[Bio] / Sprout / RHFeatures.pm Repository:
View of /Sprout/RHFeatures.pm
Revision 1.10 - (download) (as text) (annotate)
Fri Oct 17 16:43:15 2008 UTC (11 years, 5 months ago) by parrello
CVS Tags: rast_rel_2008_12_18, mgrast_rel_2008_1110_v2, mgrast_rel_2008_1110, rast_rel_2008_11_24
Changes since 1.9: +114 -142 lines
Removed obsolete GBrowse stuff. Added aliases and assignment data to fasta downloads. Added a protein sequence column.
#!/usr/bin/perl -w
package RHFeatures;
    use strict;
    use Tracer;
    use Sprout;
    use SearchHelper;
    use AliasAnalysis;
    use HTML;
    use base 'ResultHelper';
=head1 Feature Result Helper
=head2 Introduction
The feature result helper is used for searches where the result is a list of
features. As such, it is the biggest and most popular of all the result
helpers.
Because features are the bread and butter of the NMPDR, this helper provides
a set of built-in filters. Each built-in filter is associated
with a form fragment. The L</FilteredQuery> method returns a list of features
that satisfy all the filters used. The L</DefaultResultColumns> method will add
to the output columns relevant to the parameters of the search.
The default action of this helper is to assume no values are required for any of the
filters. In the case of a word search, you can use the method L</KeywordsRequired> to
denote that an empty keyword list is unacceptable.
=cut
=head2 Public Methods
=head3 new
    my $rhelp = RHFeatures->new($shelp);
Construct a new RHFeatures object.
=over 4
=item shelp
Parent search helper object for this result helper.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $shelp) = @_;
    # Create the helper object.
    my $retVal = ResultHelper::new($class, $shelp);
    # Denote no keyword is required.
    $retVal->{wordSearch} = 0;
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head2 Feature Filtering Support
=head3 KeywordsRequired
    $rhelp->KeywordsRequired();
Denote that a value is required for the word search (C<keywords>) field.
=cut
sub KeywordsRequired {
    my ($self) = @_;
    # Denote that a keyword is required.
    $self->{wordSearch} = 1;
=head3 FeatureFilterFormRows
    my $htmlText = RHFeatures::FeatureFilterFormRows($shelp, @sections);
Return a string of feature filter rows for a search form.
=over 4
=item shelp
Currently-active search helper.
=item sections
A list of section names. If no section names are specified, all sections will be
included.
=item RETURN
Returns the HTML text for table rows containing the selected filters.
=back
The currently-supported sections are:
=over 4
=item options
Contains checkboxes used to configure the search results. C<ShowAliases> includes feature aliases
in the output, C<FavoredAlias> allows the user to specify a favored alias for the alias list,
and C<FunctionSort> sorts the output by functional role.
=item subsystem
Restricts the features to those that participate in a single subsystem. The subsystem name is
specified in a field called C<subsystem>.
=back
=cut
sub FeatureFilterFormRows {
    my ($shelp, @sections) = @_;
    # Get the CGI and Sprout objects from the search helper.
    my $cgi = $shelp->Q();
    my $sprout = $shelp->DB();
    # We'll stuff the computed table rows in here.
    my @retVal = ();
    # If there are no sections, denote we want all of them.
    my @actualSections;
    if (@sections) {
        @actualSections = @sections;
    } else {
        @actualSections = qw(subsystem options);
    # Produce the sections in the named sequence.
    for my $section (@actualSections) {
        if ($section eq 'subsystem') {
            # Get the currently-selected subsystem name.
            my $subsystemName = $cgi->param('subsystem') || '(all)';
            # Get all the subsystems in the database.
            my @subsystemList = $sprout->GetFlat(['Subsystem'], "ORDER BY Subsystem(id)", [], 'Subsystem(id)');
            # Add the all-subsystem indicator.
            unshift @subsystemList, '(all)';
            # Format everything into a table row.
            push @retVal, $cgi->Tr($cgi->td("Subsystem"),
                                   $cgi->td({ colspan => 2 },
                                            $cgi->popup_menu(-name => 'subsystem',
                                                         -values => \@subsystemList,
                                                         -default => $subsystemName) .
                                            SearchHelper::Hint("Subsystem Filter",
                                                               "Select a subsystem to restrict output to genes in " .
                                                               "that subsystem. Note that a subsystem applies to a " .
                                                               "limited set of organisms, so using this filter may " .
