[Bio] / Sprout / RHFeatures.pm Repository:
Log of /Sprout/RHFeatures.pm
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Mon Mar 16 00:17:50 2009 UTC (10 years, 11 months ago) by parrello
Changes since 1.12: +3 -15 lines
Converted to use new hint support.
Mon Mar 2 22:27:29 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.11: +21 -3 lines
Converted viewer buttons to feature links.
Mon Jan 19 21:41:04 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.10: +435 -100 lines
Target search support
Fri Oct 17 16:43:15 2008 UTC (11 years, 4 months ago) by parrello
Changes since 1.9: +114 -142 lines
Removed obsolete GBrowse stuff. Added aliases and assignment data to fasta downloads. Added a protein sequence column.
Wed Sep 3 20:54:47 2008 UTC (11 years, 5 months ago) by parrello
Changes since 1.8: +6 -6 lines
Fixed URLs.
Sun Mar 23 16:15:16 2008 UTC (11 years, 11 months ago) by parrello
Changes since 1.7: +3 -3 lines
Changed viewer link to go to the seed viewer feature page.
Thu Dec 6 14:58:03 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.6: +28 -28 lines
Mon Nov 5 21:29:28 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.5: +5 -3 lines
Changed to use the SEED Viewer instead of GBrowse.
Tue Sep 11 23:27:05 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.4: +78 -2 lines
Added GBrowse support.
Mon Aug 20 23:19:19 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.3: +28 -26 lines
Made ShowSubsystems always on. Fixed some bugs.
Wed Jul 25 16:19:26 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.2: +57 -15 lines
Converted the formlets to fake buttons.
Mon Jul 16 20:53:11 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.1: +3 -9 lines
Fixed some bugs in the advanced gene search.
Mon Jul 16 20:04:51 2007 UTC (12 years, 7 months ago) by parrello
