[Bio] / Sprout / NewStuffCheck.pl Repository:
Log of /Sprout/NewStuffCheck.pl
Links to mgrast_rel_2008_0924: (view) (download) (as text) (annotate)
Tue Feb 5 05:15:42 2008 UTC (12 years, 2 months ago) by parrello
Changes since 1.25: +1 -3 lines
Diff to previous 1.25 , to selected 1.20
Changed the style on a table header.
Fri Dec 7 18:29:34 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.24: +21 -20 lines
Diff to previous 1.24 , to selected 1.20
Fixed group file management to eliminate the old, awful concept of sort-of groups.
Changes since 1.23: +78 -43 lines
Diff to previous 1.23 , to selected 1.20
Mon Jul 16 20:05:23 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.22: +198 -47 lines
Diff to previous 1.22 , to selected 1.20
Changed to include the figures needed for the semi-annual report.
Tue Apr 10 06:04:34 2007 UTC (13 years ago) by parrello
Changes since 1.21: +1 -14 lines
Diff to previous 1.21 , to selected 1.20
Removed attribute comparisons. Converted for better handling of old versions with different DBDs.
Thu Feb 22 22:06:29 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.20: +5 -4 lines
Diff to previous 1.20
Fixed a bug that caused genomes to be considered deleted and inserted simply because the name has changed.
Revision 1.20 - (view) (download) (as text) (annotate) - [selected]
Wed Feb 21 13:18:01 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.19: +4 -1 lines
Diff to previous 1.19
Added a BBH check for the new genomes.
Tue Jan 9 01:53:17 2007 UTC (13 years, 3 months ago) by parrello
Changes since 1.18: +6 -2 lines
Diff to previous 1.18 , to selected 1.20
Added code to split values on comma boundaries to make it easier to format PUBMED values in the output table.
Fri Nov 3 00:39:34 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.17: +1 -0 lines
Diff to previous 1.17 , to selected 1.20
Changed to convert underbars to spaces in the output, so that the results display correctly in the development blog.
Tue Oct 10 00:26:22 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.16 , to selected 1.20
Changed to convert underbars to spaces in the reports so they fit better in a smaller space.
Sun Oct 8 20:54:32 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.15: +136 -70 lines
Diff to previous 1.15 , to selected 1.20
Converted to generate an HTML result file.
Tue Sep 19 00:26:21 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.14: +3 -1 lines
Diff to previous 1.14 , to selected 1.20
Fixed a comment.
Thu Sep 14 11:35:03 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.13: +0 -2 lines
Diff to previous 1.13 , to selected 1.20
Took out reference to obsolete BBH table.
Wed Sep 6 19:29:46 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.12: +14 -9 lines
Diff to previous 1.12 , to selected 1.20
Added the ability to specify multiple candidate species per group.
Sat Sep 2 17:02:08 2006 UTC (13 years, 7 months ago) by parrello
Diff to previous 1.11 , to selected 1.20
Sat Sep 2 07:01:26 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.10: +175 -3 lines
Diff to previous 1.10 , to selected 1.20
Added features to check for possible group members and property problems.
Thu Aug 24 21:17:08 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.9: +4 -0 lines
Diff to previous 1.9 , to selected 1.20
More tracing.
Thu Aug 24 21:04:23 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.8: +2 -2 lines
Diff to previous 1.8 , to selected 1.20
Thu Aug 24 20:28:02 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.7: +124 -28 lines
Diff to previous 1.7 , to selected 1.20
Added analysis of possible SEED causes to missing data.
Thu Aug 24 17:56:21 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.6: +53 -10 lines
Diff to previous 1.6 , to selected 1.20
Even more formatting cleanup
Thu Aug 24 17:30:38 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.5: +30 -28 lines
Diff to previous 1.5 , to selected 1.20
More formatting cleanup.
Thu Aug 24 09:16:18 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.4: +2 -1 lines
Diff to previous 1.4 , to selected 1.20
Thu Aug 24 08:18:09 2006 UTC (13 years, 7 months ago) by parrello
Diff to previous 1.3 , to selected 1.20
Thu Aug 24 08:14:27 2006 UTC (13 years, 7 months ago) by parrello
Diff to previous 1.2 , to selected 1.20
Thu Aug 24 08:11:39 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.1: +33 -15 lines
Diff to previous 1.1 , to selected 1.20
Twiddled for better tracing.
Thu Aug 24 07:59:23 2006 UTC (13 years, 7 months ago) by parrello
Diff to selected 1.20
Added to compare old Sprout data to new Sprout data.