                                                               "yield an empty result set.")));
        } elsif ($section eq 'options') {
            # Get the current values of the parameters.
            my $aliases = $cgi->param('ShowAliases');
            my $funcSort = $cgi->param('FunctionSort');
            my $favored = $cgi->param('FavoredAlias') || '';
            my $showProt = $cgi->param('FunctionSort');
            # Display them as checkboxes.
            push @retVal, $cgi->Tr($cgi->td("Options"),
                                   $cgi->td({colspan => 2},
                                            $cgi->checkbox(-name => 'FunctionSort',
                                                           -value => 1,
                                                           -label => 'Sort by Function',
                                                           -default => $funcSort) .
                                            $cgi->checkbox(-name => 'ShowProtein',
                                                           -value => 1,
                                                           -label => 'Show Protein Sequence',
                                                           -default => $showProt) .
                                            "<br />" .
                                            $cgi->checkbox(-name => 'ShowAliases',
                                                           -value => 1,
                                                           -label => 'Show Alias Links',
                                                           -default => $aliases) .
                                            "favoring those beginning with&nbsp;" .
                                            $cgi->textfield(-name => 'FavoredAlias',
                                                            -size => 5,
                                                            -default => $favored) .
                                            SearchHelper::Hint("Gene Display Options",
                                                               "For each gene, displays its other names (aliases). " .
                                                               "You can use the text box to specify a prefix. Aliases " .
                                                               "that begin with the prefix will be sorted to " .
                                                               "the beginning of the list.")
        } else {
            Trace("Invalid feature filter form row name \"$section\".") if T(1);
    # Return the accumulated table rows.
    return join("\n", @retVal);
=head3 WordSearchRow
    my $htmlText = RHFeatures::WordSearchRow($shelp);
Return a filter row for word searches. The word search uses the keyword search index
on the feature table, and allows many different options, including boolean flags and
phrase quoting. When a word search is used, there will be an extra field in the
returned B<ERDBObject>s-- C<search-relevance>-- which is a floating-point value that can
be used to modify the sort key for the search results.
=over 4
=item shelp
=item RETURN
Returns an HTML table row containing the form field and labels for keyword searching.
The word search parameter will have the name C<keywords>.
=back
=cut
sub WordSearchRow {
    my ($shelp) = @_;
    # Get the CGI query object.
    # Get the current keyword value.
    my $expressionString = $cgi->param('keywords') || '';
    # Create the word search row in the return variable.
    my $retVal = $cgi->Tr($cgi->td("Search Words"),
                               $cgi->td({colspan => 2}, $cgi->textfield(-name => 'keywords',
        -value => $expressionString,
        -size => 40) .
                                                        SearchHelper::Hint("Keyword Box",
        "Specify a gene ID, an EC number, " .
        "or words from subsystem names, " .
        "functional roles, and/or an organism's " .
        "taxonomy.")));
    # Return it.
    return $retVal;
=head3 GetQuery
    my $fquery = $rhelp->GetQuery($genomeID);
Construct a query for processing the features in a particular genome
relevant to a search. This method is used to retrieve all of the
features that satisfy the filtering criteria of the current search. Use this
method when your search is applying a post-query filter to the list of
features returned by the feature filters. Use L</CheckFeature> if your
search is retrieving a set of features and wants to reduce them using
the filter.
The feature filter attempts to find features in the most optimal way possible.
If a subsystem is specified, then we will start from the B<HasRoleInSubsystem>
relationship, taking advantage of the fact that all features for a given genome
are clustered together in the index. If no subsystem is specified, then we will
start from B<HasFeature>, filtering by genome. If no subsystem or genome is
specified, we start from B<Feature>. At some future point we may need
to be even more sophisticated than that.
=over 4
=item genomeID (optional)
Genome whose features are to be found and filtered. If omitted, then the
features for all genomes will be returned.
=item RETURN
Returns a hash containing information describing how to query the database
for the desired features. This hash is passed to the L</Fetch> method
to execute the query and return features.
=back
=cut
sub GetQuery {
    my ($self, $genomeID) = @_;
    Trace("Constructing query for $genomeID.") if T(3) && defined $genomeID;
    Trace("Constructing query for all genomes.") if T(3) && ! defined $genomeID;
    # Start with a hash reference.
    my $retVal = {};
    # Get the CGI query and Sprout objects.
    my $shelp = $self->Parent();
    # Get our stash variable for the property ID.
    my $propIDs;
    # Get the subsystem name. If it's "(all)", we convert to a null string.
    my $subsystem = $cgi->param('subsystem');
    $subsystem = "" if ($subsystem eq "(all)");
    # Set up the search data. The $qData will contain all the parameters we need
    # for the ERDB Get command.
    my $qData = { sprout => $sprout, count => 0 };
