[Bio] / Sprout / SHGeneSearch.pm Repository:
Log of /Sprout/SHGeneSearch.pm
Changes since 1.2: +5 -5 lines
Mon Nov 5 21:30:12 2007 UTC (12 years ago) by parrello
Fixed a trace message.
Mon Aug 20 23:27:00 2007 UTC (12 years, 3 months ago) by parrello
Diff to selected 1.2
Replaces old FidSearch module.
