } + } elsif (exists $overrides{$parmKey}) { + # Here the value is being overridden, so we skip it for now. + @values = (); } # If we still have values, create the URL parameters. if (@values) { push @urlList, map { "$parmKey=" . uri_escape($_) } @values; } } + # Now do the overrides. + for my $overKey (keys %overrides) { + # Only use this override if it's not a delete marker. + if (defined $overrides{$overKey}) { + push @urlList, "$overKey=" . uri_escape($overrides{$overKey}); + } + } # Add the parameters to the URL. $retVal .= "?" . join(";", @urlList); # Return the result. return $retVal; } -=head3 GetRunTimeValue +=head3 AdvancedClassList + + my @classes = SearchHelper::AdvancedClassList(); + +Return a list of advanced class names. This list is used to generate the directory +of available searches on the search page. + +We do a file search to accomplish this, but to pull it off we need to look at %INC. + +=cut + +sub AdvancedClassList { + # Determine the search helper module directory. + my $libDirectory = $INC{'SearchHelper.pm'}; + $libDirectory =~ s/SearchHelper\.pm//; + # Read it, keeping only the helper modules. + my @modules = grep { /^SH\w+\.pm/ } Tracer::OpenDir($libDirectory, 0); + # Convert the file names to search types. + my @retVal = map { $_ =~ /^SH(\w+)\.pm/; $1 } @modules; + # Return the result in alphabetical order. + return sort @retVal; +} + +=head3 SelectionTree + + my $htmlText = SearchHelper::SelectionTree($cgi, \%tree, %options); + +Display a selection tree. -C<< my $htmlText = $shelp->GetRunTimeValue($text); >> +This method creates the HTML for a tree selection control. The tree is implemented as a set of +nested HTML unordered lists. Each selectable element of the tree will contain a radio button. In +addition, some of the tree nodes can contain hyperlinks. -Compute a run-time column value. +The tree itself is passed in as a multi-level list containing node names followed by +contents. Each content element is a reference to a similar list. The first element of +each list may be a hash reference. If so, it should contain one or both of the following +keys. =over 4 -=item text +=item link + +The navigation URL to be popped up if the user clicks on the node name. + +=item value + +The form value to be returned if the user selects the tree node. + +=back + +The presence of a C key indicates the node name will be hyperlinked. The presence of +a C key indicates the node name will have a radio button. If a node has no children, +you may pass it a hash reference instead of a list reference. + +The following example shows the hash for a three-level tree with links on the second level and +radio buttons on the third. + + [ Objects => [ + Entities => [ + {link => "../docs/WhatIsAnEntity.html"}, + Genome => {value => 'GenomeData'}, + Feature => {value => 'FeatureData'}, + Contig => {value => 'ContigData'}, + ], + Relationships => [ + {link => "../docs/WhatIsARelationShip.html"}, + HasFeature => {value => 'GenomeToFeature'}, + IsOnContig => {value => 'FeatureToContig'}, + ] + ] + ] + +Note how each leaf of the tree has a hash reference for its value, while the branch nodes +all have list references. + +This next example shows how to set up a taxonomy selection field. The value returned +by the tree control will be the taxonomy string for the selected node ready for use +in a LIKE-style SQL filter. Only the single branch ending in campylobacter is shown for +reasons of space. + + [ All => [ + {value => "%"}, + Bacteria => [ + {value => "Bacteria%"}, + Proteobacteria => [ + {value => "Bacteria; Proteobacteria%"}, + Epsilonproteobacteria => [ + {value => "Bacteria; Proteobacteria;Epsilonproteobacteria%"}, + Campylobacterales => [ + {value => "Bacteria; Proteobacteria; Epsilonproteobacteria; Campylobacterales%"}, + Campylobacteraceae => + {value => "Bacteria; Proteobacteria; Epsilonproteobacteria; Campylobacterales; Campylobacteraceae%"}, + ... + ] + ... + ] + ... + ] + ... + ] + ... + ] + ] + + +This method of tree storage allows the caller to control the order in which the tree nodes +are displayed and to completely control value selection and use of hyperlinks. It is, however +a bit complicated. Eventually, tree-building classes will be provided to simplify things. + +The parameters to this method are as follows. + +=over 4 + +=item cgi + +CGI object used to generate the HTML. + +=item tree + +Reference to a hash describing a tree. See