[Bio] / Sprout / SHPropSearch.pm Repository:
Log of /Sprout/SHPropSearch.pm
Changes since 1.6: +5 -5 lines
Tue Sep 11 23:27:42 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.5: +0 -2 lines
Removed obsolete FeatureData reference.
Changes since 1.4: +30 -17 lines
Wed Nov 15 22:34:50 2006 UTC (12 years, 11 months ago) by parrello
Wed Nov 15 12:13:05 2006 UTC (12 years, 11 months ago) by parrello
Fixed a comment.
Fri Nov 3 00:41:19 2006 UTC (12 years, 11 months ago) by parrello
Changed the name from "Property Search" to "Attribute Search" so that it matches the pages derived from SEED code.
Thu Oct 19 02:10:06 2006 UTC (12 years, 11 months ago) by parrello
Added to allow the property searches currently used for essentiality in NMPDR.
