[Bio] / Sprout / SaplingGenomeLoader.pm Repository:
Log of /Sprout/SaplingGenomeLoader.pm
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Fri Jul 22 19:20:11 2011 UTC (8 years, 2 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1
Changes since 1.12: +2 -2 lines
Diff to previous 1.12 , to selected 1.6
Fix infinite loop when an annotation file is missing the final //
Tue Jul 12 18:41:53 2011 UTC (8 years, 3 months ago) by parrello
Changes since 1.11: +9 -9 lines
Diff to previous 1.11 , to selected 1.6
Added tracing to help figure out problems with the PSEED sapling load.
Thu May 12 20:00:43 2011 UTC (8 years, 5 months ago) by parrello
CVS Tags: mgrast_dev_06072011, mgrast_release_3_1_0
Changes since 1.10: +158 -215 lines
Diff to previous 1.10 , to selected 1.6
Latest re-shuffling of the incremental load stuff.
Sat Apr 23 20:19:24 2011 UTC (8 years, 5 months ago) by parrello
Changes since 1.9: +17 -12 lines
Diff to previous 1.9 , to selected 1.6
loader fixes
Thu Apr 21 19:58:18 2011 UTC (8 years, 5 months ago) by parrello
Changes since 1.8: +8 -2 lines
Incremental load fixes and changes.
Fri Apr 1 20:48:01 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_3, mgrast_release_3_0_4
Fixed method that computes protein IDs.
Wed Mar 23 18:42:34 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, myrast_33
Changes since 1.6: +68 -33 lines
More loader updates.
Sat Feb 26 19:05:32 2011 UTC (8 years, 7 months ago) by parrello
CVS Tags: mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2
Changes since 1.5: +126 -5 lines
Even more loader fixes.
Sun Feb 13 13:02:30 2011 UTC (8 years, 8 months ago) by parrello
Fri Jan 28 22:51:42 2011 UTC (8 years, 8 months ago) by parrello
Created script for loading expression data.
Tue Jan 25 19:41:04 2011 UTC (8 years, 8 months ago) by parrello
Changes since 1.2: +147 -272 lines
Changes relating to the Expression Directory loader.
Tue Jan 11 15:04:03 2011 UTC (8 years, 9 months ago) by parrello
CVS Tags: rast_rel_2011_0119
Changes since 1.1: +98 -4 lines
Updates for single-genome loader.
Tue Dec 14 19:48:38 2010 UTC (8 years, 10 months ago) by parrello
Diff to selected 1.6
Support for SQLite database load.
