[Bio] / Sprout / ResultHelper.pm Repository:
Log of /Sprout/ResultHelper.pm
Wed Sep 3 20:54:47 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.5: +4 -10 lines
Fixed URLs.
Thu Dec 6 14:58:03 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.4: +33 -33 lines
Tue Aug 21 00:41:56 2007 UTC (12 years, 5 months ago) by parrello
Fixed handling of non-breaking spaces in blast alignments.
Mon Aug 20 23:16:59 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.2: +30 -6 lines
Fixed handling of extra columns and alignments in XML downloads. Added code to properly process non-breaking spaces during download.
Wed Jul 25 16:20:20 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.1: +46 -44 lines
Changed so that both formlets and fake buttons can be downloaded as links. Fixed an error in the URL computation so that the URLs produced are fully-qualified.
Mon Jul 16 20:04:51 2007 UTC (12 years, 6 months ago) by parrello
