[Bio] / Sprout / SaplingGenomeLoader.pm Repository:
View of /Sprout/SaplingGenomeLoader.pm
Revision 1.20 - (download) (as text) (annotate)
Fri Jul 10 14:22:27 2015 UTC (4 years, 8 months ago) by parrello
CVS Tags: HEAD
Added replaceAll option for sapling load check.
#!/usr/bin/perl -w
# Public License.
package SaplingGenomeLoader;
    use strict;
    use Tracer;
    use Stats;
    use SeedUtils;
    use SAPserver;
    use Sapling;
    use AliasAnalysis;
    use BaseSaplingLoader;
    use MD5Computer;
    use base qw(SaplingDataLoader);
=head1 Sapling Genome Loader
This package contains the methods used to load a genome into the Sapling from a genome
directory. This is not very efficient if you are trying to create a full database,
but is useful if you wish to add genomes one at a time. The information loaded will
include the basic genome data, the contigs and the DNA, subsystems, and the features.
=head2 Main Methods
=head3 Load
    my $stats = SaplingGenomeLoader::Load($sap, $genome, $directory);
Load a genome from a genome directory into the sapling database.
=over 4
=item sap
L<Sapling> object used to access the target database.
=item genome
ID of the genome being loaded.
=item directory
Name of the directory containing the genome information.
=back
=cut
sub Load {
    # Get the parameters.
    my ($sap, $genome, $directory) = @_;
    # Create the loader object.
    my $loaderObject = SaplingGenomeLoader->new($sap, $genome, $directory);
    # Load the contigs.
    Trace("Loading contigs for $genome.") if T(SaplingDataLoader => 2);
    $loaderObject->LoadContigs();
    # Load the features.
    Trace("Loading features for $genome.") if T(SaplingDataLoader => 2);
    $loaderObject->LoadFeatures();
    # Check for annotation history. If we have it, load the history records into the
    # database.
    if (-f "$directory/annotations") {
        Trace("Processing annotations.") if T(SaplingDataLoader => 3);
        $loaderObject->LoadAnnotations("$directory/annotations");
    # Load the subsystem bindings.
    Trace("Loading subsystems for $genome.") if T(SaplingDataLoader => 2);
    $loaderObject->LoadSubsystems();
    # Create the Genome record and taxonomy information.
    Trace("Creating root for $genome.") if T(SaplingDataLoader => 2);
    $loaderObject->CreateGenome();
    # Return the statistics.
    return $loaderObject->{stats};
=head3 ClearGenome
    my $stats = SaplingGenomeObject::ClearGenome($sap, $genome);
Delete the specified genome and all the related records from the specified sapling
database. This method can also be used to clean up after a failed or aborted load.
=over 4
=item sap
=item genome
ID of the genome to delete.
=item RETURN
Returns a statistics object counting the records deleted.
=back
=cut
sub ClearGenome {
    my ($sap, $genome) = @_;
    # Create the statistics object.
    my $stats = Stats->new();
    # Delete the DNA sequences.
    my @seqs = $sap->GetFlat('DNASequence', 'DNASequence(id) LIKE ?', ["$genome:%"], 'id');
    for my $seq (@seqs) {
        my $delStats = $sap->Delete(DNASequence => $seq);
        $stats->Accumulate($delStats);
    # Delete the contigs.
    SaplingDataLoader::DeleteRelatedRecords($sap, $genome, $stats, 'IsMadeUpOf', 'Contig');
    # Delete the features.
    SaplingDataLoader::DeleteRelatedRecords($sap, $genome, $stats, 'IsOwnerOf', 'Feature');
    # Delete the molecular machines.
    SaplingDataLoader::DeleteRelatedRecords($sap, $genome, $stats, 'Uses', 'MolecularMachine');
    # Delete the genome itself.
    my $subStats = $sap->Delete(Genome => $genome);
    # Accumulate the statistics from the delete.
    $stats->Accumulate($subStats);
    Trace("Statistics for delete of $genome:\n" . $stats->Show()) if T(SaplingDataLoader => 3);
    # Return the statistics object.
    return $stats;
=head3 Process
    my $stats = SaplingGenomeLoader::Process($sap, $genome, $directory);
Load genome data from the specified directory. If the genome data already
exists in the database, it will be deleted first.
