[Bio] / Sprout / Rectangle.pm Repository:
View of /Sprout/Rectangle.pm
Mon Mar 2 22:25:28 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, rast_rel_2014_0912, mgrast_dev_04082011, rast_rel_2010_0928, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, rast_rel_2009_05_18, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, rast_rel_2011_0119, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, mgrast_dev_04012011, rast_rel_2009_07_09, rast_rel_2010_0827, myrast_33, rast_rel_2011_0928, mgrast_dev_04052011, rast_rel_2009_03_26, mgrast_dev_10262011, HEAD
New data type for rectangular regions.
#!/usr/bin/perl -w
# Public License.
package Rectangle;
    use strict;
    use Tracer;
=head1 Rectangular Region Object
=head2 Introduction
This is a simple object that represents rectangular coordinates on a graphical
canvas.
The fields in this object are as follows.
=over 4
=item left
Leftmost coordinate.
=item right
Rightmost coordinate.
=item top
Top coordinate.
=item bottom
Bottom coordinate.
=back
=cut
=head3 new
    my $rect = Rectangle->new($left, $right, $top, %bottom);
Construct a new Rectangle object. The parameters are as follows.
=over 4
=item left
=item top
Top coordinate.
=item right
=item bottom
Bottom coordinate.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $left, $top, $right, $bottom) = @_;
    # Create the Rectangle object.
    my $retVal = {
                    left => $left,
                    right => $right,
                    top => $top,
                    bottom => $bottom,
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head2 Public Methods
=head3 left
    my $left = $rect->left($newValue);
Set or return the left coordinate.
=over 4
=item newValue (optional)
If specified, the new value for the left coordinate.
=item RETURN
Returns the current value of the left coordinate. (This is the new
value if a parameter was specified.)
=back
=cut
sub left {
    my ($self, $newValue) = @_;
    # Set the new value if specified.
    if (defined $newValue) {
        $self->{left} = $newValue;
    # Return the result.
    return $self->{left};
=head3 right
    my $right = $rect->right($newValue);
Set or return the right coordinate.
=over 4
If specified, the new value for the right coordinate.
=item RETURN
Returns the current value of the right coordinate. (This is the new
=back
=cut
sub right {
        $self->{right} = $newValue;
    return $self->{right};
=head3 top
    my $top = $rect->top($newValue);
Set or return the top coordinate.
=over 4
If specified, the new value for the top coordinate.
=item RETURN
Returns the current value of the top coordinate. (This is the new
=back
=cut
sub top {
        $self->{top} = $newValue;
    return $self->{top};
=head3 bottom
    my $bottom = $rect->bottom($newValue);
Set or return the bottom coordinate.
=over 4
If specified, the new value for the bottom coordinate.
=item RETURN
Returns the current value of the bottom coordinate. (This is the new
=back
=cut
sub bottom {
        $self->{bottom} = $newValue;
    return $self->{bottom};
=head3 All
    my ($left, $top, $right, $bottom) = $rect->All();
Return all four coordinates.
=cut
sub All {
    my ($self) = @_;
    # Return the results.
    return ($self->{left}, $self->{top}, $self->{right},
            $self->{bottom});
=head3 width
    my $width = $rect->width($newValue);
Set or return the width of the rectangle.
=over 4
Proposed new width.
=item RETURN
Returns the width of the rectangular region.
=back
=cut
sub width {
    # If a new value is specified, update the right edge.
        $self->{right} = $self->{left} + $newValue;
    # Return the value.
    return $self->{right} - $self->{left};
=head3 height
    my $height = $rect->height($newValue);
Set or return the height of the rectangle.
=over 4
Proposed new height.
=item RETURN
Returns the height of the rectangular region.
=back
=cut
sub height {
        $self->{bottom} = $self->{top} + $newValue;
    # Return the value.
    return $self->{bottom} - $self->{top};
1;