    # Now we determine what type of search we're doing based on the CGI paraneters.
    # Note that "findex" will be the index in the table list of the feature table.
    # We need this so we can tell the ERDB full-text search mechanism which table
    # has the keyword field in it.
    if ($subsystem) {
        # Here we are doing a subsystem search.
        $qData->{tables} = ['HasRoleInSubsystem', 'Feature'];
        $qData->{filter} = "HasRoleInSubsystem(to-link) = ?";
        $qData->{params} = [$subsystem];
        $qData->{findex} = 1;
        if (defined $genomeID) {
            # Here we're filtering by genome, so we need to add a genome filter.
            $qData->{filter} .= " AND HasRoleInSubsystem(genome) = ?";
            push @{$qData->{params}}, $genomeID;
    } elsif (defined $genomeID) {
        # This is search by genome ID, so we start from Genome.
        $qData->{tables} = ['HasFeature', 'Feature'];
        $qData->{filter} = "HasFeature(from-link) = ?";
        $qData->{params} = [$genomeID];
    } else {
        # This is a pure feature type search, so we start from Feature.
        $qData->{tables} = ['Feature'];
        $qData->{filter} = "";
        $qData->{params} = [];
        $qData->{findex} = 0;
    # Finally, check for search words. Note we take precautions to keep from being fooled by a
    # bunch of blanks.
    my $keywords = $cgi->param('keywords') || "";
    if ($keywords =~ /^\s+$/) {
        $keywords = "";
    # If we have any search words left, denote we're a keyword search.
    if ($keywords) {
        $qData->{keywords} = $keywords;
    Trace("Feature query filter is \"$qData->{filter}\" with keywords \"$keywords\".") if T(3);
    $retVal->{subsystem} = $subsystem;
    $retVal->{currentQuery} = undef;
    $retVal->{queryData} = $qData;
    $retVal->{fidCache} = {};
    # Return the query management object.
    return $retVal;
=head3 Fetch
    my $featureData = $rhelp->Fetch($fquery);
Return the data for the next feature. The object returned will be a B<ERDBObject> for
the desired feature plus any useful ancillary data. If there are no more features
it will return C<undef>.
=over 4
=item fquery
A feature query object creatd by L</GetQuery>.
=item RETURN
Returns an B<ERDBObject> for the desired feature, or C<undef> if there are no more
features available.
=back
=cut
sub Fetch {
    my ($self, $fquery) = @_;
    # Declare the return variable. If we do not find anything to put in it, the
    # user will presume we've run out of features.
    my $retVal;
    # Get the query data object.
    my $qData = $fquery->{queryData};
    # Get the feature ID cache.
    my $fidCache = $fquery->{fidCache};
    # Insure we have a query.
    my $query = $fquery->{currentQuery};
    if (! defined($query)) {
        $query = _GetNextQuery($qData);
    Trace("Starting query loop.") if T(4);
    # Loop until we find a feature or run out of queries.
    while (! defined($retVal) && defined($query)) {
        Trace("Starting fetch loop.") if T(4);
        # Save a place to store the feature that comes back.
        my $featureData;
        while (! defined($retVal) && ($featureData = $query->Fetch())) {
            # Only proceed if this feature is new.
            my $fid = $featureData->PrimaryValue('Feature(id)');
            Trace("Feature $fid found.") if T(4);
            if (! $fidCache->{$fid}) {
                # Make sure we don't check it again.
                $fidCache->{$fid} = 1;
                # Return it.
                $retVal = $featureData;
        # Check to see if we found a feature.
        if (! defined($retVal)) {
            # We did not, so we get the next query.
        } else {
            # We did, so save the query for the next call.
            $fquery->{currentQuery} = $query;
    # Return the result.
    return $retVal;
=head3 ValidParms
    my $flag = $rhelp->ValidParms();
Validate the filtering parameters for the current search request.
This method returns TRUE if the filtering parameters are valid, and FALSE if
they're invalid. In the latter case, B<SetMessage> will have been called on the
search helper object to communicate the error message.
=cut
sub Valid {
    my ($self) = @_;
    Trace("Validating filter parameters.") if T(3);
    # Get the CGI object.
    my $cgi = $self->Parent()->Q();
    # Declare the return variable. We assume everything's fine, then set it to
    # 0 if an error occurs. This enables us to flatten the IFs somewhat.
    my $retVal = 1;
    # The only validation we need to do here is for the keywords. We make use
    # of the "wordSearch" field to find out if the client has specified that
    # a keyword is required.
    if (! $self->ValidateKeywords($keywords, $self->{wordSearch})) {
        $retVal = 0;
    Trace("Validation result is $retVal.") if T(3);
    return $retVal;
=head3 ValidateKeywords
    my $okFlag = $rhelp->ValidateKeywords($keywordString, $required);
Insure that a keyword string is reasonably valid. If it is invalid, a message will be
set.
