[Bio] / Sprout / SaplingGenomeLoader.pm Repository:
Log of /Sprout/SaplingGenomeLoader.pm
Thu Jul 11 19:34:38 2013 UTC (6 years, 3 months ago) by parrello
CVS Tags: rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.18: +13 -3 lines
Diff to previous 1.18 , to selected 1.14
Added code to recover from duplicate machine IDs.
Wed May 8 20:28:44 2013 UTC (6 years, 5 months ago) by parrello
Changes since 1.17: +121 -85 lines
Diff to previous 1.17 , to selected 1.14
Updates for new incremental load.
Tue Mar 26 02:10:46 2013 UTC (6 years, 6 months ago) by parrello
Changes since 1.16: +78 -146 lines
Diff to previous 1.16 , to selected 1.14
Support for initial version of the incremental load.
Tue Dec 6 21:44:46 2011 UTC (7 years, 10 months ago) by olson
CVS Tags: mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2
Changes since 1.15: +9 -3 lines
Diff to previous 1.15 , to selected 1.14
Support disconnected operation; force missing assignments to "".
Mon Dec 5 22:05:15 2011 UTC (7 years, 10 months ago) by olson
Changes since 1.14: +29 -5 lines
Changes to support disconnected mode (don't try to talk to a SAP server) and to
allow creation of features that do not have assignments in assigned_functions.
Revision 1.14 - (view) (download) (as text) (annotate) - [selected]
Wed Aug 24 21:11:36 2011 UTC (8 years, 1 month ago) by parrello
CVS Tags: mgrast_dev_10262011, rast_rel_2011_0928
Changes since 1.13: +6 -2 lines
Updates for putting gc_content in Sapling.
Fri Jul 22 19:20:11 2011 UTC (8 years, 2 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1
Changes since 1.12: +2 -2 lines
Diff to previous 1.12 , to selected 1.14
Fix infinite loop when an annotation file is missing the final //
Tue Jul 12 18:41:53 2011 UTC (8 years, 3 months ago) by parrello
Changes since 1.11: +9 -9 lines
Diff to previous 1.11 , to selected 1.14
Added tracing to help figure out problems with the PSEED sapling load.
Thu May 12 20:00:43 2011 UTC (8 years, 5 months ago) by parrello
CVS Tags: mgrast_dev_06072011, mgrast_release_3_1_0
Changes since 1.10: +158 -215 lines
Diff to previous 1.10 , to selected 1.14
Latest re-shuffling of the incremental load stuff.
Sat Apr 23 20:19:24 2011 UTC (8 years, 5 months ago) by parrello
Changes since 1.9: +17 -12 lines
Diff to previous 1.9 , to selected 1.14
loader fixes
Thu Apr 21 19:58:18 2011 UTC (8 years, 5 months ago) by parrello
Changes since 1.8: +8 -2 lines
Diff to previous 1.8 , to selected 1.14
Incremental load fixes and changes.
Fri Apr 1 20:48:01 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_3, mgrast_release_3_0_4
Diff to previous 1.7 , to selected 1.14
Fixed method that computes protein IDs.
Wed Mar 23 18:42:34 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, myrast_33
Changes since 1.6: +68 -33 lines
Diff to previous 1.6 , to selected 1.14
More loader updates.
Sat Feb 26 19:05:32 2011 UTC (8 years, 7 months ago) by parrello
CVS Tags: mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2
Changes since 1.5: +126 -5 lines
Diff to previous 1.5 , to selected 1.14
Even more loader fixes.
Sun Feb 13 13:02:30 2011 UTC (8 years, 8 months ago) by parrello
Diff to previous 1.4 , to selected 1.14
Fri Jan 28 22:51:42 2011 UTC (8 years, 8 months ago) by parrello
Diff to previous 1.3 , to selected 1.14
Created script for loading expression data.
Tue Jan 25 19:41:04 2011 UTC (8 years, 8 months ago) by parrello
Changes since 1.2: +147 -272 lines
Diff to previous 1.2 , to selected 1.14
Changes relating to the Expression Directory loader.
Tue Jan 11 15:04:03 2011 UTC (8 years, 9 months ago) by parrello
CVS Tags: rast_rel_2011_0119
Changes since 1.1: +98 -4 lines
Diff to previous 1.1 , to selected 1.14
Updates for single-genome loader.
Tue Dec 14 19:48:38 2010 UTC (8 years, 10 months ago) by parrello
Diff to selected 1.14
Support for SQLite database load.
