[Bio] / Sprout / Sapling.pm Repository:
Diff of /Sprout/Sapling.pm
revision 1.34, Fri Nov 5 16:51:17 2010 UTC revision 1.35, Tue Dec 14 19:48:38 2010 UTC
# Line 181  Line 181
181
182  =item port  =item port
183
184  MYSQL port number to use.  MYSQL port number to use (MySQL only).
185
186    =item dbms
187
188    Database management system to use (e.g. C<SQLite> or C<postgres>, default C<mysql>).
189
190  =back  =back
191
# Line 198  Line 202
202      my $userData = $options{userData} || "seed/";      my $userData = $options{userData} || "seed/";
203      my $dbhost = $options{dbhost} || $FIG_Config::saplingHost || "localhost";      my $dbhost = $options{dbhost} || $FIG_Config::saplingHost || "localhost";
204      my $port = $options{port} || 3306;      my $port = $options{port} || 3306;
205        my $dbms = $options{dbms} || 'mysql';
206      # Compute the socket. An empty string is a valid override here.      # Compute the socket. An empty string is a valid override here.
207      my $sock = $options{sock};      my $sock = $options{sock};
208      if (! defined $sock) {      if (! defined $sock) {
# Line 208  Line 213
213      $pass = "" if ! defined $pass;      $pass = "" if ! defined $pass;
214      Trace("Connecting to sapling database.") if T(2);      Trace("Connecting to sapling database.") if T(2);
215      # Connect to the database.      # Connect to the database.
216      my $dbh = DBKernel->new('mysql', $dbName, $user, $pass, $port, $dbhost, $sock);      my $dbh = DBKernel->new($dbms, $dbName, $user, $pass, $port, $dbhost, $sock);
217      # Create the ERDB object.      # Create the ERDB object.
218      my $retVal = ERDB::new($class, $dbh, $dbd, %options);      my $retVal = ERDB::new($class, $dbh, $dbd, %options);
219      # Add the load directory pointer.      # Add the load directory pointer.
# Line 1259  Line 1264
1264      return ($name eq GLOBAL);      return ($name eq GLOBAL);
1265  }  }
1266
1267    =head3 LoadGenome
1268
1269        my $stats = $sap->LoadGenome($genome, $directory);
1270
1271    Load the specified genome directory into the database. The genome's DNA, features,
1272    protein sequences, and other supporting information will be inserted. If the
1273    genome already exists, numerous errors will occur; therefore, it is recommended
1274    that the genome be deleted first using the L<ERDB/Delete> method.
1275
1276    =over 4
1277
1278    =item genom
1279
1280    The ID of the genome being loaded.
1281
1282    =item directory
1283
1284    Name of the genome directory.
1285
1286    =item RETURN
1287
1288    Returns a statistics object describing the load activity.
1289
1290    =back
1291
1292    =cut
1293
1294    sub LoadGenome {
1295        # Get the parameters.
1296        my ($self, $genome, $directory) = @_;
1297        # Verify that the directory exists.
1298        Confess ("Genome directory $directory not found.") if ! -d $directory;
1299        # Verify that the ID is valid.
1300        Confess("Invalid genome ID $genome.") if $genome !~ /^\d+\.\d+$/;
1301        # Import the loader and call it.
1302        require SaplingGenomeLoader;
1303        my $retVal = SaplingGenomeLoader::Load($self, $genome, $directory);
1304        # Return the statistics object.
1305        return $retVal;
1306    }
1307
1308  =head2 Special-Purpose Methods  =head2 Special-Purpose Methods
1309
1310  =head3 ComputeFeatureFilter  =head3 ComputeFeatureFilter
Legend:
Removed from v.1.34
changed lines
  Added in v.1.35