=over 4
=item keywordString
Keyword string specified as a parameter to the current search.
=item required
TRUE if there must be at least one keyword specified, else FALSE.
=item RETURN
Returns TRUE if the keyword string is valid, else FALSE. Note that a null keyword string
is acceptable if the I<$required> parameter is not specified.
=back
=cut
sub ValidateKeywords {
    my ($self, $keywordString, $required) = @_;
    # Get the parent search helper.
    my $retVal = 0;
    my @wordList = split /\s+/, $keywordString;
    # Right now our only real worry is a list of all minus words. The problem with it is that
    # it will return an incorrect result.
    my @plusWords = grep { $_ =~ /^[^\-]/ } @wordList;
    if (! @wordList) {
        if ($required) {
            $shelp->SetMessage("No search words specified.");
        } else {
            $retVal = 1;
    } elsif (! @plusWords) {
        $shelp->SetMessage("At least one keyword must be positive. All the keywords entered are preceded by minus signs.");
    } else {
        $retVal = 1;
    return $retVal;
=head3 CheckSubsystem
    my $flag = $fquery->CheckSubsystem($featureData);
Determine whether or not the specified feature is in the correct subsystem.
This method will return TRUE if we pass the test, else FALSE.
=over 4
=item featureData
B<ERDBObject> for the feature to check.
=item RETURN
Returns TRUE if the feature is in the correct subsystem, else FALSE.
=back
=cut
sub CheckSubsystem {
    my ($self, $featureData) = @_;
    my $retVal;
    # Check to see if we're filtering by subsystem.
    my $subsystem = $cgi->param('subsystem') || "(all)";
    if ($subsystem eq '(all)') {
        # Not filtering, so we pass automatically.
        $retVal = 1;
    } else {
        # Here we're filtering. Check to see if the query is filtering for us.
        if ($featureData->HasField('HasRoleInSubsystem(to-link)')) {
            my ($mySubsystem) = $featureData->Value('HasRoleInSubsystem(to-link)');
            if ($mySubsystem && $subsystem eq $mySubsystem) {
                # Yes it is, so pass automatically.
                $retVal = 1;
        if (! $retVal) {
            # Now we have to check by querying the database.
            my $sprout = $self->DB();
            my ($mySubsystem) = $sprout->GetFlat(['HasRoleInSubsystem'],
                                                 "HasRoleInSubsystem(to-link) = ? AND HasRoleInSubsystem(from-link) = ?",
                                                 [$subsystem, $self->FID()],
            if ($mySubsystem) {
                $retVal = 1;
            } else {
                $retVal = 0;
    return $retVal;
=head3 CheckFeature
    my $okFlag = $rhelp->CheckFeature($feature);
Determine whether or not the specified feature fulfills all the requirements of
this result helper's active filters. This is an expensive method, so only use
it if you are filtering something fairly small.
=over 4
=item feature
B<ERDBObject> for the feature to examine.
=item RETURN
Returns TRUE if the feature satisfies all our conditions, else FALSE.
=back
=cut
sub CheckFeature {
    my ($self, $feature) = @_;
    # Get the CGI query and database objects.
    # The first condition we require is a matching subsystem.
    my $retVal = $self->CheckSubsystem($feature);
    # If we match the subsystem, we need to check the keywords.
    my $keywords = $cgi->param('keywords') || '';
    if ($retVal && $keywords) {
        # Build a new query that will return a result only if the feature passes the keyword text.
        my $query = $sprout->Search($keywords, 0, ['Feature'], 'Feature(id) = ?',
                                    [$feature->PrimaryValue('Feature(id)')]);
        # If the query could not find a result, return FALSE.
        if (! $query->Fetch()) {
            $retVal = 0;
    return $retVal;
=head3 _GetNextQuery
    my $query = RHFeatures::_GetNextQuery($qData);
Get the next query for retrieving features. This method should only be used internally.
Currently, we have a single query. This may not always be the case, in which instance
this method will need to return multiple queries in sequence.
=over 4
=item qData
Current query data object.
=item RETURN
Returns a B<DBQuery> object for the current feature query, or C<undef> if there are no
more queries to make.
