[Bio] / Sprout / RHLocations.pm Repository:
Log of /Sprout/RHLocations.pm
Mon Mar 2 22:27:55 2009 UTC (11 years, 2 months ago) by parrello
Changes since 1.6: +12 -2 lines
Converted viewer buttons to feature links.
Mon Jan 19 21:56:19 2009 UTC (11 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.5: +64 -10 lines
Wed Sep 3 20:54:47 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.4: +6 -7 lines
Fixed URLs.
Thu Dec 6 14:58:03 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.3: +11 -11 lines
Mon Aug 20 23:21:03 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.2: +17 -18 lines
Changed the nearest-feature algorithm to give priority to features that overlap the hit location.
Wed Jul 25 16:19:26 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.1: +5 -5 lines
Converted the formlets to fake buttons.
Mon Jul 16 20:04:51 2007 UTC (12 years, 10 months ago) by parrello
Diff to selected 1.6