=over 4
=item sap
L</Sapling> object for accessing the database.
=item genome
ID of the genome whose  data is being loaded.
=item directory
Name of the directory containing the genome data files. If omitted, the
genome will be deleted from the database.
=item RETURN
Returns a statistics object describing the activity during the reload.
=back
=cut
sub Process {
    # Clear the existing data for the specified genome.
    my $stats = ClearGenome($sap, $genome);
    # Load the new genome data from the specified directory (if one is
    # specified).
    if ($directory) {
        my $newStats = Load($sap, $genome, $directory);
        # Merge the statistics.
        $stats->Accumulate($newStats);
    # Return the result.
    return $stats;
=head2 Loader Object Methods
=head3 new
Create a loader object that can be used to facilitate loading genome data from a
directory.
=over 4
=item sap
=item genome
=item directory
=back
The object created contains the following fields.
=over 4
=item directory
Name of the directory containing the genome data.
=item genome
=item supportRecords
A hash of hashes, used to track the support records known to exist in the database.
=item sap
L<Sapling> object used to access the database.
=item stats
L<Stats> object for tracking statistical information about the load.
=back
=cut
sub new {
    my ($class, $sap, $genome, $directory) = @_;
    # Create the object.
    my $retVal = SaplingDataLoader::new($class, $sap, qw(contigs dna pegs rnas));
    # Add our specialized data.
    $retVal->{genome} = $genome;
    $retVal->{directory} = $directory;
    # Leave the assignment hash undefined until we populate it.
    $retVal->{assignHash} = undef;
    # Create an MD5 Computer for this genome.
    $retVal->{md5} = MD5Computer->new();
    return $retVal;
=head3 LoadContigs
Load the contig information into the database. This includes the contigs themselves and
the DNA. The number of contigs will be recorded as the C<contigs> statistic, the
number of base pairs as the C<dna> statistic, and the number of GC instances as the
C<gc_content> statistic.
=cut
sub LoadContigs {
    # Get this object.
    my ($self) = @_;
    # Open the contigs file from the genome directory.
    my $ih = Open(undef, "<$self->{directory}/contigs");
    # Get the length of a DNA segment.
    my $segmentLength = $self->{sap}->TuningParameter('maxSequenceLength');
    # Get the genome ID.
    my $genome = $self->{genome};
    # These variables will contain the current contig ID, the current contig length,
    # the accumulated DNA sequence for the current chunk, and its length.
    my ($contigID, $contigLen, $chunk, $chunkLen) = (undef, 0, '', 0);
    # This variable contains a list of the chunks, for use in computing the MD5.
    my @chunks;
    # Loop through the contig file.
    while (! eof $ih) {
        # Get the current record.
        my $line = <$ih>; chomp $line;
        # Is this the start of a new contig?
        if ($line =~ /^>(\S+)/) {
            # Yes. Save the contig ID.
            my $newContigID = $1;
            # Is there a current contig?
            if (defined $contigID) {
                # Yes. Output the contig.
                $self->OutputContig($contigID, $contigLen, $chunk, \@chunks);
            # Compute the new contig ID. We need to insure it has a genome ID in front.
            $self->FixContig(\$newContigID);
            # Initialize the new contig.
            $contigID = $newContigID;
            $contigLen = 0;
            $chunk = '';
            $chunkLen = 0;
            @chunks = ();
        } else {
            # Here we have more DNA in the current contig. Are we at the end of
            # the current chunk?
            my $lineLen = length($line);
            my $newChunkLen = $chunkLen + $lineLen;
