[Bio] / Sprout / SHWordSearch.pm Repository:
Log of /Sprout/SHWordSearch.pm
Links to mgrast_rel_2008_0923: (view) (download) (as text) (annotate)
Thu Dec 6 14:58:03 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.9: +10 -10 lines
Mon Jul 16 20:04:51 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.8: +48 -29 lines
Tue Apr 10 06:11:43 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.7: +11 -3 lines
Added status messages for long searches.
Wed Dec 6 03:37:05 2006 UTC (13 years, 2 months ago) by parrello
Added tracing.
Sat Dec 2 09:46:01 2006 UTC (13 years, 2 months ago) by parrello
Thu Nov 16 22:59:01 2006 UTC (13 years, 3 months ago) by parrello
Changed "feature" to "gene" in a message.
Wed Nov 15 12:14:40 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.3: +3 -10 lines
Fixed a comment. Converted to use the validation method in the parent class.
Fri Nov 10 22:02:02 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.2: +7 -3 lines
Added the ADVANCED button to get to the advanced search from the word search page.
Wed Nov 8 23:19:22 2006 UTC (13 years, 3 months ago) by parrello
Added tracing.
Mon Oct 16 07:46:24 2006 UTC (13 years, 4 months ago) by parrello
Added to support simplified keyword searching.
