[Bio] / Sprout / ModelSaplingLoader.pm Repository:
Log of /Sprout/ModelSaplingLoader.pm
Mon Nov 28 19:38:35 2011 UTC (7 years, 9 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Diff to previous 1.20 , to selected 1.4
Added ComplexName table
Thu Oct 6 19:05:55 2011 UTC (7 years, 11 months ago) by parrello
CVS Tags: mgrast_dev_10262011
Changes since 1.19: +73 -14 lines
Diff to previous 1.19 , to selected 1.4
Updates for new model loading procedure.
Sat Oct 1 10:35:02 2011 UTC (7 years, 11 months ago) by parrello
Changes since 1.18: +8 -2 lines
Diff to previous 1.18 , to selected 1.4
Conversion to support Postgres for ERDB.
Wed Sep 21 21:05:15 2011 UTC (7 years, 11 months ago) by parrello
CVS Tags: rast_rel_2011_0928
Diff to previous 1.17 , to selected 1.4
Changes to support complexes.
Mon May 2 17:28:09 2011 UTC (8 years, 4 months ago) by parrello
CVS Tags: mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_0, mgrast_release_3_1_1
Diff to previous 1.16 , to selected 1.4
Fixed field order in ModelGenome file.
Tue Mar 1 22:26:34 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.15: +17 -8 lines
Diff to previous 1.15 , to selected 1.4
Added more ubiquitous compounds.
Mon Feb 28 20:27:17 2011 UTC (8 years, 6 months ago) by parrello
Changes since 1.14: +23 -4 lines
Diff to previous 1.14 , to selected 1.4
Added ubiquity flag to Compound table.
Sat Feb 26 19:05:32 2011 UTC (8 years, 6 months ago) by parrello
Changes since 1.13: +194 -205 lines
Diff to previous 1.13 , to selected 1.4
Even more loader fixes.
Mon Jan 24 18:13:56 2011 UTC (8 years, 7 months ago) by parrello
Changes since 1.12: +4 -4 lines
Diff to previous 1.12 , to selected 1.4
Mon Jan 24 03:52:18 2011 UTC (8 years, 7 months ago) by parrello
Changes since 1.11: +0 -287 lines
Diff to previous 1.11 , to selected 1.4
More loader fixes.
Fri Jun 18 20:05:33 2010 UTC (9 years, 3 months ago) by parrello
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
New loader fixes.
Wed Apr 28 14:04:49 2010 UTC (9 years, 4 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Changes since 1.9: +31 -9 lines
misc load fixes
Sat Mar 27 15:19:26 2010 UTC (9 years, 5 months ago) by parrello
Mon Feb 1 20:14:28 2010 UTC (9 years, 7 months ago) by parrello
Changes since 1.7: +6 -6 lines
Sapling model updates.
Wed Dec 16 01:45:19 2009 UTC (9 years, 9 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.6: +48 -44 lines
Sapling v08 changes.
Thu Aug 27 19:52:40 2009 UTC (10 years ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.5: +9 -4 lines
Updates to fix load problems.
Wed Jul 15 23:39:58 2009 UTC (10 years, 2 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Thu May 28 18:08:56 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.2: +19 -9 lines
Tue Apr 7 14:13:11 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.1: +137 -133 lines
Fixed to skip models for non-Sapling genomes.
Wed Mar 4 00:08:30 2009 UTC (10 years, 6 months ago) by parrello
Diff to selected 1.4
Created from old ModelLoader.
