[Bio] / Sprout / NmpdrSwitch.pl Repository:
Log of /Sprout/NmpdrSwitch.pl
Tue Feb 5 05:33:24 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.1: +0 -5 lines
Removed obsolete use clauses.
Mon Nov 5 21:28:55 2007 UTC (11 years, 11 months ago) by parrello
New script to turn NMPDR off in an emergency.