=back
=cut
sub _GetNextQuery {
    my ($qData) = @_;
    my $retVal;
    # Since there's only one query per request, we fail if this method is called
    # twice.
    if ($qData->{count} == 0) {
        $qData->{count}++;
        # Get the sprout object.
        my $sprout = $qData->{sprout};
        # The type of query is dependent on whether or not a keyword search
        # is involved.
        if (exists $qData->{keywords}) {
            Trace("Query is for a full-text search.") if T(3);
            $retVal = $sprout->Search($qData->{keywords}, $qData->{findex}, $qData->{tables},
                                      $qData->{filter}, $qData->{params});
        } else {
            $retVal = $sprout->Get($qData->{tables}, $qData->{filter}, $qData->{params});
        Trace("Query created.") if T(3);
    } else {
        Trace("Last query processed.") if T(3);
    return $retVal;
=head3 AdditionalColumns
    my @cols = $rhelp->AdditionalColumns();
Return any additional columns that should be included in the feature display.
The columns returned will be standard columns, not extra columns particular
to the search. This method is required to support the extra columns mandated
by the feature filter options row as well as extra columns that may be mandated
by keywords.
=cut
sub AdditionalColumns {
    my ($self) = @_;
    # Get the CGI query object and the sprout database.
    # Get the return value.
    my @retVal = ();
    # Check for additional columns. If the feature filter form was not used,
    # these if-conditions will automatically be FALSE.
    if ($cgi->param('ShowAliases')) {
        push @retVal, 'alias';
    if ($cgi->param('ShowProtein')) {
        push @retVal, 'protein';
    # We look for the special attribute keywords here. First, we get the special
    # field list for features.
    my %specialHash = $sprout->SpecialFields('Feature');
    Trace("Special words are: " . join(" ", keys %specialHash) . ".") if T(3);
    # Get the incoming keyword list.
    my $keywordString = $cgi->param('keywords');
    if ($keywordString) {
        # Okay, we have a keyword list here. Parse out the positive words.
        my @goodWords = ERDB::SplitKeywords($keywordString);
        Trace("Good words from the keyword list are: " . join(" ", @goodWords) . ".") if T(3);
        # Loop through them, checking for specials. (Note that in general,
        # the keyword list will contain only one or two words, so we're
        # faster cycling through it instead of cycling through the specials.)
        for my $word (@goodWords) {
            if ($specialHash{$word} eq 'property_search') {
                push @retVal, "keyword:$word";
    Trace("Returning from AdditionalColumns. " . scalar(@retVal) . " columns found.") if T(3);
    return @retVal;
=head3 SortKey
    my $key = $rhelp->SortKey($feature, $datum);
Return the sort key for the specified feature. The sort key is normally a
thing created from the group name, but it can be overridden by options
on the form generated by the feature query. For example, if a keyword
search is being used, the search relevance takes precedence over everything
but whether or not the feature is an NMPDR feature. If the user asked
to sort the features by functional assignment, that would take precedence
as well.
=over 4
=item feature
ERDB object for the feature to be sorted.
=item datum
A string to be prefixed to the sort key. If the sort is being overriden
by the search options, the overriding key will precede this value;
otherwise, this value precedes all other sort key data.
=item RETURN
Returns a string that can be used to sort the specified feature into the
correct position, or that can be suffixed to an existing key.
=back
=cut
sub SortKey {
    my ($self, $feature, $datum) = @_;
    # Insure we have a datum value.
    my $realDatum = (defined($datum) ? $datum : "");
    # Get the CGI query object and the parent search helper.
    # Get the feature ID.
    my $fid = $feature->PrimaryValue('Feature(id)');
    # Get the organism data.
    my $genomeID = $sprout->GenomeOf($fid);
    my ($orgName, $group) = $shelp->OrganismData($genomeID);
    # Start the sort key with an "A" for an NMPDR genome and a "Z" otherwise.
    my $retVal = ($group ? "A" : "Z");
    # Check for keyword filtering.
    if ($feature->HasField('Feature(search-relevance)')) {
        # If there's keyword filtering, then search relevance is a factor.
        my $relevance = $feature->PrimaryValue('Feature(search-relevance)');
        # We need to normalize it so it works in a character-based sort. We
        # also need to invert it so that a higher relevance sorts to the top.
        my $relevanceString = sprintf("%0.3f", 9999 - $relevance);
        $relevanceString = " $relevanceString" while length($relevanceString) < 11;
        # Now we add it to the sort key.
        $retVal .= $relevanceString;
    # Add the organism name and feature ID.
    $retVal .= "[$orgName $fid]";
    # Prefix the incoming datum.
    $retVal = "$datum $retVal";
    # Check for functional role sorting. If the caller is not using any feature filtering,
    # the following condition will automatically be FALSE and functional role sorting will
    # not be used.
    if ($cgi->param('FunctionSort')) {
        # Here the user wants to sort by function. We put the functional
        # assignment before the sort key.
        $retVal = $feature->PrimaryValue('Feature(assignment)') . $retVal;
    return $retVal;
=head2 Virtual Overrides
=head3 DefaultResultColumns
    my @colNames = $rhelp->DefaultResultColumns();
Return a list of the default columns to be used by searches with this
type of result. Note that the actual default columns are computed by
the search helper. This method is only needed if the search helper doesn't
care.