the description above. + +=item options + +Hash containing options for the tree display. + +=back + +The allowable options are as follows + +=over 4 + +=item nodeImageClosed + +URL of the image to display next to the tree nodes when they are collapsed. Clicking +on the image will expand a section of the tree. The default is C<../FIG/Html/plus.gif>. + +=item nodeImageOpen + +URL of the image to display next to the tree nodes when they are expanded. Clicking +on the image will collapse a section of the tree. The default is C<../FIG/Html/minus.gif>. -The run-time column text. It consists of 2 percent signs, a column type, an equal -sign, and the data for the current row. +=item style + +Style to use for the tree. The default is C. Because the tree style is implemented +as nested lists, the key components of this style are the definitions for the C
    and +C
  • tags. The default style file contains the following definitions. + + .tree ul { + margin-left: 0; padding-left: 22px + } + .tree li { + list-style-type: none; + } + +The default image is 22 pixels wide, so in the above scheme each tree level is indented from its +parent by the width of the node image. This use of styles limits the things we can do in formatting +the tree, but it has the advantage of vastly simplifying the tree creation. + +=item name + +Field name to give to the radio buttons in the tree. The default is C. + +=item target + +Frame target for links. The default is C<_self>. + +=item selected + +If specified, the value of the radio button to be pre-selected. + +=back + +=cut + +sub SelectionTree { + # Get the parameters. + my ($cgi, $tree, %options) = @_; + # Get the options. + my $optionThing = Tracer::GetOptions({ name => 'selection', + nodeImageClosed => '../FIG/Html/plus.gif', + nodeImageOpen => '../FIG/Html/minus.gif', + style => 'tree', + target => '_self', + selected => undef}, + \%options); + # Declare the return variable. We'll do the standard thing with creating a list + # of HTML lines and rolling them together at the end. + my @retVal = (); + # Only proceed if the tree is present. + if (defined($tree)) { + # Validate the tree. + if (ref $tree ne 'ARRAY') { + Confess("Selection tree is not a list reference."); + } elsif (scalar @{$tree} == 0) { + # The tree is empty, so we do nothing. + } elsif ($tree->[0] eq 'HASH') { + Confess("Hash reference found at start of selection tree. The tree as a whole cannot have attributes, only tree nodes."); + } else { + # Here we have a real tree. Apply the tree style. + push @retVal, $cgi->start_div({ class => $optionThing->{style} }); + # Give us a DIV ID. + my $divID = GetDivID($optionThing->{name}); + # Show the tree. + push @retVal, ShowBranch($cgi, "(root)", $divID, $tree, $optionThing, 'block'); + # Close the DIV block. + push @retVal, $cgi->end_div(); + } + } + # Return the result. + return join("\n", @retVal, ""); +} + +=head3 ShowBranch + + my @htmlLines = SearchHelper::ShowBranch($cgi, $label, $id, $branch, $options, $displayType); + +This is a recursive method that displays a branch of the tree. + +=over 4 + +=item cgi + +CGI object used to format HTML. + +=item label + +Label of this tree branch. It is only used in error messages. + +=item id + +ID to be given to this tree branch. The ID is used in the code that expands and collapses +tree nodes. + +=item branch + +Reference to a list containing the content of the tree branch. The list contains an optional +hash reference that is ignored and the list of children, each child represented by a name +and then its contents. The contents could by a hash reference (indicating the attributes +of a leaf node), or another tree branch. + +=item options + +Options from the original call to L. + +=item displayType + +C if the contents of this list are to be displayed, C if they are to be +hidden. =item RETURN -Returns the fully-formatted HTML text to go into the current column of the current row. +Returns one or more HTML lines that can be used to display the tree branch. =back =cut -sub GetRunTimeValue { +sub ShowBranch { # Get the parameters. - my ($self, $text) = @_; + my ($cgi, $label, $id, $branch, $options, $displayType) = @_; # Declare the return variable. - my $retVal; - # Parse the incoming text. - if ($text =~ /^%%([^=]+)=(.*)$/) { - $retVal = $self->RunTimeColumns($1, $2); + my @retVal = (); + # Start the branch. + push @retVal, $cgi->start_ul({ id => $id, style => "display:$displayType" }); + # Check for the hash and choose the start location accordingly. + my $i0 = (ref $branch->[0] eq 'HASH' ? 