[Bio] / Sprout / SaplingFamilyLoader.pm Repository:
View of /Sprout/SaplingFamilyLoader.pm
Fri May 24 17:48:16 2013 UTC (6 years, 10 months ago) by parrello
CVS Tags: rast_rel_2014_0729, rast_rel_2014_0912, HEAD
Incremental load improvements.
#!/usr/bin/perl -w
# Public License.
package SaplingFamilyLoader;
    use strict;
    use Tracer;
    use Stats;
    use SeedUtils;
    use SAPserver;
    use Sapling;
    use base qw(SaplingDataLoader);
=head1 Sapling Family Loader
This class reloads FIGfam data into a Sapling database from a specified
directory. This loader is designed for updating a populated database only. Links
to features and genomes are put in, but not the features and genomes themselves.
The Family tables will be dropped and then repopulated from the flat files.
=head2 Main Methods
=head3 Process
    my $stats = SaplingFamilyLoader::Process($sap, $directory);
Reload FIGfam data from the specified directory. The existing data will be
deleted.
=over 4
=item sap
L</Sapling> object for accessing the database.
=item directory
Name of the directory containing the FIGfam data files.
=item RETURN
Returns a statistics object describing the activity during the reload.
=back
=cut
sub Process {
    # Get the parameters.
    my ($sap, $directory) = @_;
    # Create the loader object.
    my $loader = SaplingFamilyLoader->new($sap, $directory);
    # Erase the current family tables.
    my @tables = qw(Family HasMember IsCoupledTo IsFamilyFor
                    HasRepresentativeOf);
    for my $table (@tables) {
        Trace("Clearing $table.") if T(2);
        $sap->TruncateTable($table);
    # Load the new family data.
    my $stats = $loader->Load();
    # Return the result.
    return $stats;
=head2 Loader Object Methods
=head3 new
    my $loaderObject = SaplingExpressionLoader->new($sap, $directory);
Create a loader object that can be used to facilitate loading Sapling data from an
FIGfam release directory.
=over 4
=item sap
L<Sapling> object used to access the target database.
=item directory
Name of the directory containing the FIGfam release.
=back
The object created contains the following fields.
=over 4
=item supportRecords
A hash of hashes, used to track the support records known to exist in the database.
=item sap
L<Sapling> object used to access the database.
=item stats
L<Stats> object for tracking statistical information about the load.
=item directory
Name of the directory containing the subsystem data.
=back
=cut
sub new {
    my ($class, $sap, $directory) = @_;
    # Create the object.
    my $retVal = SaplingDataLoader::new($class, $sap, qw(FIGfams));
    # Add our specialized data.
    $retVal->{directory} = $directory;
    return $retVal;
=head2 Internal Utility Methods
=head3 Load
Load the FIGfam data from the previously selected directory into the database.
The family tables shold exist, but must be empty. The statistics from the load
will be returned.
=cut
sub Load {
    my ($self) = @_;
    # Get the Sapling database object and the statistics object.
    my $sap = $self->{sap};
    my $stats = $self->{stats};
    # Get the name of the FIGfam release directory.
    my $figFamDir = $self->{directory};
    Trace("FIGfams will be loaded from $figFamDir.") if T(SaplingDataLoader => 2);
    # We will keep the FIGfam IDs in here. We need them to filter the coupling
    # file.
    my %figFams;
    # Read the family functions.
    Trace("Processing family functions.") if T(SaplingDataLoader => 2);
    my $ih = Open(undef, "<$figFamDir/family.functions");
    while (! eof $ih) {
        my ($fam, $function) = Tracer::GetLine($ih);
        $stats->Add(familyFunctionRecord => 1);
        if (! defined $function) {
            $function = "";
            $stats->Add(missingFamilyFunction => 1);
        # Output the family record.
        $sap->InsertObject('Family', id => $fam, family_function => $function);
        $stats->Add('insert-Family' => 1);
        # Remember that this is a valid family.
        $figFams{$fam} = 1;
        # Connect the family to its roles.
        my ($roles, $errors) = SeedUtils::roles_for_loading($function);
        if (! defined $roles) {
            # Here the family function was suspicious.
            $stats->Add(suspiciousFamilyFunction => 1);
        } else {
            # Here we have a good function.
            for my $role (@$roles) {
                $stats->Add(figfamRole => 1);
                $sap->InsertObject('IsFamilyFor', from_link => $fam,
                        to_link => $role);
                $stats->Add('insert-IsFamilyFor' => 1);
            $stats->Add(badFigfamRoles => $errors);
    close $ih;
    # Now we need to process the memberships. This hash will map each family
    # to a hash of the associated genomes.
    my %famGenomes;
    # We also need a list of the genomes in the database, so that we only
    # process features in those genomes.
    my %genomeHash = map { $_ => 1 } $sap->GetFlat('Genome', "", [], 'id');
    # Read the memberships.
    Trace("Processing family memberships.") if T(SaplingDataLoader => 2);
    $ih = Open(undef, "<$figFamDir/families.2c");
    while (! eof $ih) {
        my ($fam, $featureID) = Tracer::GetLine($ih);
        $stats->Add(familyFeatureRecord => 1);
        # Extract the genome ID.
        if ($featureID =~ /^fig\|(\d+\.\d+)/) {
            # Insure it's one of ours.
            my $genomeID = $1;
            if (! $genomeHash{$genomeID}) {
                $stats->Add(familyFeatureNotInDb => 1);
            } else {
                # It is. Connect the family to the feature.
                $sap->InsertObject('HasMember', from_link => $fam,
                        to_link => $featureID);
                $stats->Add('insert-HasMember' => 1);
                # Connect the family to the genome.
                $famGenomes{$fam}{$1} = 1;
    close $ih;
    # Connect the FIGfams to the genomes found.
    Trace("Connecting families to genomes.") if T(SaplingDataLoader => 2);
    for my $fam (keys %famGenomes) {
        my $genomeH = $famGenomes{$fam};
        for my $genome (keys %$genomeH) {
            $sap->InsertObject('HasRepresentativeOf', from_link => $genome,
                    to_link => $fam);
            $stats->Add('insert-HasRepresentativeOf' => 1);
    # Now read the coupling data.
    Trace("Processing coupling data.") if T(SaplingDataLoader => 2);
    $ih = Open(undef, "<$figFamDir/coupling.values");
    while (! eof $ih) {
        my ($from, $to, $expScore, $contigScore) = Tracer::GetLine($ih);
        $stats->Add(familyCouplingRecord => 1);
        # Verify that both FIGfams are ours and are distinct.
        if (! $figFams{$from} || ! $figFams{$to}) {
            $stats->Add(couplingFigFamNotFound => 1);
        } elsif ($from eq $to) {
            $stats->Add(couplingFigFamReflexive => 1);
        } else {
            # Everything's okay, so we can connect the two figfams together.
            # Insure the ordering is correct.
            if ($from > $to) {
                ($from, $to) = ($to, $from);
            # Forge the connection.
            $sap->InsertObject('IsCoupledTo', from_link => $from,
                        to_link => $to, co_occurrence_evidence => $contigScore,
                        co_expression_evidence => $expScore);
            $stats->Add('insert-IsCoupledTo' => 1);
    close $ih;
    # Return the statistics.
    return $stats;
1;
