[Bio] / Sprout / LoadFIGTables.pl Repository:
Log of /Sprout/LoadFIGTables.pl
Removed obsolete use clauses.
Mon Jul 10 21:55:43 2006 UTC (13 years, 3 months ago) by parrello
Diff to selected 1.2
Added to permit a SEED database load with tracing and phone support.
