Log of /Sprout/SHDrugSearch.pm
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Changes since 1.11: +5 -5 lines
Diff to previous 1.11 , to selected 1.9
Changes since 1.10: +8 -8 lines
Diff to previous 1.10 , to selected 1.9
Mon Aug 20 23:23:21 2007 UTC (12 years, 1 month ago) by parrello
Fixed some bugs.
Revision 1.9 - (view) (download) (as text) (annotate) - [selected]
Changes since 1.8: +22 -91 lines
Thu May 17 23:43:57 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.7: +55 -16 lines
Diff to previous 1.7 , to selected 1.9
Fixed some bugs.
Fri May 11 06:30:48 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.6: +136 -71 lines
Diff to previous 1.6 , to selected 1.9
Converted to search for a PDB's docking results.
Mon Dec 11 19:50:05 2006 UTC (12 years, 10 months ago) by parrello
Diff to previous 1.5 , to selected 1.9
Shortened category names.
Tue Nov 28 21:50:59 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.4: +53 -8 lines
Diff to previous 1.4 , to selected 1.9
Added a method to convert drug target cateory codes to descriptive text.
Wed Nov 15 22:34:50 2006 UTC (12 years, 11 months ago) by parrello
Diff to previous 1.3 , to selected 1.9
Wed Nov 15 12:10:34 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.2: +24 -6 lines
Diff to previous 1.2 , to selected 1.9
Added a filter by score.
Fri Nov 10 22:00:19 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.1: +19 -4 lines
Diff to previous 1.1 , to selected 1.9
Removed the PDB title and replaced it with the reason for interest.
Wed Nov 8 23:18:54 2006 UTC (12 years, 11 months ago) by parrello
Diff to selected 1.9
Added to display drug target data.