The columns returned should be in the form of column names, all of which
must be defined by the result helper class.
=cut
sub DefaultResultColumns {
    my ($self) = @_;
    # Start with the standard columns.
    my @retVal = qw(orgName fid function svLink subsystem);
    # Add the optional columns.
    push @retVal, $self->AdditionalColumns();
    return @retVal;
=head3 MoreDownloadFormats
    $rhelp->MoreDownloadFormats(\%dlTypes);
Add additional supported download formats to the type table. The table is a
hash keyed on the download type code for which the values are the download
descriptions. There is a special syntax that allows the placement of text
fields inside the description. Use square brackets containing the name
for the text field. The field will come in to the download request as
a GET-type field.
=over 4
=item dlTypes
Reference to a download-type hash. The purpose of this method is to add more
download types relevant to the particular result type. Each type is described
by a key (the download type itself) and a description. The description can
contain a single text field that may be used to pass a parameter to the
download. The text field is of the format C<[>I<fieldName>C<]>,
where I<fieldName> is the name to give the text field's parameter in the
generated download URL.
=back
=cut
sub MoreDownloadFormats {
    my ($self, $dlTypes) = @_;
    Trace("Adding download formats for feature helper.") if T(3);
    # Add a download type for FASTA.
    $dlTypes->{fasta} = "DNA FASTA sequences of all results including [flank]nt flanking sequence";
    $dlTypes->{pfasta} = "Protein FASTA sequences of all results";
=head3 MoreDownloadDataMethods
    my @lines = $rhelp->MoreDownloadDataMethods($objectID, $dlType, \@cols, \@colHdrs);
Create one or more lines of download data for a download of the specified type. Override
this method if you need to process more download types than the default C<tbl> method.
=over 4
=item objectID
ID of the object for this data row.
=item dlType
Download type (e.g. C<fasta>, etc.)
=item cols
Reference to a list of the data columns from the result cache, or alternatively
the string C<header> (indicating that header lines are desired) or C<footer>
(indicating that footer lines are desired).
=item colHdrs
The list of column headers from the result cache.
=item RETURN
Returns an array of data lines to output to the download file.
=back
=cut
sub MoreDownloadDataMethods {
    my ($self, $objectID, $dlType, $cols, $colHdrs) = @_;
    my @retVal;
    # Check the download type.
    if ($dlType eq 'fasta' || $dlType eq 'pfasta') {
        # The FASTA downloads do not have headers or footers, so we only
        # process if we have a real ID. A real ID has an array of columns
        # passed with it, which is what we check.
        if (ref $cols eq 'ARRAY') {
            # Okay, here we have a real ID to download. The two types of
            # fasta sequences are computed almost identically. Let's start
            # with the CGI object and the search helper.
            Trace("Processing $objectID for Fasta download.") if T(4);
            # Now, we need the flanking width from the CGI parameters. The default
            # is 0. The protein FASTA does not have flanking data, so it will always
            # use the default.
            my $flankingWidth = $cgi->param('flank') || 0;
            # Compute the fasta type.
            my $type = ($dlType eq 'fasta' ? 'dna' : 'prot');
            # Get the real feature ID. Usually, this will have no effect.
            my ($fid) = $sprout->FeaturesByAlias($objectID);
            Trace("Real ID of $objectID is $fid.") if T(4);
            # Get the feature's genome ID.
            # Compute the fasta comments. These include the organism ID, function,
            # and optionally the aliases. First, we get a cheap hash of the
            # column values.
            my $nCols = scalar(@$cols) - 1;
            my %colData = map { $colHdrs->[$_] => $cols->[$_] }
                            grep { ! ref($colHdrs->[$_]) } (0 .. $nCols);
            # We'll put the comments in here. The organism name is first, and it's
            # unconditional.
            my @comments = "[" . $shelp->Organism($genomeID) . "]";
            # Next the aliases, but only if they're in the result columns. We
            # also limit ourselves to curated aliases.
            if (exists $colData{alias}) {
                push @comments, map { "[$_]" } $sprout->GetFlat(['IsAlsoFoundIn'],
        "IsAlsoFoundIn(from-link) = ?",
        [$fid], 'IsAlsoFoundIn(alias)');
            # We get the function from the columns.
            if (exists $colData{function}) {
                push @comments, $colData{function}
            # We're done. Ask the search helper for the fasta data.
            my $fasta = $shelp->ComputeFASTA($type => $objectID, $flankingWidth,
                                             join(" ", @comments));
            # Break it into lines.
            @retVal = split(/\n/, $fasta);
        } else {
            Trace("Header/footer line skipped.") if T(3);
    } else {
        # Here the download type is not one we recognize.
        Confess("Invalid download type \"$dlType\" specified for result class $self->{type}.");
    # Return the output.
    return @retVal;
=head2 Utility Methods
=head3 CurrentFeature
    my $featureRecord = $rhelp->CurrentFeature($fid);
Return the feature record for the specified feature. If the feature record
is already cached, we'll use the cache value; otherwise, we will pull in the
feature record from the database.
