[Bio] / Sprout / PropertySproutLoader.pm Repository:
Log of /Sprout/PropertySproutLoader.pm
Thu Apr 2 01:40:00 2009 UTC (10 years, 10 months ago) by parrello
Changes since 1.2: +2 -3 lines
Removed PFAMs from the attributes to avoid a memory problem.
Mon Jan 19 21:46:21 2009 UTC (11 years, 1 month ago) by parrello
Changes since 1.1: +8 -11 lines
ERDB 2.0 support
Thu Oct 9 18:16:26 2008 UTC (11 years, 4 months ago) by parrello
New Sprout loaders.
