[Bio] / Sprout / Sapling.pm Repository:
Log of /Sprout/Sapling.pm
Fri Nov 5 16:51:17 2010 UTC (9 years, 3 months ago) by parrello
CVS Tags: rast_rel_2010_1206
Diff to previous 1.33
More loader updates.
Fri Jun 18 20:05:33 2010 UTC (9 years, 8 months ago) by parrello
Diff to previous 1.32
New loader fixes.
Mon May 24 13:44:57 2010 UTC (9 years, 9 months ago) by parrello
Changes since 1.31: +1 -1 lines
Diff to previous 1.31
Updates for expression data and ACH loading.
Sun Mar 14 13:29:15 2010 UTC (9 years, 11 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Changes since 1.30: +4 -0 lines
Diff to previous 1.30
Fixed to handle a zero start location better.
Wed Feb 17 18:28:41 2010 UTC (10 years ago) by parrello
Changes since 1.29: +28 -3 lines
Diff to previous 1.29
Added genome filtering support to id processing.
Mon Feb 1 20:14:28 2010 UTC (10 years ago) by parrello
Diff to previous 1.28
Sapling model updates.
Thu Dec 24 16:45:02 2009 UTC (10 years, 1 month ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.27: +39 -0 lines
Diff to previous 1.27
Added a utility for parsing protein sequence IDs.
Wed Dec 16 01:45:19 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.26: +77 -1 lines
Diff to previous 1.26
Sapling v08 changes.
Fri Dec 11 19:07:33 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.25: +1 -1 lines
Diff to previous 1.25
Fixed DNA sequence computation.
Mon Nov 30 17:39:10 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.24: +11 -2 lines
Diff to previous 1.24
Added options to allow Sapling to run on my laptop.
Mon Nov 30 11:44:21 2009 UTC (10 years, 2 months ago) by parrello
Diff to previous 1.23
Added a trace message for server connections.
Wed Nov 25 20:37:04 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.22: +12 -2 lines
Diff to previous 1.22
Fixed an error in GetLocations.
Thu Oct 29 18:31:48 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.21: +8 -1 lines
Diff to previous 1.21
Fixes for ACH processing.
Tue Sep 8 21:30:33 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.20: +13 -0 lines
Diff to previous 1.20
Changed to allow for storing the DBD metadata in the database. This is currently only activated for Sapling.
Mon Aug 31 22:07:53 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.19: +4 -3 lines
Diff to previous 1.19
Fixed offset error in "ComputeDNA".
Sun Aug 30 22:12:57 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.18: +5 -1 lines
Diff to previous 1.18
Fixed a bug in FindGapRight.
Thu Aug 27 19:54:22 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.17: +62 -0 lines
Diff to previous 1.17
New stuff to update functional couplings on the fly.
Wed Aug 19 17:09:03 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.16: +41 -0 lines
Diff to previous 1.16
Added a method to return a list of the genomes in a pair set.
Tue Aug 11 19:36:46 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.15: +52 -0 lines
Added a method for finding the OTU of a genome.
Tue Aug 4 16:53:18 2009 UTC (10 years, 6 months ago) by parrello
Fix to alias method.
Mon Aug 3 21:32:54 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.13: +423 -21 lines
Updates to Sapling for new Sapling server functions.
Wed Jul 15 23:39:58 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.12: +33 -1 lines
Wed Jul 1 21:35:03 2009 UTC (10 years, 7 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Changes since 1.11: +70 -0 lines
Fixed pegs_for_role to return an empty list if the role is not found.
Tue Jun 30 19:53:51 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.10: +125 -23 lines
Fixed error in subsystem Contains relationship.
Tue Jun 16 21:58:36 2009 UTC (10 years, 8 months ago) by parrello
Changes since 1.9: +16 -7 lines
Fixed diagram URL. Updated to use new key scheme for faster subsystem queries.
Thu Jun 4 18:22:32 2009 UTC (10 years, 8 months ago) by parrello
Changes since 1.8: +105 -5 lines
Added a GetSubsystem method.
Thu May 28 18:08:56 2009 UTC (10 years, 8 months ago) by parrello
Changes since 1.7: +156 -8 lines
Mon May 4 18:49:49 2009 UTC (10 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Updated to use Bob's protocol for load options.
Tue Apr 21 21:22:10 2009 UTC (10 years, 10 months ago) by olson
add $FIG_Config::saplingDB
Wed Mar 4 00:08:55 2009 UTC (10 years, 11 months ago) by parrello
Changes since 1.4: +5 -4 lines
Changed defaults to work with new scheme.
Mon Mar 2 22:29:03 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.3: +76 -11 lines
Added support for DNA sequence chunking.
Thu Feb 5 07:16:16 2009 UTC (11 years ago) by parrello
Changed the default mysql user name from "root" to "seed".
Added a FIG_Config parameter for specifying the database server.
Fri Jan 23 13:44:51 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: rast_rel_2009_02_05
Fixed a bug in InsertObject. Added support for demand-driven flow control.
Mon Jan 19 21:43:05 2009 UTC (11 years, 1 month ago) by parrello
Sapling support.