1 : 0); + # Get the list length. + my $i1 = scalar(@{$branch}); + # Verify we have an even number of elements. + if (($i1 - $i0) % 2 != 0) { + Trace("Branch elements are from $i0 to $i1.") if T(3); + Confess("Odd number of elements in tree branch $label."); } else { - Confess("Invalid run-time column string \"$text\" encountered in session file."); + # Loop through the elements. + for (my $i = $i0; $i < $i1; $i += 2) { + # Get this node's label and contents. + my ($myLabel, $myContent) = ($branch->[$i], $branch->[$i+1]); + # Get an ID for this node's children (if any). + my $myID = GetDivID($options->{name}); + # Now we need to find the list of children and the options hash. + # This is a bit ugly because we allow the shortcut of a hash without an + # enclosing list. First, we need some variables. + my $attrHash = {}; + my @childHtml = (); + my $hasChildren = 0; + if (! ref $myContent) { + Confess("Invalid tree definition. Scalar found as content of node \"$myLabel\"."); + } elsif (ref $myContent eq 'HASH') { + # Here the node is a leaf and its content contains the link/value hash. + $attrHash = $myContent; + } elsif (ref $myContent eq 'ARRAY') { + # Here the node may be a branch. Its content is a list. + my $len = scalar @{$myContent}; + if ($len >= 1) { + # Here the first element of the list could by the link/value hash. + if (ref $myContent->[0] eq 'HASH') { + $attrHash = $myContent->[0]; + # If there's data in the list besides the hash, it's our child list. + # We can pass the entire thing as the child list, because the hash + # is ignored. + if ($len > 1) { + $hasChildren = 1; + } + } else { + $hasChildren = 1; + } + # If we have children, create the child list with a recursive call. + if ($hasChildren) { + Trace("Processing children of $myLabel.") if T(4); + push @childHtml, ShowBranch($cgi, $myLabel, $myID, $myContent, $options, 'none'); + Trace("Children of $myLabel finished.") if T(4); + } + } + } + # Okay, it's time to pause and take stock. We have the label of the current node + # in $myLabel, its attributes in $attrHash, and if it is NOT a leaf node, we + # have a child list in @childHtml. If it IS a leaf node, $hasChildren is 0. + # Compute the image HTML. It's tricky, because we have to deal with the open and + # closed images. + my @images = ($options->{nodeImageOpen}, $options->{nodeImageClosed}); + my $image = $images[$hasChildren]; + my $prefixHtml = $cgi->img({src => $image, id => "${myID}img"}); + if ($hasChildren) { + # If there are children, we wrap the image in a toggle hyperlink. + $prefixHtml = $cgi->a({ onClick => "javascript:treeToggle('$myID','$images[0]', '$images[1]')" }, + $prefixHtml); + } + # Now the radio button, if any. Note we use "defined" in case the user wants the + # value to be 0. + if (defined $attrHash->{value}) { + # Due to a glitchiness in the CGI stuff, we have to build the attribute + # hash for the "input" method. If the item is pre-selected, we add + # "checked => undef" to the hash. Otherwise, we can't have "checked" + # at all. + my $radioParms = { type => 'radio', + name => $options->{name}, + value => $attrHash->{value}, + }; + if (defined $options->{selected} && $options->{selected} eq $attrHash->{value}) { + $radioParms->{checked} = undef; + } + $prefixHtml .= $cgi->input($radioParms); + } + # Next, we format the label. + my $labelHtml = $myLabel; + Trace("Formatting tree node for \"$myLabel\".") if T(4); + # Apply a hyperlink if necessary. + if (defined $attrHash->{link}) { + $labelHtml = $cgi->a({ href => $attrHash->{link}, target => $options->{target} }, + $labelHtml); + } + # Finally, roll up the child HTML. If there are no children, we'll get a null string + # here. + my $childHtml = join("\n", @childHtml); + # Now we have all the pieces, so we can put them together. + push @retVal, $cgi->li("$prefixHtml$labelHtml$childHtml"); + } } + # Close the tree branch. + push @retVal, $cgi->end_ul(); # Return the result. - return $retVal; + return @retVal; } -=head2 Feature Column Methods +=head3 GetDivID -The methods in this column manage feature column data. If you want to provide the -capability to include new types of data in feature columns, then all the changes -are made to this section of the source file. Technically, this should be implemented -using object-oriented