[Bio] / Sprout / SHToolSearch.pm Repository:
Diff of /Sprout/SHToolSearch.pm
revision 1.4, Mon Aug 20 23:27:55 2007 UTC revision 1.5, Thu Dec 6 14:58:03 2007 UTC
# Line 180  Line 180
180
181  =head3 ExecTool  =head3 ExecTool
182
183  C<< my @sims = $shelp->ExecTool($seqFile, \@genomes, $tool, $options); >>      my @sims = $shelp->ExecTool($seqFile, \@genomes, $tool, $options);
184
185  Call a tool to search for DNA sequences or features.  Call a tool to search for DNA sequences or features.
186
# Line 292  Line 292
292
293  =head3 blastXML  =head3 blastXML
294
295  C<< my @dataRows = $shelp->blastXML(\@data, $maxHits, $genome); >>      my @dataRows = $shelp->blastXML(\@data, $maxHits, $genome);
296
297  Process XML output from Blast.  Process XML output from Blast.
298
# Line 405  Line 405
405
406  =head3 scanLines  =head3 scanLines
407
408  C<< my @dataRows = $shelp->scanLines(\@data, $maxHits, $genome); >>      my @dataRows = $shelp->scanLines(\@data, $maxHits, $genome);
409
410  Process output from the scan-for-matches tool. Each match consists of two  Process output from the scan-for-matches tool. Each match consists of two
411  output lines. The first contains the hit source (feature or contig), the  output lines. The first contains the hit source (feature or contig), the
# Line 475  Line 475
475
476  =head3 Canonize  =head3 Canonize
477
478  C<< my $newName = CallScanner::Canonize($name, $genomeID); >>      my $newName = CallScanner::Canonize($name, $genomeID);
479
480  If the specified name is a contig ID, insure it has a genome ID in front of it.  If the specified name is a contig ID, insure it has a genome ID in front of it.
481
# Line 512  Line 512
512
513  =head3 VerifyDB  =head3 VerifyDB
514
515  C<< CallScanner::VerifyDB($db, $type); >>      CallScanner::VerifyDB($db, $type);
516
517  Verify that the specified FASTA file has BLAST databases. If the databases  Verify that the specified FASTA file has BLAST databases. If the databases
518  do not exist, they will be created. If they are older than the FASTA file,  do not exist, they will be created. If they are older than the FASTA file,
# Line 551  Line 551
551
552  =head3 ToolSortKey  =head3 ToolSortKey
553
554  C<< my $key = $shelp->ToolSortKey($genome, $bsc, $hitLoc); >>      my $key = $shelp->ToolSortKey($genome, $bsc, $hitLoc);
555
556  Return the sort key for a match result against the specified  Return the sort key for a match result against the specified
557  genome with the specified bit-score. The results are  genome with the specified bit-score. The results are
# Line 614  Line 614
614
615  =head3 Form  =head3 Form
616
617  C<< my $html = $shelp->Form(); >>      my $html = $shelp->Form();
618
619  Generate the HTML for a form to request a new search.  Generate the HTML for a form to request a new search.
620
# Line 678  Line 678
678
679  =head3 Find  =head3 Find
680
681  C<< my $resultCount = $shelp->Find(); >>      my $resultCount = $shelp->Find();
682
683  Conduct a search based on the current CGI query parameters. The search results will  Conduct a search based on the current CGI query parameters. The search results will
684  be written to the session cache file and the number of results will be  be written to the session cache file and the number of results will be
# Line 772  Line 772
772
773  =head3 Description  =head3 Description
774
775  C<< my $htmlText = $shelp->Description(); >>      my $htmlText = $shelp->Description();
776
777  Return a description of this search. The description is used for the table of contents  Return a description of this search. The description is used for the table of contents
778  on the main search tools page. It may contain HTML, but it should be character-level,  on the main search tools page. It may contain HTML, but it should be character-level,
# Line 789  Line 789
789
790  =head3 SearchTitle  =head3 SearchTitle
791
792  C<< my $titleHtml = $shelp->SearchTitle(); >>      my $titleHtml = $shelp->SearchTitle();
793
794  Return the display title for this search. The display title appears above the search results.  Return the display title for this search. The display title appears above the search results.
795  If no result is returned, no title will be displayed. The result should be an html string  If no result is returned, no title will be displayed. The result should be an html string
Legend:
Removed from v.1.4
changed lines
  Added in v.1.5
