[Bio] / Sprout / RHLocations.pm Repository:
View of /Sprout/RHLocations.pm
Mon Jul 16 20:04:51 2007 UTC (12 years, 8 months ago) by parrello
#!/usr/bin/perl -w
package RHLocations;
    use strict;
    use Tracer;
    use BasicLocation;
    use ERDBObject;
    use POSIX;
    use base 'ResultHelper';
=head1 Location Result Helper
=head2 Introduction
The location result helper is used to display the results of a search that returns
DNA or protein locations. A DNA location is specified as a location inside a contig.
A protein location is specified as a location inside a feature.
=cut
=head2 Data Structures
=head3 NEIGHBORHOOD
Maximum distance in nucleotides for two locations to be considered in the same neighborhood.
=cut
    use constant { NEIGHBORHOOD => 4000 };
=head2 Public Methods
=head3 new
C<< my $rhelp = RHLocations->new($shelp); >>
Construct a new RHLocations object.
=over 4
=item shelp
Parent search helper object for this result helper.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $shelp) = @_;
    # Create the helper object.
    my $retVal = ResultHelper::new($class, $shelp);
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head3 BuildLocationRecord
C<< my $erdbObject = RHLocations::BuildLocationRecord($hitLocString); >>
Build an B<ERDBObject> containing data about a specified location. Unlike most
result objects, a location does not exist in the Sprout database. This method
is used to parse the location string into fields and package them as an
object for use by the column methods.
This method is provided as a static function so that the other methods of
this object have the privilege of knowing what data is in the B<ERDBObject>
generated. This is less important for the other result helpers because they
deal in database objects whose fields can be deduced from the database design.
=over 4
=item hitLocString
A string representation of a hit location, in a standard form that can
be parsed using the B<BasicLocation> constructor (e.g. C<fig|100226.1.peg.3361_140_10>
or C<100226.1:NC_003888_3766170+612>).
=item RETURN
Returns an B<ERDBObject> containing all the values parsed out of the hit location.
=back
=cut
sub BuildLocationRecord {
    my ($hitLocString) = @_;
    # Parse the location string into a location object.
    my $hitLocObject = BasicLocation->new($hitLocString);
    # Compute the genome ID from the Contig. Note that if this is a protein
    # location, the Contig is actually a feature ID. In both cases, however,
    # the genome ID is encoded as part of the ID in clear text.
    my $contig = $hitLocObject->Contig;
    $contig =~ /(\d+\.\d+)/;
    my $genome = $1;
    # Convert the components into data fields in an ERDBObject.
    my $retVal = ERDBObject->new('Location(container)' => [$contig],
                                 'Location(genome)'    => [$genome],
                                 'Location(begin)'     => [$hitLocObject->Begin],
                                 'Location(dir)'       => [$hitLocObject->Dir],
                                 'Location(length)'    => [$hitLocObject->Length],
                                 'Location(string)'    => [$hitLocObject->String]);
    # Return the result.
    return $retVal;
=head3 HitLocation
C<< my $locString = $rhelp->HitLocation(); >>
Return the hit location string for the current output line.
=cut
sub HitLocation {
    my ($self) = @_;
    # Get the record.
    my $record = $self->Record;
    # Pull out the location string.
    return $record->PrimaryValue('Location(string)');
=head3 FindNearbyFeature
C<< my $featureObject = $rhelp->FindNearbyFeature($hitLoc); >>
Find a nearby feature for this hit location. If the hit location is a protein
location (i.e. inside a known feature), then the feature is returned without
preamble. If the hit location is on a contig, the feature chosen will be the
one whose begin point or end point is closest to the location's midpoint.
This method is used by the run-time-value methods, so there will not be
a copy of the current record available.
=over 4
=item hitLoc
String describing the relevant hit location.
=item RETURN
Returns a record for the nearest feature.