=over 4
=item fid
Current feature's ID.
=item RETURN
Returns an B<ERDBObject> for the specified feature.
=back
=cut
sub CurrentFeature {
    my ($self, $fid) = @_;
    # Check the cache.
    my $cache = $self->Cache();
    my $retVal = $cache->{feature};
    # If the cache is empty, read the feature from the database.
        $retVal = $sprout->GetEntity(Feature => $fid);
        # Put it in the cache for future use.
        $cache->{feature} = $retVal;
    # Return the feature.
    return $retVal;
=head2 Column Methods
=head3 alias
    my $colDatum = RHFeatures::alias($type => $rhelp, $key);
This method computes the various things we need to know into order to process
the alias column.
=over 4
=item type
Type of data about the column that is required: C<title> for the column title,
C<download> for the download flag, and so forth.
=item rhelp
Result helper being used to format the search output.
=item key (optional)
The key to be used to compute a run-time value.
=item RETURN
Returns the desired information about the alias column.
=back
=cut
sub alias {
    my ($type, $rhelp, $key) = @_;
    my $retVal;
    # Process according to the information requested.
    if ($type eq 'title') {
        # Return the title for this column.
        $retVal = 'External Aliases';
    } elsif ($type eq 'download') {
        # This field should be included in a download.
        $retVal = 'list';
    } elsif ($type eq 'style') {
        # Here the caller wants the style class used to format this column.
        $retVal = 'leftAlign';
    } elsif ($type eq 'value') {
        # Aliases are expensive to load, so we ask for a runtime value.
        # We need the feature ID and the favored alias type.
        my $cgi = $rhelp->Parent()->Q();
        my $fid = $rhelp->ID();
        $retVal = "%%alias=$fid/$favored";
    } elsif ($type eq 'runTimeValue') {
        # Get the Sprout database object.
        my $sprout = $rhelp->DB();
        # Split the feature ID and the favored alias prefix.
        my ($fid, $favored) = split('/', $key);
        # Get the aliases for the specified feature.
        my @aliases = $sprout->FeatureAliases($fid);
        # Is there a favored alias?
        if ($favored) {
            # Yes, so we have to sort the favored aliases to the beginning.
            my @favors = ();
            my @other = ();
            my $len = length $favored;
            my $lcFavored = lc $favored;
            # Separate the favored aliases from the others.
            for my $alias (@aliases) {
                if (lc(substr($alias, 0, $len)) eq $lcFavored) {
                    push @favors, $alias;
                } else {
                    push @other, $alias;
            # Put them back together.
            @aliases = (@favors, @other);
        # Format them into a comma-separated list with URLs where appropriate.
        $retVal = AliasAnalysis::FormatHtml(@aliases);
    return $retVal;
=head3 protein
    my $colDatum = RHFeatures::protein($type => $rhelp, $key);
the protein column.
=over 4
=item type
=item rhelp
=item RETURN
=back
=cut
sub protein {
    my $retVal;
        $retVal = 'Protein Sequence';
        $retVal = 'text';
        $retVal = 'code';
        # Proteins are expensive to load, so we ask for a runtime value.
        $retVal = "%%protein=$fid";
        # Check to see if the feature is a peg.
        if ($key =~ /peg/) {
            # Yes, get its translation.
            my $translation = $sprout->FeatureTranslation($key);
            # Bust it into pieces. This makes it easier to format when it appears in HTML.
            # The chunk size is based on FASTA rules.
            my @chunks = grep { $_ } split /(.{1,60})/, $translation;
            $retVal = join(" ", @chunks);
        } else {
            # No, leave the return value blank.
            $retVal = "";
    return $retVal;
=head3 subsystem
    my $colDatum = RHFeatures::subsystem($type => $rhelp, $key);
the subsystem column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the subsystem column.
