Parent Directory
Revision Log
ERDB 2.0 support
#!/usr/bin/perl -w # # Copyright (c) 2003-2006 University of Chicago and Fellowship # for Interpretations of Genomes. All Rights Reserved. # # This file is part of the SEED Toolkit. # # The SEED Toolkit is free software. You can redistribute # it and/or modify it under the terms of the SEED Toolkit # Public License. # # You should have received a copy of the SEED Toolkit Public License # along with this program; if not write to the University of Chicago # at info@ci.uchicago.edu or the Fellowship for Interpretation of # Genomes at veronika@thefig.info or download a copy from # http://www.theseed.org/LICENSE.TXT. # package HyperLink; use strict; use Tracer; use CGI qw(-nosticky); =head1 HyperLink Package =head2 Introduction This is a dinky object that can be used to encode and decode hyperlinks. The client can extract the text value, the URL value, or an HTML representation. It also contains L</Encode> and L</Decode> methods for use by [[ErdbPm]]. The hyperlink is stored in the database with the text first, to make indexing more natural. The text is followed by a space, then the URL, another space, a double color (C<::>), and the length. The fields in this object are as follows. =over 4 =item text The text of the hyperlink. =item link The URL of the link. =back =head2 Constructors =head3 new my $hl = HyperLink->new($text, $link); Construct a new HyperLink object. =over 4 =item text Text for the link. =item link (optional) URL to which we should link. =back =cut sub new { # Get the parameters. my ($class, $text, $link) = @_; # Convert an empty or zero link to an undefined one. my $url = (! $link ? undef : $link); # Create the HyperLink object. my $retVal = { text => $text, link => $url, }; # Bless and return it. bless $retVal, $class; return $retVal; } =head3 newFromHtml my $hl = HyperLink->new_from_html($htmlLink) Create a HyperLink object from an HTML link tag. =over 4 =item htmlLink Anchor href tag containing the URL and the link text. =back =cut sub newFromHtml { # Get the parameters. my ($class, $htmlLink) = @_; # Declare the return variable. my $retVal; # Parse the HTML. if ($htmlLink =~ /^<a.*?\shref="([^"]+).*>([^<]+)<\/a>$/) { # Here it's a real anchor tag. We need to unescape the text, # then pass the text and URL to the real constructor. my $link = $1; my $text = CGI::unescapeHTML($2); $retVal = new($class, $text, $link); } else { # Here it's just text. Unescape the whole thing and pass it # without a link. $retVal = CGI::unescapeHTML($htmlLink); } # Return the result. return $retVal; } =head2 Public Methods =head3 Decode my $hl = HyperLink->Decode($string); Convert a string from the database to a Hyperlink object. =over 4 =item string String read from an [[EdrbPm]] database. =item RETURN Returns a Hyperlink object represented by the string. =back =cut sub Decode { # Get the parameters. my ($class, $string) = @_; # Unescape the input string. my $realString = Tracer::UnEscape($string); # The default is to treat the string as all text, without a URL. my $text = $realString; my $url; # Get the length of the text. This is stored at the end of the string # as a number preceded by a double colon. if ($realString =~ /::(\d+)$/) { # Save the parsed length. my $textLen = $1; # Split off the text. $text = substr($realString, 0, $textLen); my $leftOver = substr($realString, $textLen); # Now we need to peel out the url. if ($leftOver =~ /(\S+)\s::/) { $url = $1; } } # Form a hyperlink out of the two pieces. my $retVal = HyperLink->new($text, $url); return $retVal; } =head3 Encode my $string = $hl->Encode(); Return the database representation for a hyperlink. =cut sub Encode { # Get the parameters. my ($self) = @_; # Compute the return value. First, we get the text length. my ($text, $url) = ($self->{text}, $self->{link}); my $textLen = length($text); # Assemble the pieces. my $string = "$text $url ::$textLen"; # Escape the assembled string. my $retVal = Tracer::Escape($string); # Return the result. return $retVal; } =head3 text my $message = $hl->text(); Return the text of a hyperlink. =cut sub text { # Get the parameters. my ($self) = @_; # Return the result. return $self->{text}; } =head3 link my $message = $hl->link(); Return the URL of a hyperlink. =cut sub link { # Get the parameters. my ($self) = @_; # Return the result. return $self->{link}; } =head3 html my $message = $hl->html(); Return the HTML representation of a hyperlink. =cut sub html { # Get the parameters. my ($self) = @_; # Declare the return variable. my $retVal; # Do we have a URL? if (defined $self->{link}) { # Yes, wrap it around the text. $retVal = CGI::a({ href => $self->{link} }, CGI::escapeHTML($self->{text})); } else { # No, return the text alone. $retVal = $self->{text}; } # Return the result. return $retVal; } 1;
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