methods, but this is simpler for non-programmers to maintain. -To add a new column of feature data, you must first give it a name. For example, -the name for the protein page link column is C. If the column is to appear -in the default list of feature columns, add it to the list returned by -L. Then add code to produce the column title to -L and code to produce its value to L, and -everything else will happen automatically. + my $idString = SearchHelper::GetDivID($name); -There is one special column name syntax for extra columns (that is, nonstandard -feature columns). If the column name begins with C, then it is presumed to be -an extra column. The column title is the text after the C, and its value is -pulled from the extra column hash. +Return a new HTML ID string. -=head3 DefaultFeatureColumns +=over 4 -C<< my $colNames = $shelp->DefaultFeatureColumns(); >> +=item name + +Name to be prefixed to the ID string. + +=item RETURN -Return a reference to a list of the default feature column identifiers. These -identifiers can be passed to L and L in -order to produce the column titles and row values. +Returns a hopefully-unique ID string. + +=back =cut -sub DefaultFeatureColumns { +sub GetDivID { # Get the parameters. - my ($self) = @_; + my ($name) = @_; + # Compute the ID. + my $retVal = "elt_$name$divCount"; + # Increment the counter to make sure this ID is not re-used. + $divCount++; # Return the result. - return ['orgName', 'function', 'gblink', 'protlink', - FeatureQuery::AdditionalColumns($self)]; + return $retVal; } -=head3 FeatureColumnTitle +=head3 PrintLine -C<< my $title = $shelp->FeatureColumnTitle($colName); >> + $shelp->PrintLine($message); -Return the column heading title to be used for the specified feature column. +Print a line of CGI output. This is used during the operation of the B method while +searching, so the user sees progress in real-time. =over 4 -=item name +=item message + +HTML text to display. + +=back + +=cut + +sub PrintLine { + # Get the parameters. + my ($self, $message) = @_; + # Send them to the output. + print "$message\n"; +} + +=head3 GetHelper + + my $shelp = SearchHelper::GetHelper($parm, $type => $className); + +Return a helper object with the given class name. If no such class exists, an +error will be thrown. + +=over 4 -Name of the desired feature column. +=item parm + +Parameter to pass to the constructor. This is a CGI object for a search helper +and a search helper object for the result helper. + +=item type + +Type of helper: C for a result helper and C for a search helper. + +=item className + +Class name for the helper object, without the preceding C or C. This is +identical to what the script expects for the C or C parameter. =item RETURN -Returns the title to be used as the column header for the named feature column. +Returns a helper object for the specified class. =back =cut -sub FeatureColumnTitle { +sub GetHelper { # Get the parameters. - my ($self, $colName) = @_; - # Declare the return variable. We default to a blank column name. - my $retVal = " "; - # Process the column name. - if ($colName =~ /^X=(.+)$/) { - # Here we have an extra column. - $retVal = $1; - } elsif ($colName eq 'orgName') { - $retVal = "Name"; - } elsif ($colName eq 'fid') { - $retVal = "FIG ID"; - } elsif ($colName eq 'alias') { - $retVal = "External Aliases"; - } elsif ($colName eq 'function') { - $retVal = "Functional Assignment"; - } elsif ($colName eq 'gblink') { - $retVal = "GBrowse"; - } elsif ($colName eq 'protlink') { - $retVal = "NMPDR Protein Page"; - } elsif ($colName eq 'group') { - $retVal = "NMDPR Group"; + my ($parm, $type, $className) = @_; + # Declare the return variable. + my $retVal; + # Try to create the helper. + eval { + # Load it into memory. If it's already there nothing will happen here. + my $realName = "$type$className"; + Trace("Requiring helper $realName.") if T(3); + require "$realName.pm"; + Trace("Constructing helper object.") if T(3); + # Construct the object. + $retVal = eval("$realName->new(\$parm)"); + # Commit suicide if it didn't work. + if (! defined $retVal) { + die "Could not find a $type handler of type $className."; + } + }; + # Check for errors. + if ($@) { + Confess("Error retrieving $type$className: $@"); } # Return the result. return $retVal; } -=head3 FeatureColumnValue +=head3 SaveOrganismData -C<< my $value = $shelp->FeatureColumnValue($colName, $fid, \%extraCols); >> + my ($name, $displayGroup, $domain) = $shelp->SaveOrganismData($group, $genomeID, $genus, $species, $strain, $taxonomy); -Return the value to be displayed in the specified feature column. +Format the name of an organism and the display version of its group name. The incoming +data should be the relevant fields from the B record in the database. The +data will also be stored in the genome cache for later use in posting search results. =over 4 -=item colName +=item group + +Name of the genome's group as it appears in the database. + +=item genomeID + +ID of the relevant genome. + +=item genus + +Genus of the genome's organism. If undefined or null, it will be assumed the genome is not +in the database. In this case, the organism name is derived from the genomeID and the group +is automatically the supporting-genomes group. -Name of the column to be displayed. +=item species -=item record +Species of the genome's organism. -DBObject record for the feature being displayed in the current row. +=item strain -=item extraCols +Strain of the species represented by the genome. -Reference to a hash of extra column names to values. If the incoming column name -begins with C, its value will be taken from this hash. +=item taxonomy + +Taxonomy of the species represented by the genome. =item RETURN -Returns the HTML to be displayed in the named column for the specified feature. +Returns a three-element list. The first element is the formatted genome name. The second +element is the display name of the genome's group. The third is the genome's domain. =back =cut -sub FeatureColumnValue { +sub SaveOrganismData { # Get the parameters. - my ($self, $colName, $record, $extraCols) = @_; - # Get the sprout and CGI objects. - my $cgi = $self->Q(); - my $sprout = $self->DB(); - # Get the feature ID. - my ($fid) = $record->Value('Feature(id)'); - # Declare the return variable. Denote that we default to a non-breaking space, - # which will translate to an empty table cell (rather than a table cell with no - # interior, which is what you get for a null string). - my $retVal = " "; - # Process according to the column name. - if ($colName =~ /^X=(.+)$/) { - # Here we have an extra column. Only update if the value exists. Note that - # a value of C is treated as a non-existent value, because the - # caller may have put "colName => undef" in the "PutFeature" call in order - # to insure we know the extra column exists. - if (defined $extraCols->{$1}) { - $retVal = $extraCols->{$1}; - } - } elsif ($colName eq 'orgName') { - # Here we want the formatted organism name and feature number. - $retVal = $self->FeatureName($fid); - } elsif ($colName eq 'fid') { - # Here we have the raw feature ID. We hyperlink it to the protein page. - $retVal = HTML::set_prot_links($fid); - } elsif ($colName eq 'alias') { - # In this case, the user wants a list of external aliases for the feature. - # These are very expensive, so we compute them when the row is displayed. - $retVal = "%%aliases=$fid"; - } elsif ($colName eq 'function') { - # The functional assignment is just a matter of getting some text. - ($retVal) = $record->Value('Feature(assignment)'); - } elsif ($colName eq 'gblink') { - # Here we want a link to the GBrowse page using the official GBrowse button. - my $gurl = "GetGBrowse.cgi?fid=$fid"; - $retVal = $cgi->a({ href => $gurl, title => "GBrowse for $fid" }, - $cgi->img({ src => "../images/button-gbrowse.png", - border => 0 }) - ); - } elsif ($colName eq 'protlink') { - # Here we want a link to the protein page using the official NMPDR button. - my $hurl = HTML::fid_link($cgi, $fid, 0, 1); - $retVal = $cgi->a({ href => $hurl, title => "Protein page for $fid" }, - $cgi->img({ src => "../images/button-nmpdr.png", - border => 0 }) - ); - } elsif ($colName eq 'group') { - # Get the NMPDR group name. - my (undef, $group) = $self->OrganismData($fid); - # Dress it with a URL to the group's main page. - my $nurl = $sprout->GroupPageName($group); - $retVal = $cgi->a({ href => $nurl, title => "$group summary" }, - $group); - } + my ($self, $group, $genomeID, $genus, $species, $strain, $taxonomy) = @_; + # Declare the return values. + my ($name, $displayGroup); + # If the organism does not exist, format an unknown name and a blank group. + if (! defined($genus)) { + $name = "Unknown Genome $genomeID"; + $displayGroup = ""; + } else { + # It does exist, so format the organism name. + $name = "$genus $species"; + if ($strain) { + $name .