[Bio] / Sprout / Sapling.pm Repository:
Log of /Sprout/Sapling.pm
Links to rast_rel_2009_05_18: (view) (download) (as text) (annotate)
Mon May 4 18:49:49 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Updated to use Bob's protocol for load options.
Tue Apr 21 21:22:10 2009 UTC (10 years, 6 months ago) by olson
add $FIG_Config::saplingDB
Wed Mar 4 00:08:55 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.4: +5 -4 lines
Changed defaults to work with new scheme.
Mon Mar 2 22:29:03 2009 UTC (10 years, 7 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.3: +76 -11 lines
Added support for DNA sequence chunking.
Thu Feb 5 07:16:16 2009 UTC (10 years, 8 months ago) by parrello
Changed the default mysql user name from "root" to "seed".
Added a FIG_Config parameter for specifying the database server.
Fri Jan 23 13:44:51 2009 UTC (10 years, 8 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Fixed a bug in InsertObject. Added support for demand-driven flow control.
Mon Jan 19 21:43:05 2009 UTC (10 years, 9 months ago) by parrello
Diff to selected 1.4
Sapling support.
