[Bio] / Sprout / LoadProjections.pl Repository:
View of /Sprout/LoadProjections.pl
Revision 1.3 - (download) (as text) (annotate)
Fri Sep 9 13:27:02 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: rast_rel_2014_0912, rast_rel_2014_0729, mgrast_release_3_1_2, rast_rel_2011_0928, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_10262011, HEAD
Fixed Sapling constructor.
#!/usr/bin/perl -w
# Public License.
use strict;
use Tracer;
use Stats;
use ERDB;
use Sapling;
use SeedUtils;
=head1 LoadProjections
=head2 Introduction
    LoadProjections [options] <inputfile>
This script will create the ProjectOnto relationship in the Sapling database and
load it from the specified flat file. It is intended as a one-time use script.
=head2 Command-Line Options
=over 4
=item trace
Specifies the tracing level. The higher the tracing level, the more messages
will appear in the trace log. Use E to specify emergency tracing.
=item user
Name suffix to be used for log files. If omitted, the PID is used.
=item sql
If specified, turns on tracing of SQL activity.
=item background
Save the standard and error output to files. The files will be created
in the FIG temporary directory and will be named C<err>I<User>C<.log> and
C<out>I<User>C<.log>, respectively, where I<User> is the value of the
B<user> option above.
=item DBD
Name of the XML database definition file, if specified. Otherwise, the
default DBD will be used.
=item dbName
SQL name of the target database. If not specified, the default name is used.
This option allows you to specify a backup or alternate database that can
be updated without compromising the main database.
=item dbhost
Name of the MySQL database host. If not specified, the default host is used.
This option is required when the default host is restricted to read-only
database access.
=item help
Display this command's parameters and options.
=back
=cut
	# Get the command-line options and parameters.
	my ($options, @parameters) = StandardSetup([qw(ERDB) ],
	                                              DBD => ["", "if specified, the name of the DBD file to use"],
	                                              dbName => ["", "if specified, the SQL name of the target database"],
	                                              dbhost => ["", "if specified, the name of the target database"],
	                                              trace => ["2", "tracing level"],
	                                           @ARGV);
	# Create the statistics object.
	my $stats = Stats->new();
    # Create the SAPLING object.
    my $sap = Sapling->new(%$options);
	# Get the input file name.
	my $fileName = $parameters[0];
	# If a DBD was specified, internalize it.
	if ($options->{DBD}) {
		Trace("Storing $options->{DBD} in database.") if T(2);
		$sap->InternalizeDBD();
	# Now we must create a copy of the input file that has no redundant projections.
	my $ih = Tracer::Open(undef, "<$fileName");
	my $oh = Tracer::Open(undef, ">$FIG_Config::temp/projections.copy.tbl");
	while (! eof $ih) {
		my ($from, $to, $context, $percent, $score) = Tracer::GetLine($ih);
		if ($from lt $to) {
			Tracer::PutLine($oh, [$from, $to, $context, $percent, $score]);
	close $ih;
	close $oh;
	# Load the table.
	Trace("Loading projection data.") if T(2);
	$sap->LoadTable("$FIG_Config::temp/projections.copy.tbl", 'ProjectsOnto', truncate => 1, failOnError => 1);
	# Display the run statistics.
	Trace("Statistics for this run:\n" . $stats->Show()) if T(2);
