Parent Directory
Revision Log
ERDB 2.0 support
#!/usr/bin/perl -w # # Copyright (c) 2003-2006 University of Chicago and Fellowship # for Interpretations of Genomes. All Rights Reserved. # # This file is part of the SEED Toolkit. # # The SEED Toolkit is free software. You can redistribute # it and/or modify it under the terms of the SEED Toolkit # Public License. # # You should have received a copy of the SEED Toolkit Public License # along with this program; if not write to the University of Chicago # at info@ci.uchicago.edu or the Fellowship for Interpretation of # Genomes at veronika@thefig.info or download a copy from # http://www.theseed.org/LICENSE.TXT. # package PropertySproutLoader; use strict; use Tracer; use ERDB; use base 'BaseSproutLoader'; =head1 Sprout Property Load Group Class =head2 Introduction The Load Group includes all of the major searchable attribute tables. =head3 new my $sl = SproutLoader->new($erdb, $source, $options, @tables); Construct a new SproutLoader object. =over 4 =item erdb [[SproutPm]] object for the database being loaded. =item options Reference to a hash of command-line options. =item tables List of tables in this load group. =back =cut sub new { # Get the parameters. my ($class, $erdb, $options) = @_; # Create the table list. my @tables = sort qw(Property HasProperty); # Create the BaseSproutLoader object. my $retVal = BaseSproutLoader::new($class, $erdb, $options, @tables); # Return it. return $retVal; } =head2 Public Methods =head3 Generate $sl->Generate(); Generate the data for the searchable attribute files. =cut sub Generate { # Get the parameters. my ($self) = @_; # Get the sprout object. my $sprout = $self->db(); # Get the FIG object. my $fig = $self->source(); # All of the property stuff is done globally. if ($self->global()) { # Get the list of attributes we need for these searches. Currently, it's # essentials and PFAM. my @keys = $fig->get_group_keys('essential'); push @keys, 'PFAM'; # Get a hash of genome IDs. my %genomes = map { $_ => 1 } BaseSproutLoader::GetSectionList($sprout, $fig); # This will be where we compute the property IDs. my %propIDs = (); my $nextID = 1; # Loop through these keys, getting feature IDs. for my $key (@keys) { # Get all the attributes for this key. $self->Track(keys => $key, 10); my @attributes = $fig->get_attributes(undef, $key); Trace(scalar(@attributes) . " attribute values found for $key.") if T(3); $self->Add('attribute-keys' => 1); # Loop through them, extracting the ones for genomes in the genome hash. for my $attributeTuple (@attributes) { # Extract the pieces. my ($pegID, $key, $value, $url) = @{$attributeTuple}; # Default the URL to an empty string. $url = "" if ! defined $url; # Only proceed if the peg ID is valid and for a known genome. if ($pegID =~ /^fig\|(\d+\.\d+)/ && $genomes{$1}) { # It is. Compute the property ID. my $propertyKeyValue = "$key::$value"; my $propID = $propIDs{$propertyKeyValue}; if (! defined $propID) { # Here we have a new key/value pair, so it gets a new ID number. $self->Add('attribute-pairs' => 1); $propID = $nextID++; $propIDs{$propertyKeyValue} = $propID; # Add this ID to the property table. $self->PutE(Property => $propID, 'property-name' => $key, 'property-value' => $value); } # Connect the feature to the property. $self->PutR(HasProperty => $pegID, $propID, evidence => $url); $self->Add('attributes-kept' => 1); } else { # The object isn't a feature, or it isn't for an NMPDR genome, so we skip it. $self->Add('attributes-skipped' => 1); } } } } } 1;
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
