[Bio] / Sprout / SaplingLoader.pl Repository:
Log of /Sprout/SaplingLoader.pl
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Tue Jul 12 20:34:47 2011 UTC (8 years, 7 months ago) by parrello
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928
Tuned tracing messages a little more.
Tue Jul 12 18:48:19 2011 UTC (8 years, 7 months ago) by parrello
Changes since 1.4: +8 -2 lines
Added ability to specify an alternate host.
Tue Jul 12 18:41:53 2011 UTC (8 years, 7 months ago) by parrello
Added tracing to help figure out problems with the PSEED sapling load.
Wed Jun 15 20:05:31 2011 UTC (8 years, 8 months ago) by parrello
Changes since 1.2: +1 -5 lines
Fixed some documentation errors.
Thu Apr 21 21:03:43 2011 UTC (8 years, 9 months ago) by parrello
CVS Tags: mgrast_dev_06072011, mgrast_release_3_1_0
Changes since 1.1: +1 -3 lines
Removed a debugging-oriented connection statement.
Thu Apr 21 19:58:18 2011 UTC (8 years, 9 months ago) by parrello
Incremental load fixes and changes.
