[Bio] / Sprout / NmpdrStatus.pl Repository:
View of /Sprout/NmpdrStatus.pl
Revision 1.2 - (download) (as text) (annotate)
Tue Feb 5 05:32:35 2008 UTC (11 years, 10 months ago) by parrello
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, rast_rel_2008_06_16, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, rast_rel_2009_05_18, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Changes since 1.1: +0 -5 lines
Removed obsolete use clauses.
#!/usr/bin/perl -w
# Public License.
=head1 NMPDR Status Checker
This script examines all of the genomes and displays the NMPDR group for each.
The currently-supported command-line options are as follows.
=over 4
=item user
Name suffix to be used for log files. If omitted, the PID is used.
=item trace
Numeric trace level. A higher trace level causes more messages to appear. The
default trace level is 2. Tracing will be directly to the standard output
as well as to a C<trace>I<User>C<.log> file in the FIG temporary directory,
where I<User> is the value of the B<user> option above.
=item sql
If specified, turns on tracing of SQL activity.
=item background
Save the standard and error output to files. The files will be created
in the FIG temporary directory and will be named C<err>I<User>C<.log> and
C<out>I<User>C<.log>, respectively, where I<User> is the value of the
=item h
Display this command's parameters and options.
=item phone
Phone number to message when the script is complete.
=back
=cut
use strict;
use Tracer;
use FIG;
use Cwd;
use File::Copy;
use File::Path;
# Get the command-line options and parameters.
my ($options, @parameters) = StandardSetup([qw(FIG) ],
                                              phone => ["", "phone number (international format) to call when load finishes"],
                                           @ARGV);
# Set a variable to contain return type information.
my $rtype;
# Insure we catch errors.
eval {
    # Get the FIG object.
    my $fig = FIG->new();
    # Get a list of all the genomes.
    my $genomes = $fig->genome_list();
    Trace(scalar(@{$genomes}) . " found.") if T(3);
    # Loop through the list.
    for my $genome (@{$genomes}) {
        # Get the genome ID and name.
        my ($genomeID, $genomeName) = @{$genome};
        # Only proceed if the genome is complete. Otherwise, it's not part of NMPDR.
        my $flag = $fig->is_complete($genomeID);
        Trace("Complete flag for $genomeID is $flag.") if T(4);
        if ($flag) {
            # Compute the NMPDR group.
            my $nmpdrFile = "$FIG_Config::organisms/$genomeID/NMPDR";
            if (-e $nmpdrFile) {
                # Get the NMPDR group from the file contents.
                my ($nmpdrGroup) = Tracer::GetFile($nmpdrFile);
                # Trace the result.
                Trace("$genomeID ($genomeName) = $nmpdrGroup") if T(2);
        } else {
            # Denote this is not an NMPDR genome.
            Trace("$genomeID ($genomeName) not used.") if T(3);
    Trace("Processing complete.") if T(2);
if ($@) {
    Trace("Script failed with error: $@") if T(0);
    $rtype = "error";
} else {
    Trace("Script complete.") if T(2);
    $rtype = "no error";
if ($options->{phone}) {
    my $msgID = Tracer::SendSMS($options->{phone}, "NMPDR Status Checker terminated with $rtype.");
    if ($msgID) {
        Trace("Phone message sent with ID $msgID.") if T(2);
    } else {
        Trace("Phone message not sent.") if T(2);
1;
