[Bio] / Sprout / Makefile Repository:
Log of /Sprout/Makefile
Links to MAIN: (view) (download) (annotate)
Thu Jun 18 01:30:31 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.23: +0 -6 lines
Diff to previous 1.23
Removed POD stuff.
Tue Jun 16 16:32:52 2009 UTC (10 years, 5 months ago) by parrello
Diff to previous 1.22
Mon Jan 19 21:48:04 2009 UTC (10 years, 10 months ago) by parrello
Changes since 1.21: +16 -7 lines
Diff to previous 1.21
Added javascript support. Removed support for DBD documentation, which is accomplished now in real-time instead of compile-time.
Thu Nov 13 19:25:09 2008 UTC (11 years ago) by olson
CVS Tags: rast_rel_2008_11_24, rast_rel_2008_12_18
Changes since 1.20: +4 -2 lines
Diff to previous 1.20
pod2html fix
Fri Jun 20 19:12:22 2008 UTC (11 years, 5 months ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.19: +2 -1 lines
Diff to previous 1.19
Fix to path for pod2html
Tue Dec 4 20:09:03 2007 UTC (12 years ago) by olson
Changes since 1.18: +3 -1 lines
Diff to previous 1.18
Rollup of release engineering changes that shoudl  make multi-architecture
installs happier.
Thu Jul 26 19:39:42 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.17: +3 -3 lines
Diff to previous 1.17
Thu Feb 8 22:02:18 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.16: +1 -0 lines
Diff to previous 1.16
mod to hopefully get around the crashing lw code updates
Wed Aug 16 03:37:02 2006 UTC (13 years, 3 months ago) by parrello
Wed Aug 16 03:35:26 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.14: +10 -3 lines
Added code to move the NMPDR search plugins to the server.
Thu Feb 16 04:09:43 2006 UTC (13 years, 9 months ago) by parrello
This time it had better work.
Thu Feb 16 02:23:45 2006 UTC (13 years, 9 months ago) by parrello
It's clear I have no idea what I'm doing.
Thu Feb 16 02:22:12 2006 UTC (13 years, 9 months ago) by parrello
Another try at this...
Thu Feb 16 01:16:29 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.10: +4 -3 lines
An attempt to generatize the movement of XML files so they work for both Sprout and SimBlocks databases.
Mon Mar 7 17:45:34 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.9: +6 -1 lines
Fixes to put XML file in FIGdisk/FIG.
Sun Jan 23 16:12:29 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.8: +19 -19 lines
no message
Tue Jan 18 20:34:16 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.7: +1 -2 lines
Rmeove reference to Tracer.pm
Tue Jan 18 18:45:35 2005 UTC (14 years, 10 months ago) by parrello
no message
Wed Jan 12 19:09:56 2005 UTC (14 years, 10 months ago) by parrello
no message
Wed Jan 12 17:05:30 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.4: +3 -1 lines
no message
Sat Dec 18 17:54:12 2004 UTC (14 years, 11 months ago) by parrello
Changes since 1.3: +1 -2 lines
no message
Sat Dec 18 17:33:01 2004 UTC (14 years, 11 months ago) by parrello
Changes since 1.2: +4 -4 lines
no message
Mon Dec 6 18:33:26 2004 UTC (15 years ago) by olson
Changes for new makefile structure.
Fri Oct 8 19:40:55 2004 UTC (15 years, 2 months ago) by olson
sprout/seed makefile
