[Bio] / Sprout / SHPropSearch.pm Repository:
Log of /Sprout/SHPropSearch.pm
Changes since 1.6: +5 -5 lines
Tue Sep 11 23:27:42 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.5: +0 -2 lines
Removed obsolete FeatureData reference.
Mon Jul 16 20:04:51 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.4: +30 -17 lines
Wed Nov 15 22:34:50 2006 UTC (13 years ago) by parrello
Wed Nov 15 12:13:05 2006 UTC (13 years ago) by parrello
Fixed a comment.
Fri Nov 3 00:41:19 2006 UTC (13 years ago) by parrello
Changed the name from "Property Search" to "Attribute Search" so that it matches the pages derived from SEED code.
Thu Oct 19 02:10:06 2006 UTC (13 years, 1 month ago) by parrello
Added to allow the property searches currently used for essentiality in NMPDR.