=back
=cut
sub FindNearbyFeature {
    my ($self, $hitLoc) = @_;
    my $retVal;
    # Get a sprout object.
    my $shelp = $self->Parent();
    my $sprout = $shelp->DB();
    # Compute the hit location object and the target object name.
    my $hitLocObj = BasicLocation->new($hitLoc);
    # Get the location's target object.
    my $targetObjectName = $hitLocObj->Contig;
    # Check its type.
    if ($targetObjectName =~ /^fig\|/) {
        # Here the target object is a feature, so we return the feature itself.
        $retVal = $sprout->GetEntity(Feature => $targetObjectName);
        Trace("Feature $targetObjectName chosen as nearby to $hitLoc.") if T(4);
        Trace("Feature object not found.") if T(4) && ! defined $retVal;
    } else {
        # Here it's a contig, so we have to search the hard way. First, we need the
        # neighborhood size.
        my $tuningParms = $shelp->TuningParameters(neighborhood => NEIGHBORHOOD);
        my $neighborhood = $tuningParms->{neighborhood};
        Trace("Neighborhood is $neighborhood.") if T(4);
        # Widen the location by the neighborhood distance on both sides. This requires knowing
        # the contig length.
        my $contigLength = $sprout->ContigLength($targetObjectName);
        my $wideLocObj = BasicLocation->new($hitLocObj);
        $wideLocObj->Widen($neighborhood, $contigLength);
        Trace("Search neighborhood is " . $hitLocObj->String . ".") if T(4);
        # Look for features in the computed region.
        my @features = $sprout->GeneDataInRegion($targetObjectName, $wideLocObj->Left, $wideLocObj->Right);
        # Get the midpoint of the hit location.
        my $hitMidpoint = ($hitLocObj->Begin + $hitLocObj->EndPoint) / 2;
        # Search for the best choice. This will be a feature whose start or end point is closest to our
        # mid point.
        my $bestFeature;
        my $bestDistance = INT_MAX;
        for my $feature (@features) {
            # Get this feature's last location.
            my @locList = split /\s*,\s*/, $feature->PrimaryValue('Feature(location-string)');
            for my $featureLoc (@locList) {
                my $currentLoc = BasicLocation->new($featureLoc);
                for my $point ($currentLoc->Begin, $currentLoc->EndPoint) {
                    my $newDistance = abs($point - $hitMidpoint);
                    Trace("Distance is $newDistance. Best is $bestDistance.") if T(4);
                    # Now we determine whether or not this feature is better than the best one so far.
                    my $better = 0;
                    if ($newDistance < $bestDistance) {
                        # Here it's closer, so it is automatically better.
                        $better = 1;
                    } elsif ($newDistance == $bestDistance && $currentLoc->Dir eq $hitLocObj->Dir) {
                        # If the distances are the same, we break ties in favor of the location on the same strand.
                        $better = 1;
                    if ($better) {
                        $bestFeature = $feature;
                        $bestDistance = $newDistance;
        # Return the feature with the best distance.
        $retVal = $bestFeature;
    return $retVal;
=head3 NearbyFeature
C<< my $featureRecord = $rhelp->NearbyFeature($hitLoc); >>
Return the nearby feature. If it has already been found, we return it from the
cache. Otherwise we find it and then cache it on our way out.
=over 4
=item hitLoc
Location string for the current hit.
=item RETURN
Returns an C<ERDBObject> for the desired feature, or C<undef> if no such
feature exists.
=back
=cut
sub NearbyFeature {
    my $retVal;
    # Check the cache.
    my $cache = $self->Cache;
    if (exists $cache->{nearby}) {
        # Here we've already cached the value.
        $retVal = $cache->{nearby};
    } else {
        # Here we need to find it the hard way.
        $retVal = $self->FindNearbyFeature($hitLoc);
        # Save it for next time.
        $cache->{nearby} = $retVal;
    return $retVal;
=head2 Virtual Overrides
=head3 DefaultResultColumns
C<< my @colNames = $rhelp->DefaultResultColumns(); >>
Return a list of the default columns to be used by searches with this
type of result. Note that the actual default columns are computed by
the search helper. This method is only needed if the search helper doesn't
care.
The columns returned should be in the form of column names, all of which
must be defined by the result helper class.
=cut
sub DefaultResultColumns {
    return qw(orgName compareLink nextFeature nextFeatureFunction nextFeatureLink);
=head2 Column Methods
=head3 compareLink
C<< my $colDatum = RHLocations::compareLink($type => $rhelp, $key); >>
This method computes the various things we need to know into order to process
the compareLink column.