= " $strain"; + } + # Compute the display group. This is currently the same as the incoming group + # name unless it's the supporting group, which is nulled out. + $displayGroup = ($group eq $FIG_Config::otherGroup ? "" : $group); + Trace("Group = $displayGroup, translated from \"$group\".") if T(4); + } + # Compute the domain from the taxonomy. + my ($domain) = split /\s*;\s*/, $taxonomy, 2; + # Cache the group and organism data. + my $cache = $self->{orgs}; + $cache->{$genomeID} = [$name, $displayGroup, $domain]; # Return the result. - return $retVal; + return ($name, $displayGroup, $domain); } -=head3 RunTimeColumns +=head3 ValidateKeywords -C<< my $htmlText = $shelp->RunTimeColumns($type, $text); >> + my $okFlag = $shelp->ValidateKeywords($keywordString, $required); -Return the HTML text for a run-time column. Run-time columns are evaluated when the -list is displayed, rather than when it is generated. +Insure that a keyword string is reasonably valid. If it is invalid, a message will be +set. =over 4 -=item type +=item keywordString -Type of column. +Keyword string specified as a parameter to the current search. -=item text +=item required -Data relevant to this row of the column. +TRUE if there must be at least one keyword specified, else FALSE. =item RETURN -Returns the fully-formatted HTML text to go in the specified column. +Returns TRUE if the keyword string is valid, else FALSE. Note that a null keyword string +is acceptable if the I<$required> parameter is not specified. =back =cut -sub RunTimeColumns { +sub ValidateKeywords { # Get the parameters. - my ($self, $type, $text) = @_; + my ($self, $keywordString, $required) = @_; # Declare the return variable. - my $retVal = ""; - # Get the Sprout and CGI objects. - my $sprout = $self->DB(); + my $retVal = 0; + my @wordList = split /\s+/, $keywordString; + # Right now our only real worry is a list of all minus words. The problem with it is that + # it will return an incorrect result. + my @plusWords = grep { $_ =~ /^[^\-]/ } @wordList; + if (! @wordList) { + if ($required) { + $self->SetMessage("No search words specified."); + } else { + $retVal = 1; + } + } elsif (! @plusWords) { + $self->SetMessage("At least one keyword must be positive. All the keywords entered are preceded by minus signs."); + } else { + $retVal = 1; + } + # Return the result. + return $retVal; +} + +=head3 TuningParameters + + my $options = $shelp->TuningParameters(%parmHash); + +Retrieve tuning parameters from the CGI query object. The parameter is a hash that maps parameter names +to their default values. The parameters and their values will be returned as a hash reference. + +=over 4 + +=item parmHash + +Hash mapping parameter names to their default values. + +=item RETURN + +Returns a reference to a hash containing the parameter names mapped to their actual values. + +=back + +=cut + +sub TuningParameters { + # Get the parameters. + my ($self, %parmHash) = @_; + # Declare the return variable. + my $retVal = {}; + # Get the CGI Query Object. my $cgi = $self->Q(); - # Separate the text into a type and data. - if ($type eq 'aliases') { - # Here the caller wants external alias links for a feature. The text - # is the feature ID. - my $fid = $text; - # The complicated part is we have to hyperlink them. First, get the - # aliases. - Trace("Generating aliases for feature $fid.") if T(4); - my @aliases = $sprout->FeatureAliases($fid); - # Only proceed if we found some. - if (@aliases) { - # Join the aliases into a comma-delimited list. - my $aliasList = join(", ", @aliases); - # Ask the HTML processor to hyperlink them. - $retVal = HTML::set_prot_links($cgi, $aliasList); + # Loop through the parameter names. + for my $parm (keys %parmHash) { + # Get the incoming value for this parameter. + my $value = $cgi->param($parm); + # Zero might be a valid value, so we do an is-defined check rather than an OR. + if (defined($value)) { + $retVal->{$parm} = $value; + } else { + $retVal->{$parm} = $parmHash{$parm}; } } # Return the result. return $retVal; } +=head3 GetPreferredAliasType + + my $type = $shelp->GetPreferredAliasType(); + +Return the preferred alias type for the current session. This information is stored +in the C parameter of the CGI query object, and the default is C +(which indicates the FIG ID). + +=cut + +sub GetPreferredAliasType { + # Get the parameters. + my ($self) = @_; + # Determine