            if ($newChunkLen < $segmentLength) {
                # No. Add this line to the chunk.
                $chunk .= $line;
                $chunkLen += $lineLen;
            } else {
                # Yes. Create the actual chunk.
                $chunk .= substr($line, 0, $segmentLength - $chunkLen);
                # Write it out.
                $self->OutputChunk($contigID, scalar @chunks, $chunk);
                # Set up the new chunk.
                $chunk = substr($line, $segmentLength - $chunkLen);
                $chunkLen = length($chunk);
                push @chunks, $chunk;
            # Update the contig length.
            $contigLen += $lineLen;
        # Yes. Output the contig itself.
=head3 OutputChunk
    $loaderObject->OutputChunk($contigID, $ordinal, $chunk);
Output a chunk of DNA for the specified contig.
=over 4
=item contigID
ID of the contig being output.
=item ordinal
Ordinal number of this chunk.
=item chunk
DNA sequence comprising this chunk.
=back
=cut
sub OutputChunk {
    my ($self, $contigID, $ordinal, $chunk) = @_;
    # Get the sapling object.
    my $sap = $self->{sap};
    # Compute the chunk ID.
    my $chunkID = "$contigID:" . Tracer::Pad($ordinal, 7, 1, '0');
    # Connect this sequence to the contig.
    $sap->InsertObject('HasSection', from_link => $contigID, to_link => $chunkID);
    # Create the DNA sequence.
    $sap->InsertObject('DNASequence', id => $chunkID, sequence => $chunk);
    # Record the chunk.
    $self->{stats}->Add(chunks => 1);
    # Update the GC count.
    $self->{stats}->Add(gc_content => ($chunk =~ tr/GCgc//));
=head3 OutputContig
    $loaderObject->OutputContig($contigID, $contigLen, $chunk, \@chunks);
Write out the current contig.
=over 4
=item contigID
ID of the contig being written out.
=item contigLen
Length of the contig in base pairs.
=item chunk
Last DNA chunk of the contig.
=item chunks
Reference to a list of the DNA chunks up to (but not including) the last one.
=back
=cut
sub OutputContig {
    my ($self, $contigID, $contigLen, $chunk, $chunks) = @_;
    # Get the MD5 computer.
    my $md5C = $self->{md5};
    # Output the last chunk.
    $self->OutputChunk($contigID, scalar @$chunks, $chunk);
    # Connect the contig to the genome.
    $sap->InsertObject('IsMadeUpOf', from_link => $self->{genome}, to_link => $contigID);
    # Compute the MD5.
    push @$chunks, $chunk;
    my $contigMD5 = $md5C->ProcessContig($contigID, $chunks);
    # Output the contig record.
    $sap->InsertObject('Contig', id => $contigID, length => $contigLen,
            md5_identifier => $contigMD5);
    # Record the contig.
    $self->{stats}->Add(contigs => 1);
    $self->{stats}->Add(dna => $contigLen);
=head3 LoadFeatures
Load the feature data into the database. This includes all of the features,
their protein sequences, and their subsystem information. The number of
features of each type will be stored in the statistics object, identified by
the feature type.
=cut
sub LoadFeatures {
    my ($self) = @_;
    # Read in the functional assignments.
    Trace("Reading functional assignments.") if T(SaplingDataLoader => 3);
    my $assignHash = $self->ReadAssignments();
    $self->{assignHash} = $assignHash;
    # Get the directory of feature types.
    my $featureDir = "$self->{directory}/Features";
    my @types = Tracer::OpenDir("$self->{directory}/Features", 1);
    # Check for protein sequences. If we have some, load them into a hash.
    my $protHash = {};
    if (-f "$featureDir/peg/fasta") {
        Trace("Processing protein sequences.") if T(SaplingDataLoader => 3);
        $protHash = $self->LoadProteinData("$featureDir/peg/fasta");
    # Create the feature records for the types found.
    for my $type (@types) {
        # Insure this is a genuine feature directory.
        if (-f "$featureDir/$type/tbl") {
            # Yes. Read in the evidence codes (if any).
            my $evHash = {};
            my $tranFile = "$featureDir/$type/Attributes/transaction_log";
            if (-f $tranFile) {
                $evHash = $self->LoadEvidenceCodes($tranFile);
