[Bio] / Sprout / RHLocations.pm Repository:
Log of /Sprout/RHLocations.pm
Links to mgrast_rel_2008_0806: (view) (download) (as text) (annotate)
Changes since 1.3: +11 -11 lines
Mon Aug 20 23:21:03 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.2: +17 -18 lines
Changed the nearest-feature algorithm to give priority to features that overlap the hit location.
Wed Jul 25 16:19:26 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.1: +5 -5 lines
Converted the formlets to fake buttons.
Mon Jul 16 20:04:51 2007 UTC (12 years, 4 months ago) by parrello