the preferred type. + my $cgi = $self->Q(); + my $retVal = $cgi->param('AliasType') || 'FIG'; + # Return it. + return $retVal; +} + =head2 Virtual Methods =head3 Form -C<< my $html = $shelp->Form(); >> + my $html = $shelp->Form(); Generate the HTML for a form to request a new search. =head3 Find -C<< my $resultCount = $shelp->Find(); >> + my $resultCount = $shelp->Find(); Conduct a search based on the current CGI query parameters. The search results will be written to the session cache file and the number of results will be returned. If the search parameters are invalid, a result count of C will be returned and a result message will be stored in this object describing the problem. +=cut + +sub Find { + # Get the parameters. + my ($self) = @_; + $self->Message("Call to pure virtual Find method in helper of type " . ref($self) . "."); + return undef; +} + =head3 Description -C<< my $htmlText = $shelp->Description(); >> + my $htmlText = $shelp->Description(); Return a description of this search. The description is used for the table of contents on the main search tools page. It may contain HTML, but it should be character-level, not block-level, since the description is going to appear in a list. -=head3 SortKey +=cut -C<< my $key = $shelp->SortKey($record); >> +sub Description { + # Get the parameters. + my ($self) = @_; + $self->Message("Call to pure virtual Description method in helper of type " . ref($self) . "."); + return "Unknown search type"; +} -Return the sort key for the specified record. The default is to sort by feature name, -floating NMPDR organisms to the top. This sort may be overridden by the search class -to provide fancier functionality. This method is called by B, so it -is only used for feature searches. A non-feature search would presumably have its -own sort logic. +=head3 SearchTitle + + my $titleHtml = $shelp->SearchTitle(); + +Return the display title for this search. The display title appears above the search results. +If no result is returned, no title will be displayed. The result should be an html string +that can be legally put inside a block tag such as C
    or C
    . + +=cut + +sub SearchTitle { + # Get the parameters. + my ($self) = @_; + # Declare the return variable. + my $retVal = ""; + # Return it. + return $retVal; +} + +=head3 DefaultColumns + + $shelp->DefaultColumns($rhelp); + +Store the default columns in the result helper. The default action is just to ask +the result helper for its default columns, but this may be changed by overriding +this method. + +=over 4 + +=item rhelp + +Result helper object in which the column list should be stored. + +=back + +=cut + +sub DefaultColumns { + # Get the parameters. + my ($self, $rhelp) = @_; + # Get the default columns from the result helper. + my @cols = $rhelp->DefaultResultColumns(); + # Store them back. + $rhelp->SetColumns(@cols); +} + +=head3 Hint + + my $htmlText = SearchHelper::Hint($wikiPage, $hintText); + +Return the HTML for a small question mark that displays the specified hint text when it is clicked. +This HTML can be put in forms to provide a useful hinting mechanism. =over 4 -=item record +=item wikiPage + +Name of the wiki page to be popped up when the hint mark is clicked. + +=item hintText -The C from which the current row of data is derived. +Text to display for the hint. It is raw html, but may not contain any double quotes. =item RETURN -Returns a key field that can be used to sort this row in among the results. +Returns the html for the hint facility. The resulting html shows a small button-like thing that +uses the standard FIG popup technology. =back =cut -sub SortKey { +sub Hint { # Get the parameters. - my ($self, $record) = @_; - # Get the feature ID from the record. - my ($fid) = $record->Value('Feature(id)'); - # Get the group from the feature ID. - my $group = $self->FeatureGroup($fid); - # Ask the feature query object to form the sort key. - my $retVal = FeatureQuery::SortKey($self, $group, $record); - # Return the result. + my ($wikiPage, $hintText) = @_; + # Escape the single quotes in the hint text. + my $quotedText = $hintText; + $quotedText =~ s/'/\\'/g; + # Convert the wiki page name to a URL. + my $wikiURL = join("", map { ucfirst $_ } split /\s+/, $wikiPage); + $wikiURL = "wiki/view.cgi/FIG/$wikiURL"; + # Create the html. + my $retVal = " "; + # Return it. return $retVal; } -1; \ No newline at end of file + + +1;