            # Now load the feature data.
            $self->LoadFeatureData($featureDir, $type, $protHash, $evHash);
=head3 LoadEvidenceCodes
    my $evHash = $loaderObject->LoadEvidenceCodes($attributeFile);
Load the evidence codes from the specified attribute transaction log file into a
hash. The log file is in tab-delimited format. The first column contains the
transaction code (either C<ADD> or C<DELETE>), the second column a feature ID,
the third an attribute name (we'll ignore everything but C<evidence_code>), and
the fourth the attribute value.
=over 4
=item attributeFile
Name of the attribute transaction log file.
=item RETURN
Returns a reference to a hash mapping each feature ID to a comma-delimited list
of its evidence codes.
=back
=cut
sub LoadEvidenceCodes {
    my ($self, $attributeFile) = @_;
    # Get the Sapling database.
    # Get the statistics object.
    my $stats = $self->{stats};
    # Get the assignment hash: we use this to filter the feature IDs.
    my $assignHash = $self->{assignHash};
    # Open the attribute log file for input.
    my $ih = Open(undef, "<$attributeFile");
    # This two-dimensional hash will hold the evidence codes for each feature.
    my %retVal;
    # Loop through the attribute log file.
    while (! eof $ih) {
        # Get the current attribute record.
        my ($command, $fid, $key, $value) = Tracer::GetLine($ih);
        $stats->Add(attributeLine => 1);
        # Insure we have all the pieces we need.
        if (! $command || ! $fid || $key ne 'evidence_code') {
            $stats->Add(attributeLineSkipped => 1);
        } elsif (! $assignHash->{$fid}) {
            # Here the attribute is for a deleted feature.
            $stats->Add(attributeFidSkipped => 1);
        } else {
            # Get the sub-hash for this feature.
            if (! exists $retVal{$fid}) {
                $retVal{$fid} = {};
            my $featureSubHash = $retVal{$fid};
            # Process according to the command.
            if ($command eq 'ADD') {
                # Here we are adding a new evidence code.
                $featureSubHash->{$value} = 1;
                $stats->Add(attributeAdd => 1);
            } elsif ($command eq 'DELETE') {
                # Here we are deleting an evidence code.
                delete $featureSubHash->{$value};
                $stats->Add(attributeDelete => 1);
            } else {
                # here we have an unrecognized command.
                $stats->Add(attributeCommandSkip => 1);
    # Loop through the hash, converting each sub-hash to a comma-delimited list of
    # evidence codes.
    for my $fid (keys %retVal) {
        $retVal{$fid} = join(",", sort keys %{$retVal{$fid}});
    # Return the evidence hash.
    return \%retVal;
=head3 LoadFeatureData
    $loaderObject->LoadFeatureData($featureDir, $type, $protHash, $evHash);
Load the basic data for each feature into the database. The number of features of
the type found will be recorded in the statistics object.
=over 4
=item featureDir
Name of the main directory containing all the feature type subdirectories.
=item type
Type of feature to load.
=item protHash
Reference to a hash mapping each feature ID for a protein-encoding gene to
its protein sequence.
=item evHash
Reference to a hash mapping each feature ID to a comma-delimited list of
its evidence codes (if any).
