[Bio] / Sprout / SHSubSearch.pm Repository:
Log of /Sprout/SHSubSearch.pm
Tue Apr 29 20:53:35 2008 UTC (11 years, 7 months ago) by parrello
Changed title of page.
CVS Tags: rast_rel_2008_04_23
Changes since 1.7: +4 -4 lines
Mon Nov 5 21:31:01 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.6: +9 -11 lines
Fixed a bad error that caused searches to fail.
Mon Jul 16 20:04:51 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.5: +10 -12 lines
Tue Apr 10 06:11:01 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.4: +5 -0 lines
Added status messages for long searches.
Sun Feb 4 13:08:07 2007 UTC (12 years, 10 months ago) by parrello
Fixed an awkard comment.
Sat Dec 2 09:46:01 2006 UTC (13 years ago) by parrello
Sat Nov 18 00:52:59 2006 UTC (13 years ago) by parrello
Changed form title.
Wed Nov 15 12:14:14 2006 UTC (13 years, 1 month ago) by parrello
Diff to selected 1.3
Added a keyword box to make it more obvious this is a search.
