Log of /Sprout/SHDrugSearch.pm
Changes since 1.10: +8 -8 lines
Diff to previous 1.10 , to selected 1.2
Mon Aug 20 23:23:21 2007 UTC (12 years, 2 months ago) by parrello
Fixed some bugs.
Changes since 1.8: +22 -91 lines
Thu May 17 23:43:57 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.7: +55 -16 lines
Fixed some bugs.
Fri May 11 06:30:48 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.6: +136 -71 lines
Converted to search for a PDB's docking results.
Mon Dec 11 19:50:05 2006 UTC (12 years, 10 months ago) by parrello
Shortened category names.
Tue Nov 28 21:50:59 2006 UTC (12 years, 10 months ago) by parrello
Changes since 1.4: +53 -8 lines
Added a method to convert drug target cateory codes to descriptive text.
Wed Nov 15 22:34:50 2006 UTC (12 years, 11 months ago) by parrello
Wed Nov 15 12:10:34 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.2: +24 -6 lines
Added a filter by score.
Fri Nov 10 22:00:19 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.1: +19 -4 lines
Removed the PDB title and replaced it with the reason for interest.
Wed Nov 8 23:18:54 2006 UTC (12 years, 11 months ago) by parrello
Diff to selected 1.2
Added to display drug target data.