=back
=cut
sub LoadFeatureData {
    my ($self, $featureDir, $type, $protHash, $evHash) = @_;
    # Get the sapling database.
    # Get the assignment hash. This tells us our functional assignments. This method is
    # also where we remove the deleted features from it.
    # This hash will track the features we've created. If a feature is found a second
    # time, it overwrites the original.
    my %fidHash;
    # This hash tracks the deleted features. We don't want to update these.
    my %deleted_features;
    # Insure we have a tbl file for this feature type.
    my $fileName = "$featureDir/$type/tbl";
    if (-f $fileName) {
        # We have one, so we can read through it. First, however, we need to get the list
        # of deleted features and remove them from the assignment hash. This insures
        # that they are not used by subsequent methods.
        my $deleteFile = "$featureDir/$type/deleted.features";
        if (-f $deleteFile) {
            my $dh = Open(undef, "<$deleteFile");
            while (! eof $dh) {
                my ($deletedFid) = Tracer::GetLine($dh);
                if (exists $assignHash->{$deletedFid}) {
                    delete $assignHash->{$deletedFid};
                    $stats->Add(deletedFid => 1);
                    $deleted_features{$deletedFid} = 1;
        # Open the main file for input.
        Trace("Reading features from $fileName.") if T(SaplingDataLoader => 3);
        my $ih = Open(undef, "<$fileName");
        while (! eof $ih) {
            # Read this feature's information.
            my ($fid, $locations, @aliases) = Tracer::GetLine($ih);
            # Only proceed if the feature is NOT deleted.
            if (!$deleted_features{$fid}) {
                # If the feature already exists, delete it. (This should be extremely rare.)
                if ($fidHash{$fid}) {
                    $sap->Delete(Feature => $fid);
                    $stats->Add(duplicateFid => 1);
                } else {
                    # It doesn't exist, so record it in the statistics.
                    $stats->Add($type => 1);
                # If this is RNA, the alias list is always empty. Sometimes, the functional
                # assignment is found there.
                if ($type eq 'rna') {
                        $assignHash->{$fid} = $aliases[0];
                    @aliases = ();
                # Add the feature to the database.
                my $function = $assignHash->{$fid} || "";
                $self->AddFeature($fid, $function, $locations, \@aliases,
                                  $protHash->{$fid}, $evHash->{$fid});
                # Denote we've added this feature, so that if a duplicate occurs we're ready.
                $fidHash{$fid} = 1;
=head3 LoadProteinData
    my $protHash = $self->LoadProteinData($fileName);
Load the protein sequences from the named FASTA file. The sequences will be stored
in a hash by FIG feature ID.
=over 4
=item fileName
Name of the FASTA file containing the protein sequences for this genome.
=item RETURN
Returns a hash mapping feature IDs to protein sequences.
=back
=cut
sub LoadProteinData {
    my ($self, $fileName) = @_;
    # Open the FASTA file for input.
    # Create the return hash.
    my $retVal = {};
    # We'll track the current protein in here.
    my $fid;
    my $sequence = "";
    # Loop through the input file.
    while (! eof $ih) {
        # Is this a label record.
            # Yes. Save the new feature ID.
            my $newFid = $1;
            # Do we have an existing protein?
            if (defined $fid) {
                # Yes. Store it in the hash.
                $retVal->{$fid} = $sequence;
            # Initialize for the next protein.
            $fid = $newFid;
            $sequence = "";
        } else {
            # Here we have more letters for the current protein.
            $sequence .= $line;
    # Do we have a residual protein.
    if (defined $fid) {
    # Return the hash.
    return $retVal;
=head3 LoadAnnotations
    $loaderObject->LoadAnnotations($fileName);
Read in the annotation history information and use it to create annotation records.
=over 4
=item fileName
Name of the annotation history file. This file is formatted with four fields per
record. Each field is on a separate line, with a double slash (C<//>) used as the
line terminator. The fields, in order, are (0) the feature ID, (1) the timestamp
(formatted as an integer), (2) the user name, and (3) the annotation text.
