[Bio] / Sprout / RHFeatures.pm Repository:
Log of /Sprout/RHFeatures.pm
Wed Sep 3 20:54:47 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.8: +6 -6 lines
Fixed URLs.
Sun Mar 23 16:15:16 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.7: +3 -3 lines
Changed viewer link to go to the seed viewer feature page.
Changes since 1.6: +28 -28 lines
Mon Nov 5 21:29:28 2007 UTC (12 years ago) by parrello
Changes since 1.5: +5 -3 lines
Changed to use the SEED Viewer instead of GBrowse.
Tue Sep 11 23:27:05 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.4: +78 -2 lines
Added GBrowse support.
Mon Aug 20 23:19:19 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.3: +28 -26 lines
Made ShowSubsystems always on. Fixed some bugs.
Wed Jul 25 16:19:26 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.2: +57 -15 lines
Converted the formlets to fake buttons.
Mon Jul 16 20:53:11 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.1: +3 -9 lines
Fixed some bugs in the advanced gene search.
Mon Jul 16 20:04:51 2007 UTC (12 years, 4 months ago) by parrello
