[Bio] / Sprout / SHToolSearch.pm Repository:
Log of /Sprout/SHToolSearch.pm
Mon Mar 2 22:34:44 2009 UTC (11 years ago) by parrello
Changes since 1.7: +6 -6 lines
Changed column ordering in results.
Revision 1.7 - (view) (download) (as text) (annotate) - [selected]
Thu Feb 5 07:25:34 2009 UTC (11 years, 1 month ago) by parrello
Changes since 1.6: +7 -3 lines
Fixed an error that occurred when a BLAST does not return any results.
Mon Jan 19 21:56:19 2009 UTC (11 years, 2 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.5: +28 -19 lines
Thu Dec 6 14:58:03 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.4: +11 -11 lines
Mon Aug 20 23:27:55 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.3: +13 -8 lines
Changed column order for output. Converted to new hint system.
Thu Aug 16 19:23:38 2007 UTC (12 years, 7 months ago) by parrello
changed tool to sequence in name of page
Wed Jul 25 16:22:07 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.1: +1 -3 lines
Removed some obsolete "use" clauses and added more tracing.
Mon Jul 16 20:04:51 2007 UTC (12 years, 8 months ago) by parrello
Diff to selected 1.7