=back
=cut
sub LoadAnnotations {
    # Get the assignment Hash. We use this to filter out deleted features.
    # Open the input file.
    my $ih = Tracer::Open(undef, "<$fileName");
    # Loop through the input.
    while (! eof $ih) {
        # Read in the peg, timestamp, and user ID.
        my ($fid, $timestamp, $user, $text) = ReadAnnotation($ih);
        # Only proceed if the feature is not deleted.
        if ($assignHash->{$fid}) {
            # Add the annotation to this feature.
            $self->MakeAnnotation($fid, $text, $user, $timestamp);
=head3 WriteProtein
    $loaderObject->WriteProtein($fid, $sequence);
Write out the specified protein sequence and associate it with the specified feature.
This requires checking to see if the protein sequence is already in the database.
=over 4
=item fid
ID of the feature with the specified protein sequence.
=item sequence
Protein sequence for the indicated feature.
=back
=cut
sub WriteProtein {
    my ($self, $fid, $sequence) = @_;
    # Compute the key of the protein sequence.
    my $protID = $self->{sap}->ProteinID($sequence);
    # Insure the protein exists.
    $self->InsureEntity(ProteinSequence => $protID, sequence => $sequence);
    # Connect the feature to it.
    $self->{sap}->InsertObject('IsProteinFor', from_link => $protID, to_link => $fid);
=head3 LoadSubsystems
    $loaderObject->LoadSubsystems($subsysList);
Load the subsystem data into the database. This requires looking through the
bindings and using them to connect to the subsystems that already exist in the
database. If the subsystem does not exist, its bindings will not be loaded.
=over 4
=item subsysList
Reference to a list of subsystem IDs. If specified, only the subsystems in the
list will be processed. This is useful when a particular set of subsystems
has been replaced.
=back
=cut
sub LoadSubsystems {
    my ($self, $subsysList) = @_;
    # Compute the subsystem and binding file names.
    my $subFileName = "$self->{directory}/Subsystems/subsystems";
    my $bindFileName = "$self->{directory}/Subsystems/bindings";
    # Get a hash of the molecular machines already connected to this genome.
    my %machinesOld = map { $_ => 1 } $sap->GetFlat('Uses', 'Uses(from-link) = ?',
            [$genome], 'to-link');
    # Only proceed if both exist.
    if (! -f $subFileName || ! -f $bindFileName) {
        Trace("Missing subsystem data for $genome.") if T(1);
        $stats->Add(noSubsystems => 1);
    } else {
        # This hash maps subsystem IDs to molecular machine IDs.
        my %machines;
        # This hash maps subsystem/role pairs to machine role IDs.
        my %machineRoles;
        # This hash will contain the list of subsystems found in the database.
        my %subsystems;
        # We loop through the subsystems, looking for the ones already in the
        # database. The list is given in the subsystems file of the Subsystems
        # directory.
        my $ih = Open(undef, "<$subFileName");
        # Loop through the subsystems in the file, insuring we have them in the database.
        while (! eof $ih) {
            # Get this subsystem.
            my ($subsystem, $variant) = Tracer::GetLine($ih);
            Trace("Processing subsystem $subsystem variant $variant.") if T(SaplingDataLoader => 3);
            # Normalize the subsystem name.
            $subsystem = $sap->SubsystemID($subsystem);
            # Insure the subsystem is in the database and is one we're interested in.
            if ((! $subsysList || (grep { $_ eq $subsystem } @$subsysList)) &&
                    $sap->Exists(Subsystem => $subsystem)) {
                # We have the subsystem in the database. We need to compute the machine
                # role IDs and create the molecular machine. First, we need to remember
                # the subsystem.
                $subsystems{$subsystem} = 1;
                # Compute this subsystem's MD5.
                my $subsystemMD5 = ERDB::DigestKey($subsystem);
                my $rolePrefix = "$subsystemMD5:$genome";
                # Loop through the roles.
                my @roleList = $sap->GetAll('Includes', 'Includes(from-link) = ?',
                        [$subsystem], "to-link abbreviation");
                for my $roleTuple (@roleList) {
                    my ($roleID, $abbr) = @$roleTuple;
                    my $machineRoleID = $rolePrefix . '::' . $abbr;
                    $machineRoles{$subsystem}{$roleID} = $machineRoleID;
                # Next we need the variant code and key.
                my $variantCode = BaseSaplingLoader::Starless($variant);
                my $variantKey = ERDB::DigestKey("$subsystem:$variantCode");
                # Now we create the molecular machine connecting this genome to the
                # subsystem variant.
                my $machineID = ERDB::DigestKey("$subsystem:$variantCode:$genome");
