[Bio] / Sprout / NMPDRSetup.pl Repository:
Log of /Sprout/NMPDRSetup.pl
Links to rast_rel_2008_09_29: (view) (download) (as text) (annotate)
Wed Sep 24 01:58:02 2008 UTC (11 years, 1 month ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Changes since 1.16: +4 -1 lines
Diff to previous 1.16
*sigh* more fixes
Tue Sep 23 21:48:46 2008 UTC (11 years, 1 month ago) by parrello
CVS Tags: mgrast_rel_2008_0923
Changes since 1.15: +1 -17 lines
Took out the permissions configuration step. What a mess!
Tue Sep 23 20:42:51 2008 UTC (11 years, 1 month ago) by parrello
Changes since 1.14: +76 -4 lines
Added the ability to display version information.
Tue Sep 23 02:55:49 2008 UTC (11 years, 1 month ago) by parrello
Changed to pass the directory name to the configure command.
Tue Sep 9 23:47:07 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.12: +76 -136 lines
Converted to handle all the new craziness.
Wed Sep 3 20:57:10 2008 UTC (11 years, 2 months ago) by parrello
Added latest FIG_Config changes.
Mon Jun 2 05:13:25 2008 UTC (11 years, 5 months ago) by parrello
Changes since 1.10: +1 -0 lines
Added KEGG map support.
Fri May 16 08:39:42 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.9: +1 -0 lines
Added support for the robot_feed parameter.
Wed May 7 23:09:47 2008 UTC (11 years, 6 months ago) by parrello
Added FIG_Config setups for the RSS error feed and the NMPDR source directory.
Sun Mar 23 16:12:47 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.7: +21 -7 lines
Added two new parameters to the FIG_Config update. Fixed some pod formatting.
Mon Feb 18 07:05:13 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.6: +1 -0 lines
Added some missing config items.
Thu Feb 14 19:12:24 2008 UTC (11 years, 9 months ago) by parrello
Added some new configuration items.
Thu Feb 7 00:07:03 2008 UTC (11 years, 9 months ago) by parrello
Added support for RealCoreGenomes.
Tue Feb 5 05:24:51 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.3: +17 -8 lines
Thu Dec 6 21:23:06 2007 UTC (11 years, 11 months ago) by parrello
Changes since 1.2: +19 -21 lines
Fixed some bugs relating to version directory paths.
Changes since 1.1: +54 -57 lines
Mon Nov 5 21:27:47 2007 UTC (12 years ago) by parrello