=back
=cut
sub subsystem {
    my $retVal;
        $retVal = 'Subsystems';
        $retVal = 'list';
        # Ask for a runtime value. Subsystems are expensive to load.
        $retVal = '%%subsystem=' . $rhelp->ID();
        # Get the genome ID for this peg.
        my $genomeID = $sprout->GenomeOf($key);
        # Get the subsystems for the specified feature.
        my @subsystems = $sprout->SubsystemList($key);
        # Convert them to hyperlinks.
        my @links = map { HTML::sub_link($cgi, $_, $genomeID) } @subsystems;
        # String them together.
        $retVal = join(", ", @links);
    return $retVal;
=head3 relevance
    my $colDatum = RHFeatures::relevance($type => $rhelp, $key);
the relevance column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the relevance column.
=back
=cut
sub relevance {
    my $retVal;
        $retVal = 'Relevance';
        $retVal = 'num';
        $retVal = 'rightAlign';
        # Get the current record.
        my $record = $rhelp->Record();
        # Extract the search relevance.
        my $relevance = $record->PrimaryValue('Feature(search-relevance)');
        # Now we need to format it.
        $retVal = sprintf("%0.3f", $relevance);
        # Runtime support is not needed for this column.
    return $retVal;
=head3 keyword
    my $colDatum = RHFeatures::keyword($type => $rhelp, $key);
the keyword column. The keyword column name contains the keyword ID as
part of the name, so when we are processing a search, the runtime value will
be the keyword ID, and when are displaying results, the runtime value will
be the keyword ID, a slash, and then the feature ID.
=over 4
=item type
=item rhelp
The key to be used to compute a run-time value, or the name of the keyword.
=item RETURN
Returns the desired information about the keyword column.
=back
=cut
sub keyword {
    my $retVal;
        $retVal = ucfirst $key;
        $retVal = 'list';
        # Getting special attribute columns is expensive, because they're multi-valued,
        # so we do this at run-time.
        $retVal = "%%keyword=$key/" . $rhelp->ID();
        # Here the caller wants the value of the named keyword. The text is the
        # keyword ID followed by the feature ID with an intervening slash.
        $key =~ /^([^\/]+)\/(.+)/;
        my $keywordName = $1;
        my $fid = $2;
        # Get the sprout database object.
        # Get the attribute values.
        Trace("Getting $keywordName values for feature $fid.") if T(4);
        my @values = $sprout->GetFlat(['Feature'], "Feature(id) = ?", [$fid],
                                      "Feature($keywordName)");
        # String them into a list.
        $retVal = join(", ", @values);
    return $retVal;
=head3 orgName
    my $colDatum = RHFeatures::orgName($type => $rhelp, $key);
the orgName column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the orgName column.
=back
=cut
sub orgName {
    my $retVal;
        $retVal = 'Organism Name';
        $retVal = 'text';
        # Extract the organism name from the search helper.
        my $shelp = $rhelp->Parent();
        $retVal = $shelp->Organism($genomeID);
        # Check to see if we're showing FIG IDs or another
        # type.
        my $aliasType = $shelp->GetPreferredAliasType();
        if ($aliasType ne 'FIG') {
            # We're showing non-FIG IDs, so we include the FIG ID in the
            # organism name.
            $retVal .= " [$fid]";
    return $retVal;
=head3 fid
    my $colDatum = RHFeatures::fid($type => $rhelp, $key);
the fid column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the fid column.
=back
=cut
sub fid {
    my $retVal;
        $retVal = 'Gene';
        $retVal = 'text';
        # Because this may involve aliases, we compute the feature ID at run-time.
        $retVal = "%%fid=" . $rhelp->ID();
        # Get the feature object from the database or the cache.
        my $feature = $rhelp->CurrentFeature($key);
        # Ask for the preferred ID.
        $retVal = $rhelp->PreferredID($feature);
    return $retVal;
=head3 function
    my $colDatum = RHFeatures::function($type => $rhelp, $key);
the function column.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the function column.
=back
=cut
sub function {
    my $retVal;
        $retVal = 'Functional Assignment';
        $retVal = 'text';
        my $feature = $rhelp->Record();
        # Extract the functional role.
        $retVal = $feature->PrimaryValue('Feature(assignment)');
    return $retVal;
=head3 svLink
    my $colDatum = RHFeatures::svLink($type => $rhelp, $key);
the SeedViewer link column. Currently, this takes us to the Seed Viewer's
feature page.
=over 4
=item type
=item rhelp
=item RETURN
Returns the desired information about the gblink column.
=back
=cut
sub svLink {
    my $retVal;
        $retVal = 'Viewer';
        # This field should not be included in a download.
        $retVal = '';
        $retVal = 'center';
        # Here we want a link to the GBrowse page using the official GBrowse button.
        $retVal = $rhelp->FakeButton('Viewer', "wiki/rest.cgi/NmpdrPlugin/SeedViewer", undef, page => 'Annotation',
                                     feature => $rhelp->ID());
    return $retVal;
1;