                # Does it already exist?
                if ($machinesOld{$machineID}) {
                    # Yes. Output a warning.
                    Trace("Machine $machineID already found for $subsystem and genome $genome.") if T(1);
                    $stats->Add(duplicateMachine => 1);
                } else {
                    $sap->InsertObject('Uses', from_link => $genome, to_link => $machineID);
                    $sap->InsertObject('MolecularMachine', id => $machineID, curated => 0, region => '');
                    $sap->InsertObject('IsImplementedBy', from_link => $variantKey, to_link => $machineID);
                # Remember the machine ID.
                $machines{$subsystem} = $machineID;
        # Now we go through the bindings file. This file connects the subsystem
        # roles to the molecular machines.
        $ih = Open(undef, "<$bindFileName");
        # Loop through the bindings.
        while (! eof $ih) {
            # Get the binding data.
            my ($subsystem, $role, $fid) = Tracer::GetLine($ih);
            # Insure the subsystem is in the database.
            if ($subsystems{$subsystem}) {
                # Compute the machine role.
                my $machineRoleID = $machineRoles{$subsystem}{$role};
                # Insure it exists.
                my $created = $self->InsureEntity(MachineRole => $machineRoleID);
                if ($created) {
                    # We created the machine role, so connect it to the machine.
                    my $machineID = $machines{$subsystem};
                    $sap->InsertObject('IsMachineOf', from_link => $machineID, to_link => $machineRoleID);
                    # Connect it to the role, too.
                    $sap->InsertObject('IsRoleOf', from_link => $role, to_link => $machineRoleID);
                # Connect the feature.
                $sap->InsertObject('Contains', from_link => $machineRoleID, to_link => $fid);
=head3 CreateGenome
Create the genome record.
=cut
# This hash maps cache statistics to genome record fields.
use constant GENOME_FIELDS => {genome_name => 'scientific-name',
                               genome_domain => 'domain'};
# This hash maps domains to the prokaryotic flag.
use constant PROK_FLAG => {Bacteria => 1, Archaea => 1};
sub CreateGenome {
    my ($self) = @_;
    # Get the genome directory.
    my $dir = $self->{directory};
    # We'll put the genome attributes in here.
    my %fields;
    # Check for a basic statistics file.
    my $statsFile = "$dir/cache.basic_statistics";
    if (-f $statsFile) {
        # We have the statistics file, so read the major attributes from it.
        my $ih = Open(undef, "<$statsFile");
        while (! eof $ih) {
            my ($key, $value) = Tracer::GetLine($ih);
            my $fieldKey = GENOME_FIELDS->{$key};
            if ($fieldKey) {
                $fields{$fieldKey} = $value;
        # Translate the domain.
        $fields{domain} = ucfirst $fields{domain};
        # Denote the genome is complete.
        $fields{complete} = 1;
    } else {
        # Check to see if this genome is complete.
        $fields{complete} = (-f "$dir/COMPLETE" ? 1 : 0);
        # Get the genome name.
        my $ih = Open(undef, "<$dir/GENOME");
        $fields{'scientific-name'} = $line;
        # Get the taxonomy and extract the domain from it.
        $ih = Open(undef, "<$dir/TAXONOMY");
        ($fields{domain}) = split m/;/, <$ih>, 2;
    # Get the counts from the statistics object.
    $fields{contigs} = $stats->Ask('contigs');
    $fields{'dna-size'} = $stats->Ask('dna');
    $fields{pegs} = $stats->Ask('peg');
    $fields{rnas} = $stats->Ask('rna');
    $fields{gc_content} = $stats->Ask('gc_content') * 100 / $stats->Ask('dna');
