[Bio] / Sprout / SHSubSearch.pm Repository:
Log of /Sprout/SHSubSearch.pm
Changes since 1.9: +4 -4 lines
Diff to previous 1.9 , to selected 1.5
Tue Apr 29 20:53:35 2008 UTC (11 years, 5 months ago) by parrello
Diff to previous 1.8 , to selected 1.5
Changed title of page.
CVS Tags: rast_rel_2008_04_23
Changes since 1.7: +4 -4 lines
Diff to previous 1.7 , to selected 1.5
Mon Nov 5 21:31:01 2007 UTC (11 years, 11 months ago) by parrello
Changes since 1.6: +9 -11 lines
Fixed a bad error that caused searches to fail.
Changes since 1.5: +10 -12 lines
Tue Apr 10 06:11:01 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.4: +5 -0 lines
Added status messages for long searches.
Sun Feb 4 13:08:07 2007 UTC (12 years, 8 months ago) by parrello
Fixed an awkard comment.
Sat Dec 2 09:46:01 2006 UTC (12 years, 10 months ago) by parrello
Sat Nov 18 00:52:59 2006 UTC (12 years, 11 months ago) by parrello
Changed form title.
Wed Nov 15 12:14:14 2006 UTC (12 years, 11 months ago) by parrello
Diff to selected 1.5
Added a keyword box to make it more obvious this is a search.
