Links to HEAD: | (view) (download) (as text) (annotate) |
Links to rast_release_2008_09_29: | (view) (download) (as text) (annotate) |
Sticky Tag: |
*sigh* more fixes
Took out the permissions configuration step. What a mess!
Added the ability to display version information.
Changed to pass the directory name to the configure command.
Converted to handle all the new craziness.
Added latest FIG_Config changes.
Added KEGG map support.
Added support for the robot_feed parameter.
Added FIG_Config setups for the RSS error feed and the NMPDR source directory.
Added two new parameters to the FIG_Config update. Fixed some pod formatting.
Added some missing config items.
Added some new configuration items.
Added support for RealCoreGenomes.
Fixed some bugs relating to version directory paths.
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