    # Get the genetic code. The default is 11.
    $fields{'genetic-code'} = 11;
    my $geneticCodeFile = "$dir/GENETIC_CODE";
    if (-f $geneticCodeFile) {
        # There's a genetic code file, so we need to read it for the code.
        my $ih = Open(undef, "<$geneticCodeFile");
        ($fields{'genetic-code'}) = Tracer::GetLine($ih);
    # Use the domain to determine whether or not the genome is prokaryotic.
    $fields{prokaryotic} = PROK_FLAG->{$fields{domain}} || 0;
    # Compute the genome MD5.
    $fields{md5_identifier} = $md5C->CloseGenome();
    # Finally, add the genome ID.
    $fields{id} = $self->{genome};
    # Create the genome record.
    $sap->InsertObject('Genome', %fields);
=head3 ReadAssignments
    my $assignHash = $loaderObject->ReadAssignments();
Return a hash mapping each feature ID to its functional assignment. This method
essentially reads the B<assigned_functions> file into memory.
=cut
sub ReadAssignments {
    my ($self) = @_;
    my $retVal = {};
    # Loop through the assigned-functions file, storing results in the hash. Later
    # results will override earlier ones.
    my $ih = Open(undef, "<$self->{directory}/assigned_functions");
    while (! eof $ih) {
        my ($fid, $function) = Tracer::GetLine($ih);
        $retVal->{$fid} = $function;
    # Return the hash built.
    return $retVal;
=head3 FixContig
    $loaderObject->FixContig(\$contigID);
Insure that the specified contig ID contains the genome ID.
=cut
sub FixContig {
    my ($self, $contigID) = @_;
    unless ($$contigID =~ /^\d+\.\d+\:/) {
        $$contigID = "$self->{genome}:$$contigID";
=head3 ConnectLocation
    $loaderObject->ConnectLocation($fid, $contig, $segment, $left, $dir, $len);
Connect the specified feature to the specified contig location.
=over 4
=item fid
ID of the relevant feature.
=item contig
ID of the contig containing this segment of the feature (normalized).
=item segment
Ordinal number of this segment.
=item left
Location of the segment's leftmost base pair.
=item dir
Direction (strand) of the segment (C<+> or C<->).
=item len
Length of the segment (which must be no greater than the configured maximum).
=back
=cut
sub ConnectLocation {
    my ($self, $fid, $contig, $segment, $left, $dir, $len) = @_;
    # Create the relationship.
    $sap->InsertObject('IsLocatedIn', from_link => $fid, to_link => $contig,
                       begin => $left, dir => $dir, len => $len,
                       ordinal => $segment);
    # Record it in the statistics.
    $self->{stats}->Add(segment => 1);
=head2 Internal Utility Methods
=head3 ReadAnnotation
    my ($fid, $timestamp, $user, $text) = SaplingGenomeLoader::ReadAnnotation($ih);
Read the next record from an annotation file. The next record must exist (that is, an
end-of-file check should have been performed before calling this method).
=over 4
=item ih
Open file handle for the annotation file.
=item RETURN
Returns a list containing the four fields of the record read-- (0) the feature ID, (1) the
timestamp, (2) the user ID, and (3) the annotation text.
=back
=cut
sub ReadAnnotation {
    # Get the parameter.
    my ($ih) = @_;
    # Read the three fixed fields.
    my $fid = <$ih>; chomp $fid;
    my $timestamp = <$ih>; chomp $timestamp;
    my $user = <$ih>; chomp $user;
    # Loop through the lines of the text field.
    my $text = "";
    my $line = <$ih>;
    while (defined($line) && $line ne "//\n") {
        $text .= $line;
        $line = <$ih>;
    # Remove the trailing new-line from the text.
    chomp $text;
    # Return the fields.
    return ($fid, $timestamp, $user, $text);
1;