=over 4
=item type
Type of data about the column that is required: C<title> for the column title,
C<download> for the download flag, and so forth.
=item rhelp
Result helper being used to format the search output.
=item key (optional)
The key to be used to compute a run-time value.
=item RETURN
Returns the desired information about the compareLink column.
=back
=cut
sub compareLink {
    my ($type, $rhelp, $key) = @_;
    my $retVal;
    # Process according to the information requested.
    if ($type eq 'title') {
        # Return the title for this column. Button columns
        # generally don't have titles.
        $retVal = '';
    } elsif ($type eq 'download') {
        # This field should not be included in a download. It relies on the
        # existence of files that may expire soon.
        $retVal = '';
    } elsif ($type eq 'style') {
        # Here the caller wants the style class used to format this column.
        $retVal = 'leftAlign';
    } elsif ($type eq 'value') {
        # This is a run-time value that depends on the hit location.
        my $newKey = $rhelp->HitLocation;
        $retVal = "%%compareLink=$newKey";
    } elsif ($type eq 'runTimeValue') {
        my $feature = $rhelp->NearbyFeature($key);
        if (! defined($feature)) {
            # No nearby feature, so we don't return anything.
            $retVal = "";
        } else {
            # Here we want to create a formlet. We need the session ID
            # and the feature id.
            my $shelp = $rhelp->Parent;
            my $session = $shelp->ID();
            my $fid = $feature->PrimaryValue('Feature(id)');
            $retVal = $rhelp->Formlet('Context', "patscanresult.cgi", undef,
                                      page => 'genome_regions', peg => $fid,
                                      file => "tmp_$session.cache",
                                      SPROUT => 1);
    return $retVal;
=head3 nextFeature
C<< my $colDatum = RHLocations::nextFeature($type => $rhelp, $key); >>
the nextFeature column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the nextFeature column.
=back
=cut
sub nextFeature {
    my $retVal;
        $retVal = 'Nearest Feature';
        # This field should be included in a download.
        $retVal = 'text';
        $retVal = "%%nextFeature=$newKey";
            $retVal = "";
        } else {
            # Get the feature's ID.
            $retVal = $rhelp->PreferredID($feature);
    return $retVal;
=head3 nextFeatureFunction
C<< my $colDatum = RHLocations::nextFeatureFunction($type => $rhelp, $key); >>
the nextFeatureFunction column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the nextFeatureFunction column.
=back
=cut
sub nextFeatureFunction {
    my $retVal;
        $retVal = 'Assignment';
        $retVal = 'text';
        $retVal = "%%nextFeatureFunction=$newKey";
            $retVal = "";
        } else {
            # Get the feature's assignment.
            $retVal = $feature->PrimaryValue('Feature(assignment)');
    return $retVal;
=head3 nextFeatureLink
C<< my $colDatum = RHLocations::nextFeatureLink($type => $rhelp, $key); >>
the nextFeatureLink column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the nextFeatureLink column.
=back
=cut
sub nextFeatureLink {
    my $retVal;
        # Formlets don't need a column title.
        $retVal = '';
        $retVal = 'link';
        $retVal = "%%nextFeatureLink=$newKey";
            $retVal = "";
        } else {
            # Create a formlet for the feature's page.
            $retVal = $rhelp->Formlet('NMPDR', "protein.cgi", undef,
                                      prot => $fid, SPROUT => 1, new_framework => 0,
                                      user => '');
    return $retVal;
=head3 orgName
C<< my $colDatum = RHLocations::orgName($type => $rhelp, $key); >>
the orgName column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the orgName column.
=back
=cut
sub orgName {
    my $retVal;
        $retVal = 'Organism Name';
        $retVal = 'text';
        # Get the data record and the parent search helper.
        my $record = $rhelp->Record;
        # Extract the genome ID.
        my $genomeID = $record->PrimaryValue('Location(genome)');
        # Ask the parent for the organism name. This will usually be in a cache.
        $retVal = $shelp->Organism($genomeID);
        # Run-time support is not needed for this column.
    return $retVal;
1;
